  4. MRA Routplanner ignored.
3 Posts 3 Posters 923 Views 2 Watching
  • Brian Martinundefined Offline
    Brian Martin
    Why after planning a route with Routeplanner app it ignores all the route and waypoints and does it's own thing taking me miles out of the way? It doesn't even take me to start at the first waypoint. It doesn't happen with loaded GPX files just when planned using the mobile app.
      It is probably due to the setting of the app, check it sensibly.
      The manual in the Web Planner helps very well.
      VG 👋
      • Brian Martinundefined Brian Martin
        @Brian-Martin, When you start a route, you will see a switch to enable/disable "start from closest route point". Is that the one you are looking for? If not, maybe a screenshot explains your question.
        Brian Martin
        • Tracklog fails
        • Expand
          Martin Woodfordundefined
          Martin Woodford
        • Moving the map
        • Altijd weer terug naar startpunt
        • Luftlinie zwischen zwei Punkten
          Tuxiundefined
          Tuxi
        • Change Favorites icons on map
          2.2k
        • Routepunt overslaan
          JP dundefined
          JP d
