  4. Update/Viapoint announcements
5 Posts 3 Posters 50 Views
  • Skellum
    Skellum
    Skellum
    Just updated to 5.1.0 - 462 and the results are excellent so thank you Team for all of your hard work.
    However, whilst testing this update an issue cropped up that I know has been mentioned before and I am hoping can be remedied in the future, the issue is that when I add a 'Note' to a viewpoint that can be announced (I would generally do this if I am trying to point out a POI of interest) it is announced so early ie., on todays test route an announcement came 1.2 miles before reaching the POI! Hopefully you can find a way of allowing the User to adjust this distance as I appreciate other announcements may have priority in between.
    The only other issue I found is that I do not seem to be able to turn off the enabling of the 'Use all Waypoints' button so that I only see Viapoints on my route rather than seeing all route points.
    Thank you anyway though, great update!
    • Skellum Skellum
      @Skellum If this helps, via points are announced at 2 kilometres shaping points are annouced at 750 metres. There is no option to turn off shaping points, but if you choose to see and hear notes from only via points then the shaping points are only visible on screen, you will not hear any announcement from them.
      Skellum 1 Reply Last reply
      • Lluis Arasanz
        @skellum,
        Try to read this: https://forum.myrouteapp.com/post/51065
        It explains how Via and Shaping point works with announcements.
        • BMW F750GS
          Skellum
          Skellum
          Skellum
          @Nick-Carthew
          Thank you Nick, yes I'll now use shaping points with notes rather than via points as they will be that much closer to the POI. Cheers Tony
          • Lluis Arasanz Lluis Arasanz
            @skellum,
            Skellum
            Skellum
            Skellum
            @Lluis-Arasanz
            Thank you for the link, I had forgotten that you can use shaping points as well as via points for note announcements. Regards Tony
            Skellum
            Skellum
            • Routenplaner on iPad
            • New Zealand Routes
              Bull Tahr
              Bull Tahr
            • Saludo
              Bull Tahr
              Bull Tahr
              Tom Grzelinski
              Tom Grzelinski
              Tom Grzelinski
              Tom Grzelinski
