  4. Schuberth SC1
Schuberth SC1
20 Posts 4 Posters 2.8k Views 3 Watching
  • Graham Fairhurst
    Graham Fairhurst
    Graham Fairhurst
    I have an iPhone 12 and a Schuberth C4 pro with SC1 fitted. Whilst the phone connects to the headset there are no voice instructions from the MRA. Google maps works fine. Anybody had the same problem?
    Thanks
    • CD130
      If audio works through Google Maps but not through MRA, it sounds like a setting in the MRA app may not be configured correctly. Do you hear sound through your headset when you press this?
      • Graham Fairhurst
        Graham Fairhurst
        Graham Fairhurst
        Thanks for the response
        Nothing heard when I press that. Works fine when not connected to the SC1
        Not sure how I can alter the App
        • Graham Fairhurst
          Graham Fairhurst
          Graham Fairhurst
          It now appears to be working ok. The only change I made was the “input settings” from off to normal.
          Thanks for help
          CD130 Ron van der Meer 0 2 Replies Last reply
          • Graham Fairhurst Graham Fairhurst
            Thanks for help
            Okay, it sounds a bit strange, but glad this worked 🥳👍
              Thanks for help
              Ron van der Meer 0
              Ron van der Meer 0
              Ron van der Meer 0
              @Graham-Fairhurst
              Waar zit die instelling? In de MRTA app of in de Schubert SC1 app?
              CD130 1 Reply Last reply
              • Ron van der Meer 0 Ron van der Meer 0
                @Graham-Fairhurst
                • Graham Fairhurst
                  Graham Fairhurst
                  Graham Fairhurst
                  Yes, input settings in the MRA app
                  • Graham Fairhurst
                    Graham Fairhurst
                    Graham Fairhurst
                    Update, it works fine until I connect the intercom, I then loose the voice instructions
                    • CD130
                      And do other navigation apps work? Or do they have no sound either?
                      • Graham Fairhurst
                        Graham Fairhurst
                        Graham Fairhurst
                        Google maps and phone works, no music or MRA instructions, with intercom connected.
                          I think this is because you're connecting the intercom. I have the same problem on my motorcycle with the Schubert SC2, and that's because the intercom—in my case, the onboard radio—overrides the MRA output.
                          When I use the motorcycle’s radio via the intercom, I no longer receive instructions from MRA. As soon as I turn off the radio, the instructions come back. I’ve tried several things, but I haven’t yet managed to set MRA to have priority so that it pushes the intercom to the background when MRA gives an instruction.
                          If I don’t have the motorcycle’s radio (intercom) on, I can play music on the Carpuride or listen to internet radio, and when MRA gives a prompt, the music gets quieter and fades into the background.
                            @white.mouse I’m not exactly sure which setting it is (possibly Audio Multitasking?), but you can solve this by configuring the headset through the Schuberth app. I have the same headset myself. By the way, this setting is also available on most Sena headsets.
                            • Graham Fairhurst
                              Graham Fairhurst
                              Graham Fairhurst
                              Sounds like you have the same problem? I have emailed Schuberth and waiting for a response. I thought I would look at the Schuberth app and see what the options are. I seem to remember there is a priority option? I’ll keep you updated. I would like to sort it out as if I use my TomTom 400 that disconnects the intercom and I have to then reset it, which quite often takes a few attempts
                              • Graham Fairhurst
                                Graham Fairhurst
                                Graham Fairhurst
                                I have changed the priority on the Schuberth app from “intercom” to “music” and that appears to have worked. Not yet tried it out on the bike but fingers crossed
                                  I have changed the priority on the Schuberth app . . .
                                  Where in the app you can do this? In the Schuberth SC2 app I do not see this option!
                                  • Graham Fairhurst
                                    Graham Fairhurst
                                    Graham Fairhurst
                                    On the SC1 settings page “audio source priority”
                                      Well, I do not have this option. Maybe because I have the SC2!
                                      • Graham Fairhurst
                                        Graham Fairhurst
                                        Graham Fairhurst
                                        Possibly, it’s on the first page after checking for updates.
                                        Is the SC2 fitted to the C5?
                                          yes. but the option is not there (anymore)
                                          Ron van der Meer 0
                                          Ron van der Meer 0
                                          Graham Fairhurst
                                          Graham Fairhurst
                                          • Audio cuttet via Bluetooth
                                            Haug
                                            Haug
                                            35.5k
                                          • One crash today
                                          • Download club route folders
                                            Mosimann
                                            Mosimann
                                          • Elektrisch rijden
                                            John mq
                                            John mq
                                          • Zoom level issue
