  4. Waypoints - copy request
13 Posts 7 Posters 4.5k Views 4 Watching
  • Wallace Shackleton
    Wallace Shackleton
    Wallace Shackleton
    Scenario.
    Planning a multi day trip. The route needs to be changed. A new stopping point is found but that new point needs to be the starting point for the following day.
    Being able to copy and paste the new waypoint into a new route would be a great help.
    The work around of copy the lat/long then go into the new route, paste it and rebuild the waypoint information.
    Con Hennekens Guzzist Travellexxie 3 Replies Last reply
    • paul69
      hi @Wallace-Shackleton
      it is always more efficient and good practice to start the following day with waypoint #1 a few hundred metres from your actual start point. the next app will still direct you to that point of the route which will then continue in the normal manner.
      K1600 GTL
      Oukitel RT3
      iPhone 13 Pro, carpuride 702b
      • Wallace Shackleton Wallace Shackleton
        Scenario.
        @Wallace-Shackleton, I make it a habit to put the hotels in my favorites list. That way you can easily pick them up in any route.
          Exactly, place your last WP under favourites and it is available next day as startpoint.
            Scenario.
            @Wallace-Shackleton not sure, if I understand correctly. But I agree: if you simply want to copy a routepoint from one route into another route - you may do it by copying the lat/long detail and search by it in the other route.
            But then, you get only this location for a (new) routepoint. But all the information from the first routepoint -
            • routepoint name
            • routepoint additional information
            • possible pictures
              will not be copied. And that's the matter, or?
              Scenario.
              @Wallace-Shackleton you can do it the other way around: if you are planning a multi day trip, start to plan it as a whole route, because you know where you are going to. So set the end of each day as a waypoint and the engine is quickly enough to plan for you rapidlyy (I wouldn't suggest it with Baseccamp 🙈).
              If you have done this, open the toolkit, choose "split" and voila, your end of day 1 is the start of day 2, etc.
              Guzzist 1 Reply Last reply
              • Travellexxie Travellexxie
                @Lex.Kloet.RX yes - but this is only possible, if you want to have the last routepoint from first day also as starting point in the second day.
                But if you simply want to copy "any" routepoint into "any" other route - then the "splitting idea" is not a solution 😉
                • Guzzist Guzzist
                  @Guzzist that's the second sentence of what the topicstarter wrote 😉 "A new stopping point is found but that new point needs to be the starting point for the following day."
                    @Lex.Kloet.RX yes, I know - he mentioned first and second route...
                    But he wrote also about "copy" and copy by using the lat/long info. And this can be used everywhere.
                    I will not hijack this topic; may I should open another thread...
                      @Jörgen said in Waypoints - copy request:
                      Learned something again... because the favorites are always available.
                      But only the basic text under 1.) is taken over, where the street name is written, etc.
                      The note is not saved in the favorite, just as an image is not transferred...
                      • paul69
                        Sometimes using your finish waypoint as the next day’s starting point can cause problems, I’ve learned this the hard way.
                        For example,
                        your final waypoint might be set on the road outside a hotel. That road could be one-way, while the hotel car park is actually behind the building, meaning you have to drive past the hotel and enter from another street.
                        If you then start the next day from the carpark using that same end waypoint as your starting point, the navigation may send you all the way around the one-way system just to get back to waypoint #1 outside the hotel.
                        Hope that makes sense and helps someone avoid the same issue 👍
                        K1600 GTL
                        Oukitel RT3
                          A starting point should always be about 200-400m from the hotel in the direction of travel and can be reached safely 😉🍀
                          paul69 1 Reply Last reply
                            @Hubert-Thoring said in Waypoints - copy request:
                            yes, i wrote words to that effect in post #2 of this thread.
                            K1600 GTL
                            Oukitel RT3
                            Wallace Shackleton
                            Wallace Shackleton
                            • Live tracking
                              Jeff Causey
                              Jeff Causey
                            • Routing issue
                            • Bar Buttons problems
                              Gert Jan Bastiaans
                              Gert Jan Bastiaans
                            • Compare providers error
                            • Overlapping routes
                              peha
                              peha
