  4. Safety Tutor
Safety Tutor
20 Posts 10 Posters 7.7k Views 4 Watching
    @Marco-Strani, I suspect you are talking about trajectory speed control?
    Marco Strani
    Marco Strani
    Marco Strani
    @Con-Hennekens said in Safety Tutor:
    I'm talking about a a fairly common system on highways in Italy based on calculating the average speed over a stretch of road of a few kilometers. If the calculated average speed is higher than the limit, you'll be fined.
    Travellexxie Con Hennekens martin-phogel.de 3 Replies Last reply
      @Marco-Strani If you go to Navigation settings > Audio > Speed warnings and select All you will hear a warning when you go faster than the speed limit of the road that you are travelling on.
      Marco Strani
      Marco Strani
      Marco Strani
      @Nick-Carthew said in Safety Tutor:
      I know the safest way of driving is to respect the limits 😉 but, as there is a way to know where speed cams are, I was wondering is there's a similar notification for this further speed check system
      • Marco Strani Marco Strani
        @Marco-Strani why do you need an app, to drive safely? 🤷🏻
        Marco Strani 1 Reply Last reply
        • Travellexxie Travellexxie
          Marco Strani
          Marco Strani
          Marco Strani
          @Lex.Kloet.RX why do navigation apps notify speedcam?
            @Marco-Strani I use neither, because in Germany (where I live) it is not permitted and I am used to ride without any warning. So, I drive in any vehicle (cabrio, camper, motorcycle) according to what the road signs indicate. They are there with a purpose.
              @Marco-Strani said in Safety Tutor:
              Yeah, that's called trajectory speed cam. As far as I know they are mentioned in the app, as far as they are known in the HERE map data.
                martin-phogel.de
                martin-phogel.de
                martin-phogel.de
                @Marco-Strani
                I was in the Czech Republic a few months ago, where the tutor system (or something similar?) is also used, and I received a warning about it in MRA.
                So it's quite possible that you'll receive these warnings in Italy too.
                • Marco Strani
                  Marco Strani
                  Marco Strani
                  thanks Martin, did you receive a warning only when entering the monitored section or during the whole section, or were you warned also when exiting it?
                    martin-phogel.de
                    martin-phogel.de
                    martin-phogel.de
                    @Marco-Strani
                    If I remember correctly, there was a warning at the beginning of the section and then a display during the section (remaining distance) and the measured average speed. But I'm not entirely sure anymore. Can't you just try it out?
                    • Alex reds
                      Alex reds
                      Alex reds
                      Hi Marco, with the MRA Navigation app you can be alerted about your speed compared to the speed limit, and you can also get warnings about speed cameras. However, the app doesn’t provide notifications for average speed check systems (tutors) — especially the new ones recently installed on some Italian highways.
                      Currently, only a few navigation apps warn you when you enter a tutor zone, but they offer far fewer navigation features overall. So, it’s better to stay cautious — driving a bit slower lets you enjoy the trip and the scenery much more.
                      • Alex reds Alex reds
                        @Alex-reds The app does warn you when you are in an ‘Average speed zone’.
                        richtea999 1 Reply Last reply
                          In Norway, the warning system has always worked very well!
                          • Erdna
                            Erdna
                            Erdna
                            I remember several occasions in Italy, when I was warned about Tutor zones. As often, Here map quality is the "issue". If nobody notifies about speed traps, etc., it won´t be available in map data.
                            • Marco Strani
                              Marco Strani
                              Marco Strani
                              wrote on last edited by Marco Strani
                              thanks, I will check at the first opportunity
                              • Marco Strani
                                Marco Strani
                                Marco Strani
                                Yesterday I had the chance to check how the app behaves in this case.
                                When approaching a Tutor zone, the app informs about it starting from 300 meters then, when entering the zone, a message similar to "Average speed check" stays on the screen (you can close it). Finally, when approaching the end of the zone, it informs starting from 800 meters, and decrementing the distance until the end, with a message similar to "Average speed check for XXX meters". The popup does not close automatically once you exit the zone and needs to be explicitly closed.
                                While this is positively answering my initial question, I think that it would be better to inform earlier the start than the end of the zones: I'm generally not interested in driving faster than allowed but in being sure I am not doing it expecially when I am monitored
                                  Being very pedantic:
                                  The app does warn you when it has the data to know you are in an ‘Average speed zone’.
                                  It's very useful, but it can be out of date, have errors, etc, and it's up to you to keep your eyes peeled and ride to the road signs.
                                  Cameras are unforgiving. Except in the UK where you have a 10% + 1 mph leeway (as of right now - Nov 2025):
                                  https://www.met.police.uk/foi-ai/metropolitan-police/disclosure-2024/april-2024/speed-cameras-thresholds/
                                  Erdna
                                  Erdna
                                  martin-phogel.de
                                  martin-phogel.de
                                  Tony 13
                                  Tony 13
                                  Alex reds
                                  Alex reds
                                  Marco Strani
                                  Marco Strani
                                  • Strange translation
                                  • Crazy routing
                                  • Foutmelding In MRA Next
                                  • Kort voorstellen
