  3. [App] Announcements
  4. Android only update! (4.4.1)
28 Posts 10 Posters 15.6k Views 2 Watching
  • ginogino ginogino
    @Marinus-van-Deudekom said in Android only update! (4.4.1):
    @ginogino maybe you can put in a service ticket and include the log file.
    Thanks, I didn't know how to extract the log file. I'll open a ticket reporting the error.
    @ginogino, to be honest, if the app skipped to 9 and you still followed the original route to 8, there really is no error. Having no turn by turn instructions is what happens if you disable recalculation and leave the blue line. Of course you can ask why the app skipped 8. Could it be an accidental touch on the phone's display?
    ginogino 1 Reply Last reply
      ginogino
      ginogino
      ginogino
      @Con-Hennekens said in Android only update! (4.4.1):
      There was no problem because I knew perfectly well the road I had selected when I planned the motorcycle tour, but instead I worry when I have to take roads that I don't know well or that I'm doing for the first time.
        @ginogino said in Android only update! (4.4.1):
        I had chosen to get to waypoint 9 via waypoint 8, I took the right direction for me, not for the app, which would have taken me to waypoint 8, then to waypoint 9, and then on.
        Do you mean that you've kept on going on the route that you planned or did you like @Con-Hennekens stated diviate a bit in Rezzoaglio.
        If I look at your route there should not have been any reason why the app would try to get you to skipp shapingpoint 8. No roadblocks or seasonal blocking.
        I don't know why you would disable recalculation.
        As I look at you route I would have put in more shapingpoints to prevent unexpected deviation of your route.
        I would certainly put shapingpoint 7 a bit more in the direction of 8
        Now it's almost on the crossing where things went wrong for you.
        Have you enabled the white original route in your settings. That way you can see when you're about to deviate from your route.
        JP d
        JP d
        JP d
        wrote on last edited by JP d
        Exactly always ensure your waypoints are a good distance from a junction, intersection, roundabout or adjacent road. If you use the (expand) add waypoints option you have to check every single one.
        I've also had MRA take me left onto a single track lane shortcut even though my friend's MRA was showing straight ahead which was the correct way.
        I didn't have (show original route) turned on which would have helped but previously the white line (show original route) didn't follow the road correctly so I turned it off. Looks like it has been fixed now but I'll find out for sure on my trip on the 20th.
        ginogino BMcG 2 Replies Last reply
        • JP d JP d
          ginogino
          ginogino
          ginogino
          @JP-d said in Android only update! (4.4.1):
          I used to use the "expand" function, until I realized it was introducing a lot of errors, and I haven't used it since.
          • ginogino ginogino
            @ginogino I would not use the expand waypoint function but simply add a couple manually
            • JP d JP d
              not sure if it is the same issue you are refering to but just so you know before your trip there is still an issue with the "original route" line not exactly "following the road" if you are navigating in offline mode
              there are a couple of workarounds, details are here https://forum.myrouteapp.com/post/66551
              JP d 1 Reply Last reply
              • BMcG BMcG
                JP d
                JP d
                JP d
                #22
                @Brian-McG You're right mate! My mistake I had forgotten to turn WiFi and Data off 🤦🏻‍♂️.
                I navigate with my old phone (no SIM) using offline maps.
                So you're saying if I open a route offline and then click on the (pen) 🖋️ edit route icon, then go to (Menu) scroll down and select (Navigate) the white line original route would follow the blue navigation line correctly?
                Thanks for your reply 🍻
                BMcG 1 Reply Last reply
                • JP d JP d
                  @JP-d that sounds about right
                  you can test it at home & see the white line not fitting correctly
                  I think it is easier to see on longer routes with more points as somewhere MRA are limiting the number of track points for the track calculation, so longer routes deviate away more from the road
                  the other work around is start the navigation while your old phone is still connected to the hotel wifi then the white line is calculated correctly as it is online & MRA allows more points for the track caclulation
                  then go offline & close the wifi
                  • Banshees
                    Banshees
                    Banshees
                    The latest update made the bouton barely distinguished when riding, on Android Auto.
                    I know where is the zoom and the POI option (to remove one waypoint while driving). But i can't see correctly the bouton.
                    -oOOo-()-oOOo---------------------------------------------
                    Banshees
                    MRA Gold & Nav - Life
                    --------------Oooo-----------------------------------------
                    oooO ( )
                    _)
                    • Banshees Banshees
                      @Banshees maybe you can share a screenshot
                      • Thomas Neumeyer
                        Thomas Neumeyer
                        Thomas Neumeyer
                        Hi, just out of curiosity. When is the next big update planned? Any teaser available?
                        Thomas
                          Thomas
                          @Thomas-Neumeyer it’s in beta since yesterday!
                          Expected release end of the month.
                          • Thomas Neumeyer
                            Thomas Neumeyer
                            Thomas Neumeyer
                            Cool, thank you Corjan.
                            JP d
                            JP d
                            Thomas Neumeyer
                            Thomas Neumeyer
                            ginogino
                            ginogino
                            Banshees
                            Banshees
                            • Online map settings
                              MartinW
                              MartinW
                            • Real-time traffic
                              Òscar
                              Òscar
                              Andy Nicholson
                              Andy Nicholson
                            • HERE map not calibrated
                              MartinW
                              MartinW
                            • Myrouteappstay
                              Bé Jeuring
                              Bé Jeuring
                            • Navigatie met DMD tablet
                            • Show on the maps's button
