The route is planned to go the wrong way round the roundabout
Whilst planning a short route for a test, I was surprised to find that MRA Route Planner had routed the journey through a roundabout in the wrong direction.
The routing engine was set to the default (OSM).As soon as I switched the routing engine to HERE, the route was planned to go through the roundabout in the correct direction.
If I switch the calculation engine back to Standard (OSM) – and open the route in MRA Navigation – the route is initially displayed going the wrong way round the roundabout again. When I then start navigation, the route is displayed going the right way round the roundabout. However, you can still see the white line of the original route, which continues to go the wrong way round the roundabout.
Is this an OSM map error?
https://www.myrouteapp.com/de/social/route/13112788?mode=share
Yes, it’s a mapping error.
Especially if it’s just this roundabout.When starting navigation is clearly sees it’s not permitted and sends you round the other way.
@Guzzist Yes a mapping error, it is the same on the Openstreetmap site
There was no indication on the roundabout that it should be one-way
The one-way has been added
It will take a while to propogate to the live Openstreetmap site & a fair while before it appears on MRA -
thank you all, I will report to OSM
