  3. [App-Beta] Announcements
  4. Updated beta! 5.0.3 (449)
30 Posts 13 Posters 322 Views 6 Watching
    Perhaps one more request: With wider fingers, gloves, or in bright sunlight, it's sometimes too easy to accidentally hit the logout button.
    Perhaps this could be adjusted as shown in the image; that would certainly be very helpful for all users.
    @Hubert-Thoring you’ve shared the feedback before. Have not changed it in this version and won’t in the next 🙂
    • ConiKost
      ConiKost
      ConiKost
      wrote on last edited by ConiKost
      @Corjan-Meijerink I would like to point a few things about the device management 🙂
      • My iPhone 17 Pro Max is shown as Unknown Device
      • Will be there any option to delete devices? For example, if some device has been sold?
      • On german translation, when opening the device management from settings, the button is called 'Abbrechen' which makes less sense here. 'Zurück' would be a better translation here.
      Shiny!
      • ConiKost ConiKost
        @ConiKost said in Updated beta! 5.0.3 (449):
        Yes, use the red icon on the right behind each device.
        That button backs off from deleting devices from the list, so O think "abbrechen" is not very wrong 😉 . This window is the same one as the one you are forced into when you really need to delete one from the list. "Zurück" in that case is not an option.
          @Corjan-Meijerink said in Updated beta! 5.0.3 (449):
          Sorry, it was just supposed to be a well-intentioned suggestion for honest users, and I thought maybe it was just overlooked... 🤔
          I understand it now, if someone happens to come to "unsubscribe" it should just happen like that, that's how it will certainly go for some times.
          • unfortunate for those who have acquired their license correctly and honestly and like to use it (... then effort is generated)
          • right for those who have not purchased a license properly, for that it is really good 👍 (unsubscribe and OFF and over)
            @Hubert-Thoring but it’s not an unsubscribe?
            It’s just logging out off the app.
            CD130 1 Reply Last reply
              @Corjan-Meijerink Gisteren gebeurde er iets bijzonders na het installeren van deze beta op mijn iPad en iPhone:
              iPhone: via de nieuwe instellingen pagina logde ik mijn iPad uit. (rode knop)
              iPad: app bleef werkend terwijl online op wifi, daarop geforceerd afgesloten en opnieuw gestart. Zonder ook maar ergens op te hoeven drukken was ik weer ingelogd.
              iPhone: Bij mijn apparaten bleef alleen mijn iPhone zichtbaar. Hierop geforceerd afgesloten en app opnieuw gestart. iPhone was vervolgens uitgelogd. Moest daarbij ook de app herstarten omdat er iets was aangepast aan mijn abonnement gaaf die aan. (die melding kwam laatst ook ergens op het forum voorbij.)
              iPad: Gaf vervolgens de melding dat ik teveel apparaten actief had.
              iPhone: Gaf een melding dat rond de 50 routes (mijn bibliotheek is veel groter) werden gesynchroniseerd.
              iPhone: Zag de iPad daarna ook weer gewoon ingelogd... en alles werkte weer...
              Hierop gestopt met rommelen en ben ik gaan mopperen tegen Rob 😉 Van Rob begreep ik dat die rode knop geen uitlog knop is. Wat het dan wel is snap ik ook niet helemaal, maar nu geef jij aan dat dit wel een knop is om uit te loggen. Snap het niet meer 😂
              Hopelijk heb je iets aan bovenstaande.
              @Corjan-Meijerink Yesterday something unusual happened after installing this beta on my iPad and iPhone:
              iPhone: via the new settings page, I logged out of my iPad (red button)
              iPad: the app kept working while online on Wi-Fi, then I force-closed it and restarted. Without having to press anything, I was logged in again.
              iPhone: Under my devices, only my iPhone remained visible. I force-closed it and restarted the app. The iPhone was then logged out. I also had to restart the app because something had been changed with my subscription (that notification recently came up somewhere on the forum as well).
              iPad: Then it displayed a message that I had too many active devices.
              iPhone: Showed a message that around 50 routes (my library is much larger) were being synchronized.
              iPhone: Afterwards, I saw the iPad logged in again… and everything worked again.
              At that point, I stopped messing around and started complaining to Rob 😉 From Rob, I understood that the red button is not a logout button. What it actually is, I don’t quite understand either, but now you’re saying it is a logout button. I don’t get it anymore 😂
              Hopefully the above is helpful.
              • MotoCon
                Guys, the red button takes a device out of the device list, zo you can continue. It does not unsubscribe, it does not long off, it just makes room for your device in a list that may contain 2 devices. You do not need to login on the other devices, nothing bad happens...
                @Hubert-Thoring, those who have acquired their license correctly are unlikely to run into this.
                • Arno 0
                  Arno 0
                  Arno 0
                  I don’t like the chosen red button because for me it means something like exporting or sharing data. Why not chosen for the delete (trash bin) button?
                  • CD130 CD130
                    @CD130 sounds like it works exactly as expected.
                    It does not log out your account but it unlists the device as active. When using the other device it is automatically activated again 🙂
                      In Dutch I would say “afmelden” rather than “uitloggen” but I don’t know if English has this specific contextual distinguish 😄
                      @nick-carthew help? 😛
                      Nick Carthew Jörgen 2 Replies Last reply
                        @Corjan-Meijerink Delist or Exclude would both work as would Deregister and Unlist.
                          @Nick-Carthew amen. Then that’s the better term 🙂
                          • Arno 0 Arno 0
                            @Arno-0 said in Updated beta! 5.0.3 (449):
                            I am not certain putting something in the bin really gives me a better feeling... 😉
                              In German, I would say "Gerät abmelden" to make it more clear. So it is not related to the account and with loggin/ loggout etc. Could work also in other languages.
                                Sorry, I have to ask again because I don't understand the reason 🤔
                                Why are the device - "Log out" also deleted all synchronized routes in this affected device .
                                VG ✋
                                  VG ✋
                                  @Hubert-Thoring because that button is actually “abmelden” as it says 🙂
                                  We were referring to the red icon to unlist a device.
                                  • Marinus van Deudekom
                                    449 in available in the Google store
                                      @Corjan-Meijerink , I knew that, ... 👍
                                      But my question was about what exactly happens when "loging out" in the background in relation to the MRA app installation on the mobile phone?
                                      This means that when "logging out" all synchronized routes are deleted, and what else, all offline maps etc. are also deleted so that the app becomes neutral and is only synchronized again with the account the next time you log in to the device.
                                      It remains unclear at the moment what exactly is deleted when "unsubscribing" and what is not, because the offline cards are probably not deleted during this deregistration.
                                        @Hubert-Thoring only local cached data related to your account are removed when logging off. Which is no issue at all because it’s in the cloud anyway 🙂
                                        Let’s not treat logging off as a weird new feature because it’s there since day one in the app 😉
                                          ConiKost
                                          ConiKost
                                          Arno 0
                                          Arno 0
                                          rpluckengmail.com
                                          rpluckengmail.com
                                            Albert van den Elsen
                                          • Verminkte route op TomTom.
                                            Jacob Waterweg
                                            Jacob Waterweg
                                            LE DIZES Freddy
                                            LE DIZES Freddy
                                          • Probably a me thing
                                            Solo1138
                                            Solo1138
