  4. Little issues, night mode in tunnel, recalculation
9 Posts 5 Posters 82 Views 4 Watching
  • Jörgenundefined Online
    during my last tour from about, 3680km I had only little issues.
    One, was in Switzerland when driving through a tunnel, the display switch to night mode, (nice feature) but on some tunnels it takes a very long time to switch back when the tunnel ended.
    Here the tunnel ended a long time before, but the display is still in night mode.
    Is this a matter of the HERE map data?
    The other was, for some reason the App started recalculation and ist not coming back in normal mode.
    A restart was needed. What could be the reason?
      @Jörgen
      Tunnel:
      • I only drive with day mode, also goes well in the tunnel.
      • The time between day and night mode switching can also be on the mobile phone.
      Recalculation:
      • Navigate offline, and the recalculation off then I don't have that
      • Recalculation without a network apparently leads to such problems described by you
      • Maybe the map to the route section was not offline on your phone, even if the map is missing there is the problem
      Tunnel:
      • ich fahre nur mit Tag Modus, geht auch gut im Tunnel.
      • Die Zeit zwischen Tag und Nacht Modus Umschaltung kann auch am Handy liegen.
      Neuberechnung:
      • Navigation Offline fahren, und die Neuberechnung Aus dann habe ich das nicht
      • Neuberechnung ohne Netz führt scheinbar zu solchen von dir beschriebenen Problemen
      • Vielleicht war die Karte zu dem Routenabschnitt nicht offline auf deinem Handy , auch dann wenn die Karte fehlt gibt es das Problem
      iPad 9. Gen iOS 26.4.1/ iPhone 16e iOS 26.4.1 / iPhone Xr iOS 18.7.7 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
      • Guzzistundefined Offline
        Hi @Jörgen - I don't know about difference between iPhone and Android.
        But I'm using Android and my screen settings in MyRoute-App are not "night", not "day", but "phone".
        In device settings, I use automated brightness.
        By this, display will not change to dark mode if you drive in tunnel, but will only reduce brightness. That's verry ok for me.
          My App-Theme is also set to phone (Android). And I have this switch from day mode to night mode in tunnels.
          And it is fine, it works perfect in Germany, but not in Switzerland.
          As I said, may be and map data error.
          • Jörgenundefined Jörgen
            @Jörgen ...oh - I don't have options for tunnels at my Android device; only for sunrise and sunset.
            Then you will probably be right about the map errors...
              I don´t have an option for tunnels, it just works without anything from my site.
              • Peter Schieferundefined Offline
                Peter Schiefer
                Jörgen, last weekend I was crossing Switzerland from Basel to Geneve and I got the same problem with my iPhone but consider in combination with CarPlay in my Cabrio. Not switching back to daylight mode. Long time to find back to the road at the end. As I remember, at one or two case I need a restart. But as mentioned in a car, the Display of the Audiosystem switched also in night modus when your running lights gets on. So at that time I was not clear by myself why it doesn‘ t switch back. No reading your issue I must confirm this.
                Peter
                  Do you think this problem IS only in Switzerland?
                    M. Schrijverundefined Offline
                    I've seen this sometimes.
                    • The Location stays stuck in the tunnel. But this is visible on your screen.
                    • I'm not sure if it a map error. I'm not familiar enough with Here map. But on Google and TomTom maps the road get a slighty darker color where the tunnel is. On this part the GPS will switch to Night mode. Maybe this is wrong on the Here map at some tunnels.
                    • MRA gets stuck in Night mode while re-gaining the GPS fix when leaving the tunnel.
                    Peter Schiefer
                    • App behaviour when in offline mode at a construction site
                    • MRA Update V5.1 …. What awaits us when?
                      Andre Klapundefined
                      Andre Klap
                    • Supprimer un itinéraire qui est affiché
                      LE DIZES Freddyundefined
                      LE DIZES Freddy
                    • New device …. how to change registered devices?
                      silberfuchs67undefined
                      silberfuchs67
                    • Identifying an expert route without hunting for the start point
                      16.7k
                    • Finetunen van herberekenen zou fijn zijn.
