  3. Broken road (in map only)
13 Posts 7 Posters 3.3k Views 3 Watching
  • Juan Carlos Garcia Ojeda
    I dont know if this was posted yet. I searched for it but couldn't find it.
    I have a route where a road appears incomplete on the map (HERE), and the planner makes me backtrack many kilometers to go to the same place and continue the route. If I try it with another map, it works fine, but when I transfer it to the Garmin XT2, since it has the same map, it recalculates and makes the same error. Is there any way to "cross" that point in a straight line?
    I've attached an image.
    Thank you very much.
    • LE DIZES Freddy
      LE DIZES Freddy
      LE DIZES Freddy
      Bonsoir
      vous cliquez sur le WP4 la féntre s'ouvre , vous cliquez sur les 3 points à droite (plus d'option)
      une deuxième ligne apparait vous cliquez sur le deuxième icone en partant de la droite ( voiture 4X4) et ça forcera la route vers le point 3
      nomko 1 Reply Last reply
      • Juan Carlos Garcia Ojeda Juan Carlos Garcia Ojeda
        @Juan-Carlos-Garcia-Ojeda Open the shapingpoint context-menu for point 4. Klick the Landrover-button (blue circle) and a strait line wil connect the points 3 and 4.
          Thank you so much for your reply.
          I already did this and it works in the route planner, but when I import it into the GPS, it does the same thing again and looks for another route (150km) to get to point four.
          Marinus van Deudekom Rob Verhoeff Mzokk 3 Replies Last reply
            @Juan-Carlos-Garcia-Ojeda if it’s a map error, report it to Here. Like that it will be a solution for both MRA and your XT
              Yes, I'll have to report it. I think it would be a good idea to be able to connect the points on the GPS as well.
              Thanks
                @Juan-Carlos-Garcia-Ojeda That’s a bit dumb… 🫣 that’s what you get for only half-reading the text. Of course my solution doesn’t work if you export to another device. Better read more carefully next time…😉
                  Thanks
                  @Juan-Carlos-Garcia-Ojeda, it would, but that's up to Garmin I suppose
                    @Juan-Carlos-Garcia-Ojeda I've had this before on here maps in Spain (Picos)
                    You can fix it in Basecamp by designating two waypoints as "Direct" across the gap.
                    Change the point type to direct and calculate the route. Keep the rest with the motorcycling profile. I've tried this out and the route executes. If you make the points "don't alert" you don't notice the route has a patch/repair. Hopefully this is useful.
                      Hi
                      I did it in Basecamp and it seems to work
                      Thank for answer.
                        Bonsoir
                        Banned
                        @LE-DIZES-Freddy said in Broken road (in map only):
                        Bonsoir
                        @LE-DIZES-Freddy Please next time if you want to help respond in English. Not everybody can read or understand French. Thanks!
                        • nomko
                          Banned
                          @Juan-Carlos-Garcia-Ojeda Did you report it to HERE?
                          Link: https://mapfeedback.here.com/#/report
                          If you report, you can add a screenshot from Google Maps to show that that the road is not interrupted at that location.
                          • nomko nomko
                            Bonsoir
                            LE DIZES Freddy
                            LE DIZES Freddy
                            LE DIZES Freddy
                            @Nomko-Nomden hello You clic on th rignt button of your mouse and choose "translate" it so easy
                            LE DIZES Freddy
                            LE DIZES Freddy
                              TomOnTour
                              TomOnTour
                            • Pay for beta?
                            • Live payments enabled
                              Brett Bartick
                              Brett Bartick
                            • Maps Michelin
                              LE DIZES Freddy
                              LE DIZES Freddy
                              1.1k
                              TomOnTour
                              TomOnTour
                            • import in beta-mra failed
