  3. Routes can not be uploaded
38 Posts 13 Posters 17.7k Views 5 Watching
  • Virtua
    Virtua
    Virtua
    I have the same problem as well................
    I can load old routes, but the routes created today are saying "An error occurred while connecting with the server"
    Android. Its been like it all day...............
    • HABVEN aka MrMRA
      Delete the Navigation app and mobile app, then open the routes in MRA planner and rental the app again.
      • daz 2
        daz 2
        daz 2
        wrote on last edited by daz 2
        #27
        yes I agree with Matt I deleted navigation app and which I can only assume my route app then opened routes on the my route app not only on the android phone but also on the web app then reinstalled navigation app but still the same error "An error occurred while connecting to the server" also can say I did this both on my home wifi and on mobile data with same result ..hope this helps.. Dave
        Kudee 1 Reply Last reply
        • daz 2 daz 2
          Kudee
          Kudee
          Kudee
          @daz-2 Same here, Reinstalled the App and rebooted the Mobile, same situation. No connection to the Server
          • Catalina
            Catalina
            Catalina
            Hi all. Last Sunday (23 may) we had a database problem with saving the routes. This database problem started around 10 in the morning till afternoon. All routes created in between that time are sadly corrupted.
            There are a few steps that will help us gain more information:
            • Can you open other routes that were not made / edited on 23 may?
            • Can you create new routes successfully?
            • Could you try to duplicate the corrupted route and see if it works?
            Kudee Stelios Poulman 2 Replies Last reply
            • Catalina Catalina
              Kudee
              Kudee
              Kudee
              @Catalina said in Routes can not be uploaded:
              Can you open other routes that were not made / edited on 23 may? NO! No connection to Server!
              Can you create new routes successfully? Can you open other routes that were not made / edited on 23 may? NO! No connection to Server!
              Can you create new routes successfully? NO! No connection to Server!
              Could you try to duplicate the corrupted route and see if it works? Could you try to duplicate the corrupted route and see if it works? NO! No connection to Server!
              Guys, I hope you have Backups and are able to fix that. Please!
              • Catalina Catalina
                Stelios Poulman
                Stelios Poulman
                Stelios Poulman
                @Catalina I have the same problem on my Android phone. Some (not all) older routes will load on the Navigator App. No routes created after Sunday will load, including one I created just now to test.
                Very frustrating!
                • daz 2
                  daz 2
                  daz 2
                  #32
                  Hi Catalina , In my case I can open any maps that were created before 23rd may, I have made two routes open to public. "test route 2" which was made prior to 23rd of may and this opened in in my route planner app and on the web page and in navigation app with no problem .I then made a copy of this route named " test route 2 copy" which opened in in my route planner app and on the web page with no issues, but when I try to open i the navigation app it produces the error "An error occurred while connecting with the server.". But here's the important difference although the original "test route 2 " opened in navigation app when I tried to reopen it again brings up the same error, now the only changes I made were to rename title of the original route... I hope this helps Dave.(daz)
                  • daz 2 daz 2
                    Hi @daz-2. Can you share (copy and paste route url from address bar) the two public routes on here please.
                    • daz 2
                      daz 2
                      daz 2
                      #34
                      no problem Nick 1 .this is the original made a few days ago only change i made was to the title https://www.myrouteapp.com/route/open/4463915
                      2.this is the copy no alteration https://www.myrouteapp.com/route/open/4641024
                      None of these will open in the navigation app anymore after changing the title of the original .. Hope this helps Dave(daz)
                      Nick Carthew 2 Replies Last reply
                      • daz 2 daz 2
                        @daz-2 Thanks Dave. I'm busy at the moment but I will check them out later today.
                        • daz 2 daz 2
                          #36
                          @daz-2 said in Routes can not be uploaded:
                          Hi Dave. I downloaded both routes to my iPhone 11 and both opened normally in MRA Navigation. I noted that you had used OpenStreetMap to plan your route. MRA Nav uses the Here map.
                          1F2F1891-84BB-4CB5-8049-AD98C763A0D2.png F54B984B-6C72-4CE0-BEA8-F96BD7C59225.png
                          • Nick Carthew
                            @Matt-Flaming Yes you have and I have now checked this.
                            • daz 2
                              daz 2
                              daz 2
                              hi Nick thanks for you help, If you look around the forum you will see many post's saying the issue does no exist on ios only on android but there has been a notice posted on the main web page that there is indeed a problem for android users . thanks for your help Dave .
                              Spili
                              Spili
                              Reinhard-32
                              Reinhard-32
                              Kudee
                              Kudee
                              Michel van Hagen MRA-Founder
                              daz 2
                              daz 2
                              Stelios Poulman
                              Stelios Poulman
                              Catalina
                              Catalina
                              Virtua
                              Virtua
                              Paulette Silvius
                              Paulette Silvius
                              Michael Janker
                              Michael Janker
                                Rene van Maanen
                                Rene van Maanen
                              • One crash today
                                Mosimann
                                Mosimann
