  4. V5.1.0 - 462 New altitude/heading shows incorrect Data
24 Posts 9 Posters 2.3k Views 9 Watching
  • Reinhard Punzundefined Offline
    Reinhard Punz
    In version 5.1.0 build 462 the new altitude/heading circular indicator appears horizontally mirrored.
    Examples:
    riding west lights the east/right segment
    riding northwest lights the northeast segment
    North and south appear correct, suggesting the widget mirrors east/west directions instead of having a 180° offset.
    The issue is independent of map orientation mode (North up / Dynamic / 3D).
      Reinhard Punz
      Note: The displayed altitude is approximately 50 meters too high. Sometimes only 45 meters.
        Reinhard Punz
        • Mzokkundefined Offline
          Standard GPS satellites don’t track your height from the actual ground (valleys, mountains). They measure your distance from a theoretical, mathematical model of the Earth called an ellipsoid. Your phone then has to translate that to "Mean Sea Level" using a gravity model, which can easily throw off calculations by hundreds of feet. In short your phone is not that accurate on the vertical plane. Even specific GPS devices such as Garmin are only accurate to +/- 30m unless they also take data from a topographic database which triangulates horizontal position with a topographical datum. My phone is a 60m out using MRA or OSMand (reading high) and my Zumo XT usually under or over reads by 20-30m
            Oh and strangely it can be accurate at higher elevations. I was using MRA on a trip on Saturday crossing a pass at 448m and it was reading 447M passing the datum point??
              wrote on last edited by Mzokk
              I did a little experiment with this. My house is just below a 50m contour line. My phone using MRA gives 341ft or 104M.
              Same with OSMand.
              In OSMand you can download a correction file "World Altitude Correction"
              This puts me at 157ft or 48M which would be within + or - 3m of my actual elevation.
              Might be worth building in the correction file somewhere?
              • Jörgenundefined Offline
                I noticed also that a correction of about -50 m is necessary.
                  Regarding the Noth segment display, I believe it was always correct.
                  • Guzzistundefined Offline
                    I compared several apps and GPX Tools. Only OsmAnd Shows the correct value (at my home base in southern part of Germany.
                      It’s just a nice extra feature! It’s not like your life depends on the altitude display shown by the navigation system. I see it as a fun gimmick. Whether I’m driving at sea level or at 1500 meters in mountainous terrain, it’s simply fun to see — nothing more. And I believe that’s exactly how this functionality was intended: nothing more and nothing less. Apparently, some phones handle it better than others.
                      Guzzistundefined Mzokkundefined Con Hennekensundefined 3 Replies Last reply
                        @Rob-Verhoeff I totally agree with you Rob. It was just this discussion, which let me check just at home, because I know the hight there 😊
                          @Rob-Verhoeff Agree also. Just a fun thing. Elevation isn't even critical when hill walking. I'm more of a map and old Silva compass person for that activity. I have started to use OSMand a bit whilst walking.......its a slippery slope (sorry couldn't resist) 😊
                          • Bouke Entundefined Offline
                            In The Netherlands our level is based on NAP. GPS level is based on a globel level. for yhe netherlands it is arround a 40 meter differance then our NAP.
                              Reinhard Punz
                              I also see the altitude information as a nice addition, but my main concern is the incorrect direction. It seems the direction is reversed, and west/east are swapped. North/south is displayed correctly on my Android devices.
                              • Reinhard Punzundefined Reinhard Punz
                                @Reinhard-Punz You mean the red stripe in the compass? It always pointed to the north as far as I can see.
                                Reinhard Punzundefined 1 Reply Last reply
                                  @Rob-Verhoeff, That is of course true, but does not reason away why other apps show it right 😉 If correction is possible, I am all for it.
                                    Reinhard Punz
                                    @Rob-Verhoeff Yes, exactly. The screenshot shows that I'm facing southwest, but the compass is pointing southeast. I'm at an altitude of approximately 331 meters.Screenshot_20260526_133821.jpg
                                      @Reinhard-Punz, I don't think the direction you are facing is relevant. It's the direction you are moving to that is. It looks like you are stationary. Then it will not work.
                                        Reinhard Punz
                                        @Con-Hennekens It's true that in this example I was on foot (so very slowly). But I observed the same thing yesterday during a long car ride.
                                        • Stanisławundefined Offline
                                          I think the red bar is showing North and all is correct, am I wrong?
                                          Staszek
                                          Mzokkundefined
                                          Reinhard Punz
                                          Bouke Entundefined
                                          Stanisławundefined
                                            Stevedo 6 0undefined
                                          • A few observations
                                            Thomas Miklundefined
                                            Thomas Mikl
                                            Aiello antoninoundefined
                                            John S Parryundefined
                                          • Color of Via points issue
                                            Adrian Avramundefined
