  4. Can't add waypoint when Route (outline) added via Route Details.
3 Posts 2 Posters 360 Views 2 Watching
  • JP d
    JP d
    JP d
    I noticed recently that if I've planned a route and want to compare it to a prestigious route by adding it via the (Route Details) button then (Routes) button. Then I can't click on the like to add a waypoint. I can only do so where the overlay Route isn't running across the current route. Also there's no way to turn the overlay Route off. You can only delete it or Merge it.
    See image
    • JP d JP d
      See image
      @JP-d Zoom in on the map as far as possible and press and hold on the line of your route. For me, this does insert a route point with a number between the two intended points.
      JP d 1 Reply Last reply
        JP d
        JP d
        JP d
        @Rob-Verhoeff Cheers🍻 Rob
        JP d
        JP d
        • Vergrendel scherm zet alles op z'n kop
        • Route Breakdown
        • MRA 6.0.0 - 515 Carplay folder twice
        • How to delete favourites?
          3.1k
        • Hallo, wéér een nieuwe gebruiker !
