  4. opencycle issues
opencycle issues
a7 groningen
8 Posts 4 Posters 1.6k Views 2 Watching
  • Mylleundefined Offline
    Mylle
    when using the opencycle map in order to create a bike route I encounter very often a problem in the wense that the "HERE" map blocks the route...
    I try to use the F3 bike highway beteween Velten and Herent (part of the Leuven-Brussels F3), and encounter each time this issue. Strange that teh cycle map is using the HERE map basis for calculations. I have had this problem so many times that for me this opencycle map is useless. If you want more examples, let me know
    regards,
    Daniel
    • Mylleundefined Mylle
      regards,
      Daniel
      Nick Carthewundefined Online
      @Mylle said in opencycle issues:
      Leuven-Brussels F3
      Are you using the planning map from OpenStreetMap and do you have bicycle selected as transport mode?
        Mylle
        Yes,
        When I force a routing point on the F3 Bike Highway by drag and drop I get the following:
        Then, when I place two routing points on the F3:
        When hitting "help me ...":
          Yes,
          @Mylle Just add more route points and you can cycle on F3.
            Mylle
            ??? i wil try that, but isn’t the message ( the last one ) not misleading in this case?
            Danny
              Danny
              @Mylle I don’t know, I couldn’t read it.
              • Rolf Engelsmanundefined Offline
                Rolf Engelsman
                Same problem here. Opencycle map doesn’t allow certain cycle paths.
                • Rolf Engelsmanundefined Rolf Engelsman
                  @Rolf-Engelsman, change your base map to OpenSTreetMap, and your transport method to bicycle:
                  Rolf Engelsman
                  Mylleundefined
                  Mylle
                  • Is It Me?
                    Herman Veldhuizenundefined
                    1.4k
                  • Tablet screen lock
                  • Onbekende fout, 3 problemen
                  • Xavy desde España/ Xavy from Spain
                    Lluis Arasanzundefined
