  4. Error message 'Could not calculate route' when one is shown on the map #bug
13 Posts 5 Posters 2.3k Views 3 Watching
  • Andy Wundefined Offline
    Andy W
    Steps to reproduce:
    • Open the app
    • Select MRA RoutePlanner
    • Select Search icon
    • Select Favourites
    • Select a favourite
    • Select 'Add to route' (to add as point 1)
    • Select Favourites
    • Select a another favourite (different to the first one)
    • Select 'Add to route' (to add as point 2)
    A route is calculated at this point and shown on the map.
    • Scroll down and select Navigate
    The error message is displayed and Navigation does not start:
    If you go back to 'Route information', enter a route name and save it, Navigation can then start OK. It seems as though a route must have a name before Navigation can start. If that is by design, then a better message would be helpful.
    Andy
    Rob Verhoeffundefined Nick Carthewundefined 2 Replies Last reply
    • Andy Wundefined Andy W
      Steps to reproduce:
      • Open the app
      • Select Favourites
      • Select Favourites
      Andy
      Rob Verhoeffundefined Offline
      @Andy-W I followd your exact steps. I can navigate the desired route...
        Curious to know if this is consistent for you. Cannot reproduce it either.
        A name only need to be added when saving the route which is not required for navigating it directly.
        Andy Wundefined 1 Reply Last reply
          Steps to reproduce:
          • Open the app
          • Select Favourites
          • Select Favourites
          Andy
          @Andy-W Followed your instructions for two routes, could not replicate your experience. Both routes navigate without the need to enter a name.
            Andy W
            @Corjan-Meijerink said in Error message 'Could not calculate route' when one is shown on the map #bug:
            @Corjan-Meijerink Yes, it's consistent for me. I tried using different points from other search filters such as Parking and Restaurant just in case it was related to something in the Favourites list but I still get the same error.
            I created a short video which is on a OneDrive account so you can see it.
            https://1drv.ms/v/c/aad78959cdc75fa0/IQBfgrU0f0SdQL1ImYwIFO3jAW8HAfLMK_Agw8lxyt8z8bE?e=IskIdc
            After the error message, I step back in the application and get a confirmation message about discarding the route so it has clearly calculated one (and it shows on the map too).
            I'm using a Samsung Galaxy S23 and don't have another phone or tablet I could test this on.
            Andy
              Andy
              @Andy-W Thanks for your reply.
              Could you create a support ticket with the logs of the app attached?
              These logs can be retrieved by long pressing the version number at the bottom of the account page in the app (where all the settings are).
              What travelmode have you got selected?
              Does changing this influence the outcome?
                Travellexxieundefined Offline
                The only thing I can think of, is that your actual position is too far away from any calculable road.
                  Andy W
                  That has been done.
                  I had Motorcycle selected. I have tried different travelmodes and still get the same error.
                  Andy
                    Andy W
                    @Lex.Kloet.RX said in Error message 'Could not calculate route' when one is shown on the map #bug:
                    If I just select one favourite I can navigate to it so I don't think it's my current location.
                    Andy
                      That has been done.
                      Andy
                      @Andy-W Thanks for creating the ticket, I've read it.
                      I will fix the issue πŸ˜‰
                      It seems to be caused by the fact that you have enabled the "navigate routes as track" option. Try turning this off and retry your steps.
                      Working on a solution now πŸ™‚
                        Andy W
                        @Corjan-Meijerink Thanks for the update. I've turned off the "navigate routes as track" option and it works OK.
                        Andy
                          Andy
                          @Andy-W Thanks for confirming πŸ˜ƒ
                          From my side I can let you know that the issue is fixed.
                          So when the next update is available, this will work even when "navigate routes as track" is enabled.
                            Andy W
                            @Corjan-Meijerink That's great. Thanks for the quick response.
                            Andy Wundefined
                            Andy W
                            • Tussenstop/routepunt toevoegen tijdens navigeren
                              Leike Lodiersundefined
                            • Gas Stations not displaying
                              Lenny Oundefined
                              Lenny O
                            • Layout My Routes
                              Alida Veenstraundefined
                              Alida Veenstra
                            • Font for the distance to the next turn to smal
                            • Geen routelijn
                            • Statement on map spinning
                            • 'Toon route' optie eenvoudiger beschikbaar maken
                            • Routekleur
