  4. POI Editor and converter
9 Posts 4 Posters 2.1k Views 2 Watching
  • BertMundefined Offline
    After starting with Excel to convert POI I have changed to Java script in Google Sheets.
    The main reason is that I do not have Excel on my home computer, but have a google account.
    pre is that I can convert the POI data everywhere when there is a computer available, downside is that you need a Google account.
    After some playing around and some help from my new friend Chatgpt I have managed to do the following in Google sheets:
    • Import and export KML and GPX files.
      Import is done from a folder Named "Import" in Google Drive.
      Export can be done to Google Drive and downloaded.
      (Import from the computer gave some issues and unstability due to the restrictions of Google to import files
      into the server side, so I removed this function.)
    • Geocode the sheet with name, address, city and country with the help of Google.
      • Geocode for the Garmin navi, Google MyMaps etc with different fields
        (Google only fills in the field known to the coordinates, so sometimes not all the field are inserted.)
      • Geocode for MRA in the Name field of the GPX, as MRA only imports this field.:
        Brackets can be inserted after the name and the address in inserted between the brackets.
        The color of the address can be changed for better visibility in the Sheet.
    Geocoding can be done on a single field or on multiple fields.
    • Check the POI in Google Maps
    I am not a programmer, so the programm is not 100% but it does what it needs to do.
    If there is interest in the program I can post it on Github and share the Google Sheet, but I then must add some documentation to it.
    So if more then 5 people are interested I will do the above effort ๐Ÿ˜‰
    some screen shots:
    Imported file
    file menu
    Geocode the first 5 rows by selecting Latitude and Longitude
    "Special MRA tools" to fill in address in the Name field.
    Screenshot with added address in namefield ( in different colors) and the export dialog.
    POI GPX imported in MRA where in the Namefield the address is added between brackets.
      This sounds a lot like my PQ2POI effort, but I made it into a webservice.
      https://forum.myrouteapp.com/post/69311
      Would people be interested in a web-solution for this? upload POI, enrich with address, combine it in the namefield). I could give it a try.
      BertMundefined 1 Reply Last reply
        @Con-Hennekens said in POI Editor and converter:
        I have seen your PQ2POI, looks nice.
        I have no webspace, so that is why I use Google sheets for it. Are you using a database for the convertion?
        • BertMundefined BertM
          @BertM, No, it is plain HTML5. But for a solution like yours at least some python code must be used, or a backend to run a script. Nominatim is an API service that could be used freely to geocode, but it is throttled to 1 lookup per second...
            Nick Carthewundefined Online
            I understand more when you write in Dutch ๐Ÿ˜
              @Nick-Carthew said in POI Editor and converter:
              Somehow I don't think my lack of English is the cause for that... ๐Ÿ˜‰
                Hey,
                ich wรคre gerne dabei !!! VG
                I would love to participate !!! Best regards
                iPad 9. Gen iOS 26.3 / iPhone 16e iOS 26.3/ iPhone Xr iOS 18.7.5 / PC mit MS Win11 /โ—๏ธMyRoute-App im Cradel und Remotek-Oneโ—๏ธ Info zu MRA & Remotek One
                  some screen shots:
                  Imported file
                  file menu
                  @BertM, could you show me the source or link of that POI file? Many sources claim to offer biker(friendly) facilities, but a list for all of europe would be very handy.
                    It just a small file I use for testing:
                    https://www.motorhotels.info/poi
                    BertMundefined
                    • Unable to stop navigation
                      1.1k
                    • Waypoints missing in 5.0.3 when navigating as track
                      Herman Veldhuizenundefined
                    • Suggestions For Nice Route From Rotterdam tp Spa
                      Alan Daubneyundefined
                      Alan Daubney
                    • Carpe Iter Caretta
                      Martin Wilckeundefined
                      Martin Wilcke
                    • Web planner SKIP button
                      Stephan Dornbergundefined
                      Stephan Dornberg
                    • MRA connector won't see my pc-connected BMW Navigator (tomtom version, 2024 yr)
                      Stephan Dornberg
                      1.9k
                    • Probleem met ANDROID in de wagen.
                      M PRPundefined
                      M PRP
