  3. Via point icons not showing on Zumo XT
24 Posts 3 Posters 7.3k Views 3 Watching
  • A Former User?
    A Former User?
    A Former User
    After creating a route in MRA and adding details to via points ie: cafe stop and time and changing colour to red. After exporting, these do not show up on the Garmin Zumo XT map as such. The via points only show as start and destination flags. After watching the video for via en shaping, Serg shows the customised via points on a Zumo XT after exporting. So what am I doing wrong?
      @Brian-Martin
      Did you use the Garmin XT export option?
      • A Former User?
        A Former User?
        A Former User
        Yes I did
          Yes I did
          @Brian-Martin
          Share you’re route please, make sure it is public. Then I can have a look
          Henrik Müller 1 Reply Last reply
            @Brian-Martin
            Henrik Müller
            Henrik Müller
            Henrik Müller
            @Hans-van-de-Ven-MRA-Master
            Hi Hans
            I have still my problem regarding the route between the second last point (sharping point or via point) and the finish point is a "offroad" track" I'm also using the Garmin XT option.
            I have made my route public, called last point.
            • Henrik Müller Henrik Müller
              Hi Hans
              @Henrik-Müller
              Hendrik please share the url off the route here
                @Henrik-Müller
                Henrik Müller
                Henrik Müller
                Henrik Müller
                https://www.myrouteapp.com/en/social/route/4559836?mode=share
                  @Henrik-Müller
                  Thanks, I will have to investigate that further, probably is it the track that you see, and when you drive the route it will be under the routeline
                    @Henrik-Müller
                    Henrik Müller
                    Henrik Müller
                    Henrik Müller
                    @Hans-van-de-Ven-MRA-Master said in Via point icons not showing on Zumo XT:
                    @Henrik-Müller
                    It worked fine for 8-10 days ago - if I try to disable the GPS satellite, and simulate the route on the device, the problem is also showed.
                    I'm not using tracks, as i like the via and sharping points options.
                      @Henrik-Müller
                      @Henrik-Müller
                      From the Dutch XT FB group
                      You probably haven't converted your track to the trip planner. Nowadays you can also choose 'Go' when you select the track. You will then get that dotted line to the start or nearest point, but no further indication. You should start the route from the trip planner and not from tracks.
                        @Henrik-Müller
                        Henrik Müller
                        Henrik Müller
                        Henrik Müller
                        wrote on last edited by Henrik Müller
                        I’m using the trip planner (as shaping and via points are nice) - the dotted line is as you stated from where you right now to the first (via) point.
                        I’m not using tracks and convert them, as I then will lose the points benefits.
                        The issue I referred to, is the calculation between the second last point (sharping or via) and the finish (via point) marked by a checked flag.
                        (All in the trip planner)
                        My workaround, right now is to place 2 points nearby the finish flag.... Looking forward for a fix.
                        / Henrik
                          / Henrik
                          @Henrik-Müller
                          I had the same today🤷‍♂️
                            @Henrik-Müller
                            Henrik Müller
                            Henrik Müller
                            Henrik Müller
                            @Henrik-Müller
                            Sound "good" - and as your status is instructor, you probably have access to elevate this issue to the right programmer people at MRA ?
                            / Henrik
                              @Henrik-Müller
                              / Henrik
                              @Henrik-Müller
                              I don't know if this is a Garmin or an MRA issue, as I only see this on the XT and not on MRA Navigation. I'm going to test this by putting a route from Garmin Basecamp on my XT.
                                @Henrik-Müller
                                Henrik Müller
                                Henrik Müller
                                Henrik Müller
                                If I make a new route on the XT device in trip planner, it works as it should.
                                If the problem is in the XT software when importing GPX into trip planner, MRA must report it to the Garmin SW team, as MRA probably have more “weight” in the approach than a bunch of users...?
                                  @Henrik-Müller
                                  Then they probably already know at Garmin, and this will be solved with one of the updates
                                    @Henrik-Müller
                                    Henrik Müller
                                    Henrik Müller
                                    Henrik Müller
                                    Hi Hans
                                    I’m writing the route works if you program the route on direct on the XT device in trip planner - so the Garmin own internally route calculation works.
                                    The issue is starts when I import a ROUTE from MRA into trip planner, then the strange “off road route” between the second last and the last point appears.
                                    I’m glad you have seen it yourself from MRA - How did your test with Basecamp go ?
                                    Hans van de Ven MR.MRA 3 Replies Last reply
                                      Hi Hans
                                      @Henrik-Müller
                                      I have not yet tested with a route from basecamp ...
                                        Hi Hans
                                        @Henrik-Müller
                                        With a route from BC no problem, given the placement of the next to last route point, it is probably due to the distance between the last and the next to last route point that this will occur.
                                        I added an extra route point and now the route continues as usual.
                                        I'm going to test this further.
                                        I'm going to place this with the developers.
                                        To be continued.
                                          Hi Hans
                                          @Henrik-Müller
                                          Hi Henrik, the route from the last waypoint to the end point is not calculated correctly, that's why you see either the dotted line of the track or a straight (direct route) route line.
                                          It has been reported to the developers, they may need to make a minor adjustment to the .gpx file for the Garmin XT.
                                          Thanks for reporting.
                                          Henrik Müller 2 Replies Last reply
                                          Henrik Müller
                                          Henrik Müller
                                          A Former User?
                                          [[global:former-user]]
                                          • New Zealand Routes
                                            wim GS
                                            wim GS
                                            2.0k
                                          • Off-road niet zichtbaar in Android Auto
                                          • IOS 27
                                          • Naar vorig routepunt
                                          • Getal in begin logo
