  4. Route lines not showing
15 Posts 9 Posters 2.9k Views 4 Watching
  • Mike Morrill
    Mike Morrill
    Mike Morrill
    I have been a user since you started & am having more problems with route lines than I ever had. When I build a route, more times than I care to count route lines are not showing between cities. It is not due to road closures, or small hard to identify roads, but large highways & well known routes. I am in the USA, but have used your software throughout, Italy, Austria, Switzerland, Spain, & Norway. I travel a lot by Motorcycle.
    • Con Hennekens
      I don't understand... Can you elaborate, preferably with a screenshot?
      • Mike Morrill Mike Morrill
        @Mike-Morrill A screenshot as @Con-Hennekens asked for would be helpful but to really understand and discover the problem it would be better if you could share your route.
        Sharing your route from MRA is far better than just forwarding the .gpx files as sharing will show what map and settings you are using.
        To share your route, open the route and click the Share button top right, choose the Link option and copy and paste the URL web address into your reply. If the privacy of the route is not public you’ll get the opportunity to change this after clicking the Link option.
        • Patrick 65
          Patrick 65
          Patrick 65
          ik heb hetzelfde probleem vandaag.
          hier de link : https://www.myrouteapp.com/nl/social/route/12860220?mode=share
          • Patrick 65 Patrick 65
            @Patrick-65 Wijzig de planningkaart naar HERE.
            Change the planning map to HERE.
              @Patrick-65, It looks like you are using motorbike transport mode in the OSM map. That is not supported, but not the reason for what happens. I deducted the problem to be related to the use of Segments on OSM map. If you disable this function in the toolkit, the planner acts normal. (Show segments on map).
              • Patrick 65
                Patrick 65
                Patrick 65
                waarom dient de knop om segmenten te gebruiken dan??
                Dit was net handig om op sommige stukken snelwegen te vermijden...
                  @Patrick-65 Dat is het nog steeds. Alleen moet je je werkwijze wellicht iets aanpassen! Als je in de OSM-kaart je route maakt met segmenten, dan zet je die - zodra je klaar bent - om naar de Here kaart. Je krijgt dan een waarschuwing dat je verder gaat in een kopie van je route. De segmenten zijn dan in je route opgenomen. Voordeel is nu dat je met navigeren geen problemen hebt omdat de app natuurlijk ook gebruikmaakt van de Here-kaart.
                    @Patrick-65 said in Route lines not showing:
                    Die functionaliteit kun je dus nog steeds gewoon gebruiken, mits je de aangegeven optie uit zet. Dat betreft alléén de weergave van de segmenten op de kaart. Bij de routepunten zie je die nog steeds gewoon staan. Ik geef je deze tip alleen maar als workaround, zodat jij verder kan met je planning. Het onderliggende probleem zal moeten worden opgelost door het dev-team.
                    • Patrick 65
                      Patrick 65
                      Patrick 65
                      het lukt me niet om de segmenten toe te voegen. waar staat deze optie bij de routepunten?
                      Als ik verander (met auto) naar OSM, zie ik geen routelijnen.
                        @Patrick-65 Zet in OSM minstens 2 punten, dan kun je segmenten en de kromming aanpassen 8622.png 8623.png 8624.png
                        BMW R 1250 GS
                        DMD-NOR7E 7"
                        SPC Universal mount
                        Motorola Edge 40 "offline"
                        Sena SLR 3
                        Sena 50 R
                        • Lluis Arasanz
                          I Found a thread of my interest...
                          I see thread is opened in English...
                          I see 2 answers in English, but...
                          Someone writes in Dutch or German (i do not know) and ALL post is written on different language that started.
                          Perhaps YOU know Dutch or German, not me. And perhaps not Thread stated knows also.
                          Is so difficult to follow initial Language? What happes if every one writes in his language?
                          Empiezo a estar cansado de esta desconsideración al resto de usuarios del Foro.
                          • BMW F750GS
                            That the problem of this Forum.
                            We used to have a rule that posts should be written in the same language they start in. Unfortunately, everyone here writes however they like.
                            I use DeepL as a browser add-on to translate other languages directly when I highlight text.
                            • RetiredWingMan
                              I use the Chrome browser and turn on translate. Works well.
                              • Lluis Arasanz Lluis Arasanz
                                @Lluis-Arasanz said in Route lines not showing:
                                I have seen multiple posts by you not honoring the same principle I believe.
                                Deepl is your friend, don't lose respect for people in this community please (yes I use deepl too).
                                That being said:
                                @Jörgen said in Route lines not showing:
                                The actual "rule" was dedicated to the BETA categories, and said that posts should preferably be started in English or in Dutch (being the by far biggest group of people at that time) and replied to in the original language or in English. Maybe the amount of German speaking people has caught up by now, that's possible. I can read English and German (and Dutch) pretty well, but must admit that the frequency (and maybe the too elaborate writing style of some) sometimes keeps me from continuing.
                                Personally I would have no problem with the forum being English completely, but that might be a bridge too far for many. In the meantime I scan most foreign messages on interesting keywords, and translate only if my interest is triggered. Don't make too big of a problem about everything 😉
                                Patrick 65
                                Patrick 65
                                Mike Morrill
                                Mike Morrill
                                  2.4k
                                  2.2k
                                • Seizoensafsluitingen
                                • Altitude numbers size
                                  RainerT
                                  RainerT
