  3. How to Keep Routes Consistent When Exporting to Garmin Zumo XT?
16 Posts 10 Posters 6.4k Views 4 Watching
  • nevatikundefined nevatik
    Hey Folks,
    I am pretty much still a novice at using MyRoute-app, and it has been tremendously helpful for planning my motorbike trips! I use a Garmin Zumo XT for navigation, but I've been having a small problem when I export my planned routes onto the device. I sometimes have lost a couple of waypoints or the route has slightly changed.
    I have even tried using either GPX version 1.1, GPX version 1.2 and I still cannot get 100% consistency. So I’m hoping to hear from other users of the Zumo XT - what is the best export format or method to have the routes just as I planned in MyRoute-app?
    I usually spend 90% of my time working on cloud projects (in fact, I just returned from Azure training in Hyderabad),sounds intresting right,😁 however, riding is my weekend passion and I would like to develop to improve on route planning and GPS syncing.
    Thanks in advance for any tips - I would truly appreciate your thoughts and experiences!
    nevatik
    Mzokkundefined Offline
    @nevatik Just to distil that a bit.
    Using the XT I now do four things that I wouldn't have necessarily done with older Garmin Units I use/have used.
    1. I put a shaping point on every road I want to be on and use more shaping points than I previously would have if planning routes in basecamp or increasingly MRA routeplanner
    2. Always make a track and display the track and the route on the device so that I can spot any deviation(s).
    3. Have recalculation on prompted rather than automatic and use it sparingly
    4. Any route I'm using gets saved as an "Active Route" to avoid any issues with repeated u-turns if I have used recalculation at some point in the route.
      Hey Folks,
      nevatik
      Travellexxieundefined Offline
      @nevatik I export the 1.2GPX version, make the track visible on the map in a nice color (anything but purple), set recalculating off and here you go. If you get lost (are off route) DO NOT PANIC!!!! 😄 but drive reLexed ✌ to the visible track/route. If there is a deviation, just follow it, because it will lead you to your planned route/track. And as soon as you are on the route again, (bike)life goes on 😉
      Guzzistundefined Sandor Vethundefined 2 Replies Last reply
        Guzzistundefined Offline
        since I'm using MyRoute-App, I don't use any longer Garmin XT. But if I remember correctly, then gpx 1.1 file format is supposed to be used for Garmin XT. The gpx 1.2 file format is supposed to be used for Garmin XT2 (and Tread series).
        If you mix it up, result may be trouble with Shaping Points and Via Points on Sat Nav after transmitting.
        • Guzzistundefined Guzzist
          @Guzzist That is not correct. the 1.2 format can be used on the XT. If you use the 1.2 format make shure that there are a couple of Viapoints in the route
            @Marinus-van-Deudekom thank you for correction. But I did not wrote, it's not allowed/ not possible to use gpx 1.2. for transmission to Garmin XT. Technically you can - but there is a reason why we have the two different formats...
            And XT (as the older one) is working verry different to the newer ones like XT2 and Tread 😉
              @Guzzist The 1.2 format is one that isonly possible in MRA and made special for the use of Garmin Devices
                Hey Folks,
                nevatik
                Steve Jarrellundefined Offline
                Steve Jarrell
                @nevatik All very good advice given here. The XT can drive you crazy at first. Here's what I do that gives me very consistent results. Some of this has been stated already.
                1. When planning online I use the HERE maps as it seems to give the most consistent results. Understand that when you import a route into the XT it WILL recalculate the route based on its settings (avoidances, faster vs shortest, etc.) I turn off the avoidances and select fastest vs shortest. I also use the GPX 1.1 route / track / poi format.
                2. Put in enough shaping points so that the route is as unambiguous as possible. Be generous with them in areas where there are different ways to get from point a to point b.
                3. As others have stated, when the route is imported the track is imported as well. Go to your tracks and make the track that matches the route visible, then when you pull up the route any deviations will be obvious. Play with the track's width and color to make it obvious when you're viewing it overlaid with the route.
                4. Another very quick check to see if the XT's route matches your planned route in the planner is simply bring it up in the planner, look at the total distance, then bring it up on the XT and check the distance there as well. They should be VERY close. If not, check the route vs the track on the XT, make the necessary adjustments in the online planner, then delete the route and track from the XT and import them again. After doing this a few times you'll figure out what to look for (where to put your shaping points) and it will become a lot easier. I just planned a 3 week trip that I'm starting on tomorrow with my brother that includes 19 days of riding, and I only had 1 route that I had to modify and that was because of something really dumb that I had done leaving out some obviously needed shaping points.
                5. The other very important thing (to me) that I'll mention is that once you have the route roughly laid out with the shaping points and via points, bring up the waypoint list in the online planner, select the first waypoint, hit the zoom button, ensure that it's exactly where you want it, move it if necessary, then click the right arrow to advance to the next shaping or via point, adjust as necessary, and continue through the entire route looking for any adjustments that are necessary. Move the shaping or via points away from any intersections that may cause confusion.
                This can be annoying and frustrating at first, but with a little practice you'll figure out what the XT is doing and you'll be able to force it to do exactly what you want it to do!
                Steve
                Steve Jarrell
                Western North Carolina US
                2025 BMW R1200GS
                2025 Can-Am Spyder
                DMD T865-X 8" Tablet
                Garmin XT3
                • Mike Luca 0undefined Offline
                  Mike Luca 0
                  I got tired of playing with 1.1/1.2 and resorted to exporting to XT using GPX 1.0. Seems to keep the fidelity of the route I planned and includes all of the waypoints and viapoints where I put them.
                  I keep the XT around as my 'belt and suspenders' approach. If my phone pukes, I have a dedicated satnav to fall back on. Just as long as I don't have to open Basecamp.
                  AlanMundefined 1 Reply Last reply
                  • Mike Luca 0undefined Mike Luca 0
                    AlanMundefined Offline
                    AlanM
                    @Mike-Luca-0
                    Mike, I have spent hours trying to get XT to copy a MR route accurately.
                    The tracks aways work but convert to trip just will not follow.
                    Tried saving in 1.0 on an old route and it worked first time.
                    Thanks for the tip.
                    AlanM
                      I have never had one problem with the 1.2 export to my XT. Recalculation set off, track visible.
                      • Boštjan Kreutzundefined Offline
                        Boštjan Kreutz
                        I am Zumo XT user since few years, but just recently became MRA user (I bought Gold membership). In general MRA is exactly what I needed for as how I do routes.
                        I do route planning on Windows Chrome webpage and minor adjustments on Chrome browser on android tablet (shortcut as an app to have full screen) that I take with me on longer few days trips. I then use andorid MRA app on my phone to export as version 1.1 and open with Garmin Drive, then bluetooth to export to Zumo XT. It works.
                        As someone suggested, Jheath's in Zumo forum is a must-read.
                        Also you have to have MRA gold membership because you want to use HERE maps.
                        You have to understand the difference between VIA (MRA = hand) and SHAPPING (MRA = tear) points, also to know that adding a waypoint for a city is not just search of city in the search bar, but to add waypoint directly to the road you want to drive by in that city... and use quite a lot of waypoints for a trip. And to have similar settings (avoid hightways, etc.) with MRA and Garmin XT...
                        A good tip is also about starting point... It should be a like 50 or 100 m in front of your actual start point so that you surely drive through it.
                        I also noticed that Zumo XT only show limited characters of route name in a Trip Planner. But if I name the route without spaces, I get to see longer names in Zumo XT, so it is better for organizing...
                        I am still learning, but so far... everything as planned 🙂
                          Sandor Vethundefined Offline
                          Sandor Veth
                          @Lex.Kloet.RX Hi Lex, This can be a good suggestion. However what to do when you already drove 100 km and you accidently shutdown your active route? How do you the start the route again. In my opinion there are only three options Start, End or Nearest. And if so, due the lack of shaping points, it will always bring you through a direct route to the nearest point. So then you missing the fun. Or are there other options that i am not aware of?
                          • Sandor Vethundefined Sandor Veth
                            @Sandor-Veth when you want to restart you have to be ON the route and then you will be brought to the next waypoint following the route not a direct line. It has been a while, but I think it is "End".
                            Sandor Vethundefined 1 Reply Last reply
                              Sandor Veth
                              @Lex.Kloet.RX Thanks
                              • Mzokkundefined Mzokk referenced this topic on
                              Steve Jarrell
                              Mzokkundefined
                              Boštjan Kreutz
                              Mike Luca 0
                              Sandor Veth
                              AlanMundefined
                              AlanM
                              nevatikundefined
                              nevatik
                                Carl Leeundefined
                                Carl Lee
                                6.4k
                                RetiredWingManundefined
                                Fran Sundefined
                                Fran S
                              • New update 5.2.1
                              • Problems route planning on Ipad
                              • Track vs Route
                                Roger Needham 0undefined
                                Roger Needham 0
