  3. [App-Beta] Announcements
  4. New beta! 5.0.3 (447)
94 Posts 21 Posters 711 Views 9 Watching
  • ConiKost ConiKost
    @Corjan-Meijerink said in New beta! 5.0.3 (447):
    @ConiKost thanks for sharing your thoughts! 3 devices is also allowed but not stimulated so then you indeed need to logoff one using the presented interface.
    But from what I understood, If I would do that more often with a test device, woudn't I risk again my account due device-chance? Or does that mean, once I logged in on a device, its fingerprint is added to my account device list and I am save? Only to be allowed to login at the same time on two devices would be fine for me.
    #51
    @ConiKost fully correct! (the last and positive part)
    • Lluis Arasanz
      Hi @Corjan, Only for identify scenarios...
      License limit of 2 devices, affects also Web Planner on computer?
      I understand that this limit is for mobile devices which are user for navigation (Next license), even that in a mobile device affects also Integrated MRA RoutePlanner.
      Best Regards!!
      • BMW F750GS
      • Lluis Arasanz Lluis Arasanz
        Best Regards!!
        @Lluis-Arasanz, web planner in a browser is excluded from the restrictions. The restrictions are for the complete MRA app, so it includes also the in-app planner.
          @Con-Hennekens good...
          This is what I suppose, and how license must be applied. My post is only to clarify others that thinks web planner on Computer is also affected.
          • BMW F750GS
            @Lluis-Arasanz, exactly. And also web-logins from a tablet are not affecting the device management.
              Is a device which is logged in but switched off (like my tablet or navigation phone). Also count as a logged in device?
              Why the question. I installed the app on 3 devices but only my daily phone is always switched on.
                @M.-Schrijver, having a device switched on or off does not influence the fact that you are using it with the MRA app. But of course you can remove any switched off device from the list on the phone you are trying to use when the message about device management appears.
                  so what I read, I am not affected. iPhone, iPad and Android tablet should work seamless. The old Samsung I use sometimes for testing is outdated anyway.
                  And what I understand, web access is not affected anyway.
                    Sorry to ask again, after reading three pages, it is still not clear. Are my guess right?
                      @Jörgen, yes, however the third device your are starting the app on, will show the list of devices in which you can decide to remove one. The removal has no real impact, the removed device will be added to the list again when you start the app on it, if then it is the third device again, you can remove one of the others. If you put a fourth device in the mix, things will become a problem. You have the beta, just try it, to get comfortable with it. Just don't press "abmelden", then you will need to resync all your routes.
                      • Bouke Ent
                        hopelijk krijg ik nu niet tig meldingen. op een aantal tablets geinstalleerd zowel ios als android en op aantal telefoons ios en android. hopelijk word bij upgrade van app status gelijk offline gemaakt zodat ik alleen met 2 items kan inloggen op app. we gaan het ervaren. op android trouwens beta en op ios gewoon.
                          Hi everyone! 👋
                          It is time for a lovely new beta.
                          Not the most exciting update for you but definitely for us 😉
                          Device management
                          This is the core aspect of this update.
                          Unfortunately we are seeing a massive amount of account sharing going on.
                          At MyRoute-app we try our hardest every single day to be customer oriented and keeping our prices low. As of this year our base prices for subscriptions had to be increased (for the first time since 2021) and because of new contracts with our suppliers we also have to implement a device limit per subscription.
                          As we now pay per active phone we cannot (ignorantly) allow users to use our app on an unlimited amount of phones. As of this update we allow a maximum of 2 devices to be used at the same time. When exceeding this limit (3 devices) you will be presented a beautiful interface in which you can logoff another device. After doing so, you can use your current phone again 😃
                          Some important notes:
                          • Excessively switching between multiple phones will lead to an automatic warning
                          • Attempts to use way too many devices (4) at once will lead to an automatic block
                          Our terms & conditions will be updated appropriately.
                          Simply put: times of sharing your account with big groups of friends or your club are over, sharing with your partner / personal use on a few devices is still allowed.
                          Note for beta testers: being a beta testers does not mean you are allowed to share your account but if for (proven) testing you wish to use more devices, simply contact our support department.
                          SSO fixed
                          Signing into the app using a SSO authentication method (such as Apple or Google) was broken. Luckily this has now been fixed! 🎉
                          Link and file opening
                          Opening links and files with the app has always been possible.
                          In this update the stability of these features has been improved to ensure it works as expected when the app is in any state (such as terminated / in the background / opened).
                          Minor fixes and stability improvements
                          Many small issues that are not relevant to mention here have been fixed.
                          Also we fixed a few errors that would result in route calculations failing.
                          Finally a few critical CarPlay / Android Auto errors have been solved and we added a bit more logging to investigate some persistent issues a few users have.
                          What's next
                          Slowly but surely we are transitioning to a more focused dedication on the website.
                          In the next update 5.1 we will:
                          • Aim for solving all stability issues CarPlay and Android Auto
                          • Add highly requested features to CarPlay and Android Auto
                          • Major technical internal updates
                          Cheers,
                          Corjan
                          @Corjan-Meijerink Did Some testing of the new Beta.
                          I saw that the spinning map issue is not yet solved. In both navigating a route and the free drive mode there’s still a problem. When I comes to a complete stop the map turns in the north direction and the position marker moves direction north. If I was on a road with separated lanes the position marker will move to the lane that is heading north. The north direction of the dynamic mode camera view will then turn witch will be actually not north. I haven’t seen that in the previous versions. So the spin of the map is actually turning the map facing north.
                          Another thing that I’ve noticed was when the notification of a speed camera pops up and your speed is over the Max speed the pop-up turns red, great feature. Maybe it was already like this but I haven’t noticed it before
                            #63
                            Ein Vorschlag: s. Bild, so war das da gemeint, denn ich finden den Hinweis das beim abmelden Dinge gelöscht werden schon sehr wichtig !
                            Vorschlag:
                            Original, hier ist die Auswahl zwischen "Meine Geräte" und "Abmelden" zu dicht beieinander. Ein Hinweis das was gelöscht wird fehlt auch !
                            • Bouke Ent Bouke Ent
                              @Bouke-Ent said in New beta! 5.0.3 (447):
                              Je heb een limiet van drie apparaten waarvan er twee tegelijkertijd ingelogd kunnen zijn. Wissel jij vaker van toestel dan van sokken? Pas als je met het derde apparaat wilt navigeren dan krijg je op dat apparaat de melding om je af te melden van één van je andere apparaten. En dat vergt bijna geen extra handelingen...
                              Hubert Thoring Bouke Ent 2 Replies Last reply
                              • Guzzist
                                @Corjan-Meijerink may I ask the question: what is the background for simultaneously use of 2, but not 3 devices?
                                And may it is misunderstood: if someone is using 2 mobile phones for navigation at same time - and uses a tablet at night in hotel room - this is not counted as third device? I believe the first 2 devices are used for navigation during the ride. And the third device is just in use in the hotel at evening - while the app at the 2 navigation devices is switched off. Then there are not 3 devices in count, or? I mean in the hotel, no one is going to navigate...?
                                  #66
                                  @Rob-Verhoeff said in New beta! 5.0.3 (447):
                                  Der Begriff „Abmelden“ ist irreführend, denn mit der einen Funktion „s.Bild“ Symbol rechts wie ein „Ausgang“ wird nicht abgemeldet sondern nur das Gerät ausgetragen und damit auf das 3. Gerät gewechselt…
                                  Wenn man dann den Status abfragt ist die App an diesem Gerät freigegeben!!!
                                  The term "log out" is misleading, because with the one function "s.picture" symbol on the right like an "output" is not logged out but only the device is logged out and thus on the 3rd Device changed...
                                  If you then ask for the status, the app is released on this device!!!
                                  Rob Verhoeff Cristiano Repetti 2 Replies Last reply
                                    @Hubert-Thoring said in New beta! 5.0.3 (447):
                                    And that's where translating Dutch to English to German goes wrong! I didn't use the term "Log out" in Dutch!!! So thank you for your comment that is not saying anything.
                                    • Lluis Arasanz
                                      #68
                                      La verdad, lo que no entenderé nunca es no respetar el idioma original del post.
                                      No todo el mundo habla alemán o neerlandés o, como en mi caso, castellano.
                                      Tan difícil es mantener el mismo idioma?
                                      The truth is, what I will never understand is not respecting the original language of the post.
                                      Not everyone speaks German or Dutch or, as in my case, Spanish.
                                      Is it so difficult to maintain the same language?
                                      Die Wahrheit ist, dass ich nie verstehen werde, dass die Originalsprache des Beitrags nicht respektiert wird.
                                      Nicht jeder spricht Deutsch oder Niederländisch oder, wie in meinem Fall, Spanisch.
                                      Ist es so schwierig, die gleiche Sprache beizubehalten?
                                      De waarheid is dat ik nooit zal begrijpen dat ik de oorspronkelijke taal van de post niet respecteer.
                                      Niet iedereen spreekt Duits of Nederlands of, zoals in mijn geval, Spaans.
                                      Is het zo moeilijk om dezelfde taal te behouden?
                                      • BMW F750GS
                                        @Rob-Verhoeff ik ga terug naar max 2. maar ik heb nog een paar oude telefoons en tablets waar mra nog op staat. ik ga ze wel eerst deinstalleren omdat ze in theorie al ingelogd zijn. ik gebruikte voor kleine aanpassingen van routes een tablet met app in planner omdat menu op klein scherm in app iets handiger is dan webplanner in chrome. daar springen menus nog wel eens naar vreemde plaatsen en touch is minder handig.
                                        optie blijft dan in en uitloggen..... maar dat is niet mijn voorkeur.
                                        op telefoon route aanpassen is me iets te klein.
                                        Bouke
                                          Bouke
                                          Houd er rekening mee dat je met max 3 apparaten mag werken! Als je inlogt met de 4e dan blokkeert je account 😉
                                          • 4
                                          • 5
                                          Albert van den Elsen
                                          ConiKost
                                          ConiKost
                                          Òscar
                                          Òscar
                                          Vince Hyde
                                          Vince Hyde
                                          Cristiano Repetti
                                          Cristiano Repetti
                                          Rob de Weijze
                                          Rob de Weijze
                                          • Verminkte route op TomTom.
                                            Jacob Waterweg
                                            Jacob Waterweg
                                            LE DIZES Freddy
                                            LE DIZES Freddy
                                          • Probably a me thing
                                            Solo1138
                                            Solo1138
