  4. Thork racing t865x
Thork racing t865x
18 Posts 7 Posters 6.3k Views 4 Watching
  • Mils Mils
    Hallo,
    Is er iemand de Thork Racing t865x tablet al uitgebreid gebruikt?
    Marinus van Deudekom heeft er een mooie blog over gemaakt maar ik was eigenlijk nieuwsgierig naar zijn ervaring na bijna één jaar...
    Welke remote gebruiken jullie en waarom?
    Thx,
    @Mils I have been using the T865-X for two years now, because after decades of use, Garmin devices had left me very disappointed outside Germany.
    Even the Garmin devices in the Tread series were no better (they are Garmin, after all) and far too expensive. That's why I chose DMD and not the more heavy Carpe Iter.
    Why the T865-X and not the T665? Because the small screen is harder to read when driving off-road.
    Why an Android device? Because I can use my preferred apps at the same time.
    For my journeys, I create explicitly planned routes with MRA Route Planner and navigate using the MyRoute app.
    This works really well.
    For off-road sections (like ACT, TET) in between, I use tracks I have received and navigate with them using the DMD2 app (because their own off-road maps are much better!). In special cases/regions, I may also use OsmAnd or LocusMap.
    I use the same GPX file in several apps for this purpose simultaneously.
    And for rallyes – where roadbooks are handed out – the T865-X also serves me well. Because I don't need a second device, I can display the roadbooks as PDF files on the T865-X too.
    To do this, I use the Remote-2 controller from DMD as a remote controller on the handlebars.
    Why not Silverfox or others? Because the 4-way button of Silverfox cannot be operated properly in shaking off-road ride! The hard 2-way switch on the DMD controller can be operated much more precisely with your thumb on the handlebars – to zoom in, or to scroll through the lines of the roadbook, line by line. And controller has a prepared cable connection, which makes it more reliablec (but can also operated by Bluetooth)!
    The only drawback at present is the lack of integration of this controller into the MyRoute app.
    For example, the 4-way button must be used to zoom in on the map in the MyRoute app. With all other apps, this can be done with the 2-way switch.
    However, I am in communication with Corjan and the DMD developer to find a solution...
    • Andre Trudeau Andre Trudeau
      @Mils Pretty sure that any remote hardwired to the DMD-865X would not work with anything other than the apps supported by the "manage" app (Formerly the Button App) since it appears that the remote goes thru that app to send commands if wired. Silverfox uses the same DMD app once wired.
      @Andre-Trudeau said in Thork racing t865x:
      @Mils Pretty ...supported by the "manage" app (Formerly the Button App)...
      Please what do you mean with "manage app"? Which app exactly is this? I only know the "Button App". But by this, I can't setup the functions of the DMD Remote-2 controller properly to MyRoute-App.
      • Mils Mils
        @Marinus-van-Deudekom
        Ik heb gelezen dat je de Silverfox via bluetooth moet verbinden en MRA niet goe werkt als je de kabel gebruikt.
        Zou dit zo ook met de originele controler van Thork Racing zijn of zou met deze wel alle functies werken?
        @Mils ik gebruik de remote aangesloten via de kabel voor de 12 volt voeding maar op uitdrukkelijk advies van SilverFox het gebruik via Bluetooth. Bij DMD zeggen ze dat het via de kabel zou moeten maar ik heb proefondervindelijk vastgesteld dat via Bluetooth probleemloos werkt. Ik heb voor SilverFox gekozen vanwege de kleine bevestigings houder. Die van DMD war3n voor mijn situatie veel te groot
        Mils 1 Reply Last reply
          Mils
          Mils
          Mils
          Ok,nice!
          Kan Cor-Jan softwarematig geen aanpassing doen zodat de Silverfox volledig compatibel is bedraad?
          Zou pachtig zijn omdat dit qua opstelling bij de meeste motoren de beste optie is door de smalle benodigde montage ruimte.
          • Mils Mils
            Ok,nice!
            @Mils dat ligt niet aan Corjan maar aan DMD. Ik heb geprobeerd daar de deur open te krijgen maar kwam terecht in de discussie het ligt niet aan ons maar aan SilverFox. Een daar zeggen ze precies het tegenovergestelde.
            De redenering van SilverFox vind ik persoonlijk meer argumenten bevatten een aangezien het via Bluetooth zonder problemen werkt, zag ik het nut van verder discussiëren niet meer zitten.
            De ondersteuning vanuit SilverFox is echt super goed.
            • Mils
              Mils
              Mils
              Jammer toch, aangezien bekabeld mij stabieler lijkt. DMD zal hun eigen controler willen verkopen zeker... Zoals gezegd is de Silverfox beter voor veel motoren door de plaatsbesparende smalle opbouw.
              • Guzzist
                Ja, de bevestiging van de Silvervox is smaller, waardoor knipperlichten en andere schakelaars nog steeds goed bereikbaar zijn.
                Voor offroad-rijden is de Remote-2-controller van DMD echter geschikter
                Als ik een navigatiesysteem van een offroad-specialist gebruik, wil ik ook de bekabelde afstandsbediening van deze specialist gebruiken. Daarom mijn aanbeveling hiervoor – in de hoop dat deze ook binnenkort in de myRoute-app wordt geïntegreerd.
                • Guzzist Guzzist
                  Mils
                  Mils
                  Mils
                  @Guzzist Waarom is de DMD controler "beter"geschikt voor offroad?
                  Hoop met je mee dat de DMD controler ook binnenkort in de myRoute-app wordt geïntegreerd. Zou sterke move zijn!
                  Guzzist 1 Reply Last reply
                  • Arjan de Vries
                    Arjan de Vries
                    Arjan de Vries
                    Ik heb hem nu ook al een tijdje in combi met de Silverfox C1.
                    Bevalt me uitstekend. Zelfs zo goed dat toen ik de Triumph Tiger inruilde ik het tablet gewoon op mijn Harley Road King heb gemonteerd, incl. C1. In die combi al vele km gereden met MRA als hoofd navigatie. Het tablet is buiten het motorrijden ook te gebruiken als leesboek of om te netflixen 😉
                    Ik heb er wel een data only abbo inzitten (6 euro pm) om te kijken of alles vlekkelozer verloopt dan zonder data. Ik wil mijn ophone er niet aan hangen als hotspot. Kortom erg tevreden tot nu toe alhoewel ik toch ook wel weer naar mijn telefoon neig op het stuur (kleiner).
                    • Mils Mils
                      @Mils said in Thork racing t865x:
                      ...... omdat bij de DMD Remote-2-controller de 2-wegschakelaar (voor zoom en voor regelverplaatsing in het roadbook) zeer robuust is en van metaal is gemaakt. En goed met de duim kan worden bediend zonder verwarring - vooral bij zwaar offroad-gebruik.
                      De 4-wegschakelaars van Silverfox en anderen zijn minder veilig te bedienen tijdens zwaar offroad-gebruik en kunnen gemakkelijker beschadigd raken...
                      • Mils
                        Mils
                        Mils
                        Hoi @Corjan-Meijerink, Kan de DMD controler (bekabeld) in de myRoute-app worden geïntegreerd?
                        Thx.
                        • martin-phogel.de
                          martin-phogel.de
                          martin-phogel.de
                          Ik gebruik al geruime tijd de apparaten van Thork Racing (T865 - T665 - T865X) in combinatie met de RemotekOne-afstandsbediening, die perfect samenwerkt met MRA.
                          De stroomvoorziening werkt op een knoopcelbatterij en de verbinding via Bluetooth is zeer stabiel, dus je hebt geen gedoe met kabels. Ik gebruik de RemotekOne op twee motorfietsen; je moet een kleine veiligheidsschroef losdraaien en dan kun je hem eenvoudig omsteken. Dat duurt maar een minuut.
                          In tegenstelling tot veel andere afstandsbedieningen heeft de RemotekOne geen joystick, maar uitsluitend 6 knoppen voor alle functies, die ook met dikke handschoenen aan heel veilig te bedienen zijn.
                          En bovendien is hij ook nog eens goedkoper dan de andere...
                          Ik zou de RemotekOne altijd weer kopen.
                          Vertaald met DeepL.com (gratis versie)
                          martin-phogel.de
                          martin-phogel.de
                          Arjan de Vries
                          Arjan de Vries
                          GHPA
                          GHPA
                          Andre Trudeau
                          Andre Trudeau
                          Mils
                          Mils
                          • Strange translation
                          • Crazy routing
                          • Foutmelding In MRA Next
                          • Kort voorstellen
