  3. [App] Announcements
  4. Android only update! (4.4.1)
28 Posts 10 Posters 15.6k Views 2 Watching
    @ginogino, My guess is that in Rezzoaglio you wandered off route and had the app recalculate a few times, after which it skips WP8, thinking it is unreachable. It then goes to WP9, for which the the red line is exactly the right way. In your example, what is the distance between Waypoints 7, 8 and 9? Maybe a bit too big. Skipping then can have a big impact too. You would have easily corrected that, by long-pressing WP8, which forces to recalculate from there.
    ginogino
    ginogino
    ginogino
    @Con-Hennekens said in Android only update! (4.4.1):
    In Rezzoaglio, I didn't deviate from the route because when the app pointed me in the wrong direction, leading to waypoint 9 and skipping waypoint 8, knowing full well the route I had chosen to get to waypoint 9 via waypoint 8, I took the right direction for me, not for the app, which would have taken me to waypoint 8, then to waypoint 9, and then on.
    I keep route recalculation disabled because there are no warnings (like "make a U-turn") if you take the wrong turn, and if the route is recalculated without me realizing it, I risk (as has already happened several times) taking too much distance or not taking the route I intended.
    • ginogino ginogino
      @ginogino said in Android only update! (4.4.1):
      Do you mean that you've kept on going on the route that you planned or did you like @Con-Hennekens stated diviate a bit in Rezzoaglio.
      If I look at your route there should not have been any reason why the app would try to get you to skipp shapingpoint 8. No roadblocks or seasonal blocking.
      I don't know why you would disable recalculation.
      As I look at you route I would have put in more shapingpoints to prevent unexpected deviation of your route.
      I would certainly put shapingpoint 7 a bit more in the direction of 8
      Now it's almost on the crossing where things went wrong for you.
      Have you enabled the white original route in your settings. That way you can see when you're about to deviate from your route.
      ginogino JP d 2 Replies Last reply
        ginogino
        ginogino
        ginogino
        Yes, I continued on the route I had planned, which turned white, but the information about the next turns disappeared, I was not alone and I was unable to stop to take a photo of the display.
        In the options I don't seem to have found the possibility to change the color of the roads.
        • ginogino ginogino
          @ginogino maybe you can put in a service ticket and include the log file. By pressing long on the version number.
          What you experienced shouldn't have happened
          ginogino 1 Reply Last reply
          • richtea999
            Still one minor layout problem left, Corjan - the sync screen.
            Probably not worth a release, but worth a fix:
              ginogino
              ginogino
              ginogino
              @Marinus-van-Deudekom said in Android only update! (4.4.1):
              Thanks, I didn't know how to extract the log file. I'll open a ticket reporting the error.
              • ginogino ginogino
                @ginogino, to be honest, if the app skipped to 9 and you still followed the original route to 8, there really is no error. Having no turn by turn instructions is what happens if you disable recalculation and leave the blue line. Of course you can ask why the app skipped 8. Could it be an accidental touch on the phone's display?
                  ginogino
                  ginogino
                  ginogino
                  There was no problem because I knew perfectly well the road I had selected when I planned the motorcycle tour, but instead I worry when I have to take roads that I don't know well or that I'm doing for the first time.
                    JP d
                    JP d
                    JP d
                    wrote on last edited by JP d
                    Exactly always ensure your waypoints are a good distance from a junction, intersection, roundabout or adjacent road. If you use the (expand) add waypoints option you have to check every single one.
                    I've also had MRA take me left onto a single track lane shortcut even though my friend's MRA was showing straight ahead which was the correct way.
                    I didn't have (show original route) turned on which would have helped but previously the white line (show original route) didn't follow the road correctly so I turned it off. Looks like it has been fixed now but I'll find out for sure on my trip on the 20th.
                    ginogino BMcG 2 Replies Last reply
                    • JP d JP d
                      ginogino
                      ginogino
                      ginogino
                      @JP-d said in Android only update! (4.4.1):
                      I used to use the "expand" function, until I realized it was introducing a lot of errors, and I haven't used it since.
                      • ginogino ginogino
                        @ginogino I would not use the expand waypoint function but simply add a couple manually
                        • JP d JP d
                          not sure if it is the same issue you are refering to but just so you know before your trip there is still an issue with the "original route" line not exactly "following the road" if you are navigating in offline mode
                          there are a couple of workarounds, details are here https://forum.myrouteapp.com/post/66551
                          JP d 1 Reply Last reply
                          • BMcG BMcG
                            JP d
                            JP d
                            JP d
                            #22
                            @Brian-McG You're right mate! My mistake I had forgotten to turn WiFi and Data off 🤦🏻‍♂️.
                            I navigate with my old phone (no SIM) using offline maps.
                            So you're saying if I open a route offline and then click on the (pen) 🖋️ edit route icon, then go to (Menu) scroll down and select (Navigate) the white line original route would follow the blue navigation line correctly?
                            Thanks for your reply 🍻
                            BMcG 1 Reply Last reply
                            • JP d JP d
                              @JP-d that sounds about right
                              you can test it at home & see the white line not fitting correctly
                              I think it is easier to see on longer routes with more points as somewhere MRA are limiting the number of track points for the track calculation, so longer routes deviate away more from the road
                              the other work around is start the navigation while your old phone is still connected to the hotel wifi then the white line is calculated correctly as it is online & MRA allows more points for the track caclulation
                              then go offline & close the wifi
                              • Banshees
                                Banshees
                                Banshees
                                The latest update made the bouton barely distinguished when riding, on Android Auto.
                                I know where is the zoom and the POI option (to remove one waypoint while driving). But i can't see correctly the bouton.
                                -oOOo-()-oOOo---------------------------------------------
                                Banshees
                                MRA Gold & Nav - Life
                                --------------Oooo-----------------------------------------
                                oooO ( )
                                _)
                                • Banshees Banshees
                                  @Banshees maybe you can share a screenshot
                                  • Thomas Neumeyer
                                    Thomas Neumeyer
                                    Thomas Neumeyer
                                    Hi, just out of curiosity. When is the next big update planned? Any teaser available?
                                    Thomas
                                      Thomas
                                      @Thomas-Neumeyer it’s in beta since yesterday!
                                      Expected release end of the month.
                                      • Thomas Neumeyer
                                        Thomas Neumeyer
                                        Thomas Neumeyer
                                        Cool, thank you Corjan.
                                        JP d
                                        JP d
                                        Thomas Neumeyer
                                        Thomas Neumeyer
                                        ginogino
                                        ginogino
                                        Banshees
                                        Banshees
                                        • Online map settings
                                          MartinW
                                          MartinW
                                        • Real-time traffic
                                          Òscar
                                          Òscar
                                          Andy Nicholson
                                          Andy Nicholson
                                        • HERE map not calibrated
                                          MartinW
                                          MartinW
                                        • Myrouteappstay
                                          Bé Jeuring
                                          Bé Jeuring
                                        • Navigatie met DMD tablet
                                        • Show on the maps's button
