  3. [App-Beta] Announcements
  4. Update 5.0 - Updated beta version
20 Posts 12 Posters 216 Views 8 Watching
    Good morning, there is something strange with the start menu on iPhone and iPad (with Routeplanner, Roundtour, Target, etc.)
    The menu moves up to the edge by itself, step by step, and then falls back down, then moves up again. This happens continuously. It is particularly noticeable in landscape mode more than in portrait.
    Video from iPad: https://youtu.be/_XdN5WJyMWg
    Why is it still not possible to move the menu down at least one third of the screen?
    To be honest, the daily greeting is a nice idea, but it just takes up space. In my opinion, it would be enough to have it when you start the app.
      I can also confirm, with both devices, the iPhone and iPad, somehow irregular light swimming movement of the menu on the display
      • Dave J 0
        @Corjan-Meijerink Quick question. I like the new feature of ‘Free drive for regular / scenic routes is not promoted as such but can be launched by long pressing the navigate button’ but is this available in CarPlay when selected on the iPhone? This does not appear to show for me. Will this be enabled downstream if not available just yet?
        Ducati Multistrada V4 Rally
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        Google Pixel 6 Pro
        • Dave J 0 Dave J 0
          @Dave-J-0 no, that isn’t yet available yet on CP / AA.
          That is the ambition when we add a dedicated free drive mode in the app now too. The architectural foundation of CarPlay / Android Auto requires a route to be loaded at almost all times.
          We still even need to investigate the possibilities of what a free drive can show at all. That said, a map in CP / AA with a route visible and no navigation will be possible for sure 😉
            @Dave-J-0 :
            I only understood that with the longer pressing now through your hint here 😂, thank you, that's how it is with the E to D translation in the great languages, sometimes you don't understand it correctly. ✅
            Das mit dem länger drücken, habe ich erst jetzt verstanden durch deinen Hinweis hier 😂, danke, so ist das mit der E zu D Übersetzung in den tollen Sprachen , manchmal versteht man es nicht richtig. ✅
              Great function with the longer press of the navigation, is like the follow mode if you have no route you can the hotel as an example route with two WP systems, start the route press the navigation longer and already you have the maps as the basis of the road to follow.
              Hope that's exactly how it works ..! Unfortunately, the weather does not allow the test on the motorcycle at the moment. VG
              Tolle Funktion mit dem länger drücken der Navigation , ist wie der Folge Modus wenn man keine Route hat kann man das Hotel als Beispiel Route mit zwei WP anlagen, die Route starten die Navigation länger drücken und schon hat man die Karten als Basis der Strasse zu folgen.
              Hoffe genau so geht das ..! Das Wetter lässt das testen am Motorrad im Moment leider nicht zu. VG
                Is the Android version already available?
                  @Jörgen: Bij mij ook nog steeds niet
                  No, Still not found in Android Playstore!
                    I also was hoping the Android version was available. Then i could test the improved autozoom functionality on this rainy day.
                      Still no Android version available! Been waiting for 3 days now.
                      • Lluis Arasanz
                        Andorid version available in Play Store!!! come on!!!
                        • BMW F750GS
                          Yes. Updated to 5.0. 0 420. Let's try it out on Thursday.
                          • Hide warnings on the map
                          • Map Layers
                            Martin White
                            Martin White
                            Michael 2v
                            Michael 2v
                          • Bollard trouble
