  3. [Beta] Announcements
  4. New beta! 5.0.3 (447)
94 Posts 21 Posters 711 Views 9 Watching
  • Hubert Thoring Offline
    #81
    I would say every device that has its own installed MRA app on the system is counted. A CP or AA solution as a pure mirroring of the mobile phone display is not counted...
    iPad 9. Gen iOS 26.6.2/ iPhone 16e iOS 26.6.2/ Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
    • Guzzist Guzzist
      I'm a bit irritated, be ause I'm not familiar enough with AA/CP. Until now, I thought that these devices merely "mirror the monitor" of the connected mobile phone (wireless or wired). So, Corjan's last answer faces into my understanding.
      But currently @Con-Hennekens replies to me, I should not call such devices as "mirror".
      So, does this mean, on some AA/CP models apps can be installed?
      Or in other words: is my understanding correct - does the new rule only counts a device, if "Navigation Next" is really installed on a device?
      Corjan Meijerink Online
      #82
      @Guzzist yes, the app only counts installed devices. Meaning it’s an Android or iOS device.
      Not calling Android Auto / CarPlay a mirroring device is preferred because it does not actually mirror your screen. It’s a whole different interface with its own rules / features. Whereas a mirroring device just copies the screen of your phone with all those features.
      But not very relevant for the discussion.
      No, CP / AA does not count as a device 🙂
      • Guzzist Guzzist
        Rob Verhoeff Offline
        • Guzzist Guzzist
          b0hd1 Offline
          b0hd1 Offline
          wrote on last edited by b0hd1
          #84
          @Guzzist Si se le puede instalar aplicaciones no es un CP/AA, es un dispositivo Android o Apple.
          Aunque también hay aparatos mixtos CP/AA + android (linkifun MT23, por ejemplo).
          En todo caso la regla es fácil. Si instalas, suma como equipo adicional, si no instalas, no.
          Saludos.
          • https://t.me/MRa_by_b0hd1
          • YouTube: @demco17
          • Guzzist Guzzist
            Marinus van Deudekom Offline
            @Guzzist AA Needs your phone in erachter of that device. No phone no possibility to use MRA. That’s why AA is not seen as an extra device so doesn’t country in the number Off devices for your MRA account
              @paul69 what @Hubert-Thoring says is correct.
              CarPlay / Android Auto is not an extra device.
              paul69 Offline
              paul69 Offline
              @Corjan-Meijerink said in New beta! 5.0.3 (447):
              thanks both for the reply and clarification
              K1600 GTL
              Oukitel RT3
              iPhone 13 Pro, carpuride 702b
              • Guzzist Guzzist
                @Guzzist said in New beta! 5.0.3 (447):
                Yes that's exactly what it is. AA/CP devices usually do not run the software, your phone runs it, to be displayed on on your screen. I hate the term "mirror" for it, since, the GUI is not identical to the native app's GUI, and comes with some restrictions. But the app is indeed run by the phone.
                To make it even more complex, SOME (mostly car) head units actually do run Android natively and you can install apps on it. In those cases, of course, it is seen as an independant device running the MRA app. but if you need to connect your phone in order to use AA or CP, it is NOT an independant device, and you can use as many AA/CP devices from your phone as you like.
                  Die Übernahme des Modell Namen des „iPhone 16e“ erfolgt nicht, es funktioniert nur bei dem iPad und iPhone Xr. Das iPhone 16e (26.2.1) und iPad (26.2.) das iPad werde ich auf Update (26.2.1) bringen, danach noch einmal testen 👋
                  Das 16e ist das hier gelistet „Unknown device“ Gerät ….
                  Gibt es einen Grund dafür ?
                  @Hubert-Thoring said in New beta! 5.0.3 (447):
                  Fixed in the definitive version.
                  Was an issue specific for this device.
                  • Travellexxie Travellexxie referenced this topic on
                  • Albert van den Elsen Offline
                    Ik ben op mijn Laptop, Iphone 15 en Carpe Iter aangemeld maar ondanks dat laat de iPhone maar één apparaat zien. Dat is begrijpelijk want alleen de iPhone heeft toegang tot testflight en de CI is Android en heeft geen Testflight optie.
                    HEt valt me op dat niet de juiste versie van de iPhone IOS getoond.
                    Deze staat op 26.2.1 terwijl 26.3 geïnstalleerd is.
                    iPhone 15,
                    Carpuride W702 Pro
                    Sena 20S EVO headset
                    Harley Davidson Road King M8
                      @Albert-van-den-Elsen klinkt verder prima. Over die versie zou ik me vooral geen zorgen maken.
                      • AWDC LAO AWDC LAO
                        Een groepsabonnement zou natuurlijk welkom zijn.
                        AWDC LAO Offline
                        AWDC LAO Offline
                        De helft van mijn leden van mijn groep hebben onder een Basisabonnement genomen en Navigation next, het zijn voornamelijk volgers en geen planners. En ze besparen op hardware toestellenzoals TomTomRider 450-550, Chigee 5 & 6, Garmin, XT1, BMW navigator 4, 5 en 6 .... wat ook een zeer grote kost is.
                        • AWDC LAO AWDC LAO
                          @AWDC-LAO Mensen die alleen een Navigation Next Abo hebben, zijn geen basis users meer. Ze hebben in de webinterface wel meer rechten, vergelijkbaar met Silver. maw geen beperking meer mbt aantal routes. Maar je hebt niet de vergelijking tools etc van Gold
                            @Marinus-van-Deudekom, met een Navigation Next abonnement heb je echt niet met Silver vergelijkbare features. Wel krijg je in je basic abonnement de beschikking over de HERE kaart, omdat Navigation dat ook gebruikt.
                              Ik had duidelijker moeten zijn. Vergelijkbaar is zeker niet alle rechten van Silver maar wel meer dan basic. BV geen Max aantal routes
                              • 4
                              • 5
                              ConiKost
                              ConiKost
                              Vince Hyde
                              Vince Hyde
                              Cristiano Repetti
                              Cristiano Repetti
                              Rob de Weijze
                              Rob de Weijze
                              • Welke instelling
                                1.1k
                                Thomas Schäfer
                                Thomas Schäfer
                              • opslaan naar plantomtom
                                chris 18
                                chris 18
                              • Seizoen sluitingen wegen
                                PAT62
                                PAT62
                              • Rejoining routes
                              • App loopt vast
                                Sytze van der Laan
                                Sytze van der Laan
