  4. Free ride not possible with new update
9 Posts 5 Posters 1.7k Views 4 Watching
  • stuart marrittundefined Offline
    stuart marritt
    When in landscape mode with the new update you can't see the full map using free ride all you see is the menu and no way to hide it.
      Correct, a dedicated free drive mode will be added later.
      For now you could long press the navigate button on a route to enable a sort of free drive 🙂
      This is default for walking / cycling.
      Note (hint): a route could just contain a random single waypoint
        stuart marritt
        Thanks for that 👍
          Guzzistundefined Offline
          @Corjan-Meijerink please what do you mean with "Navigation Button" at home screen?
          I tried with an extra created route with only one route point in. By starting the navigation, I got the message "no route could be calculated".
          If I switch before this to use offline maps - than it worked.
          • Jörgenundefined Offline
            @Guzzist see this video from me: https://www.facebook.com/groups/myrouteapp.de/posts/2277583002713813/?__cft__[0]=AZVWNuTt1vlpY9FbXU6jWR9YxxYRZPdEdWx2fjhp_oq0tQVSgHJbOzThTKOrb-Ejq_WwoEIOhLTZojR4NXupttyNJerPpDdk8hHuZDF5SPqR746WTYhTzK4OdNn0d_zZiedGfBqOdgIP4tZTOv7OS0hSTSZ5RA9cVcxqN4dGrdC1vAGK5MTXqyCTjLbqvA144x3Dt-UHC9kfSTg0MT_bVGlX&__tn__=%2CO%2CP-R
            • Guzzistundefined Guzzist
              @Guzzist, if you long-press the Navigate button when you start a route, it starts in "follow-the-line" mode. When you make a route with only one waypoint (eg your home address or whatever), you can start that route without a line in follow the line mode, and see the full map. It's a work-around until a real free-drive mode is available.
              @Jörgen, that's a private group. If you want to share a video, please use a public option.
              • Jörgenundefined Jörgen
                @Jörgen thank you verry much for the linked video. But I'm sorry, I don't have Facebook.
                @Con-Hennekens thank you verry much for the hint. I now understand, it's not beginning on the home screen, but by opening a route.
                In meantime I figured out:
                • if I create an extra created route with only one route point in (may my home base), and starting the navigation, I will get the message "no route could be calculated". So it doesn't work.
                • if I select this extra created route, and open it for edit, and switch to use offline maps just before start navigation - then it works
                • if I select this extra created route, and longpress button "Navigate" - then it workes too (in both modes: offline and online maps)
                • if I'm at map on home screen and longpress icon "position indicator" on map - then I get the submenue with buttons "Navigate" and others. And if I press this button, I get a sub-submenue with button "Start". If I press this - it worked too - just responds: "reached your destination". But it worked then also as freeride mode.
                As mentioned before, it's a workaround. For a real freeride mode, min. current speed limitations must be populated.
                But Corjan has promised for later... 😊
                Jörgenundefined Con Hennekensundefined 2 Replies Last reply
                  @Guzzist said in Free ride not possible with new update:
                  Exactly, and that's what it's designed for.
                  Here the video: https://youtu.be/1RL0z0LxDew
                    Is indeed, a route with a single waypoint makes no route, so it cannot be calculated, but following the map can be don by the long-press instead. It is what it is for now 😉
                    stuart marritt
                    • Tussenstop/routepunt toevoegen tijdens navigeren
                      Leike Lodiersundefined
                    • Gas Stations not displaying
                      Lenny Oundefined
                      Lenny O
                    • Layout My Routes
                      Alida Veenstraundefined
                      Alida Veenstra
                    • Font for the distance to the next turn to smal
                    • Geen routelijn
                    • Statement on map spinning
                    • 'Toon route' optie eenvoudiger beschikbaar maken
                    • Routekleur
