Schuberth SC1
Update, it works fine until I connect the intercom, I then loose the voice instructions
And do other navigation apps work? Or do they have no sound either?
Google maps and phone works, no music or MRA instructions, with intercom connected.
I think this is because you're connecting the intercom. I have the same problem on my motorcycle with the Schubert SC2, and that's because the intercomāin my case, the onboard radioāoverrides the MRA output.
When I use the motorcycleās radio via the intercom, I no longer receive instructions from MRA. As soon as I turn off the radio, the instructions come back. Iāve tried several things, but I havenāt yet managed to set MRA to have priority so that it pushes the intercom to the background when MRA gives an instruction.
If I donāt have the motorcycleās radio (intercom) on, I can play music on the Carpuride or listen to internet radio, and when MRA gives a prompt, the music gets quieter and fades into the background. -
If I donāt have the motorcycleās radio (intercom) on, I can play music on the Carpuride or listen to internet radio, and when MRA gives a prompt, the music gets quieter and fades into the background.@white.mouse Iām not exactly sure which setting it is (possibly Audio Multitasking?), but you can solve this by configuring the headset through the Schuberth app. I have the same headset myself. By the way, this setting is also available on most Sena headsets.
Sounds like you have the same problem? I have emailed Schuberth and waiting for a response. I thought I would look at the Schuberth app and see what the options are. I seem to remember there is a priority option? Iāll keep you updated. I would like to sort it out as if I use my TomTom 400 that disconnects the intercom and I have to then reset it, which quite often takes a few attempts
I have changed the priority on the Schuberth app from āintercomā to āmusicā and that appears to have worked. Not yet tried it out on the bike but fingers crossed
I have changed the priority on the Schuberth app . . .
Where in the app you can do this? In the Schuberth SC2 app I do not see this option!
On the SC1 settings page āaudio source priorityā
Well, I do not have this option. Maybe because I have the SC2!
Possibly, itās on the first page after checking for updates.
Is the SC2 fitted to the C5? -
yes. but the option is not there (anymore)
With your input, this post could be even better š
