  4. Little issues, night mode in tunnel, recalculation
10 Posts 6 Posters 87 Views 4 Watching
  • Jörgen Offline
    Jörgen Offline
    during my last tour from about, 3680km I had only little issues.
    One, was in Switzerland when driving through a tunnel, the display switch to night mode, (nice feature) but on some tunnels it takes a very long time to switch back when the tunnel ended.
    Here the tunnel ended a long time before, but the display is still in night mode.
    Is this a matter of the HERE map data?
    The other was, for some reason the App started recalculation and ist not coming back in normal mode.
    A restart was needed. What could be the reason?
    • Hubert Thoring Offline
      @Jörgen
      Tunnel:
      • I only drive with day mode, also goes well in the tunnel.
      • The time between day and night mode switching can also be on the mobile phone.
      Recalculation:
      • Navigate offline, and the recalculation off then I don't have that
      • Recalculation without a network apparently leads to such problems described by you
      • Maybe the map to the route section was not offline on your phone, even if the map is missing there is the problem
      Tunnel:
      • ich fahre nur mit Tag Modus, geht auch gut im Tunnel.
      • Die Zeit zwischen Tag und Nacht Modus Umschaltung kann auch am Handy liegen.
      Neuberechnung:
      • Navigation Offline fahren, und die Neuberechnung Aus dann habe ich das nicht
      • Neuberechnung ohne Netz führt scheinbar zu solchen von dir beschriebenen Problemen
      • Vielleicht war die Karte zu dem Routenabschnitt nicht offline auf deinem Handy , auch dann wenn die Karte fehlt gibt es das Problem
      • Guzzist Offline
        Guzzist Offline
        Hi @Jörgen - I don't know about difference between iPhone and Android.
        But I'm using Android and my screen settings in MyRoute-App are not "night", not "day", but "phone".
        In device settings, I use automated brightness.
        By this, display will not change to dark mode if you drive in tunnel, but will only reduce brightness. That's verry ok for me.
        • Jörgen Offline
          Jörgen Offline
          My App-Theme is also set to phone (Android). And I have this switch from day mode to night mode in tunnels.
          And it is fine, it works perfect in Germany, but not in Switzerland.
          As I said, may be and map data error.
          Guzzist 1 Reply Last reply
            Guzzist Offline
            Guzzist Offline
            @Jörgen ...oh - I don't have options for tunnels at my Android device; only for sunrise and sunset.
            Then you will probably be right about the map errors...
            • Jörgen Offline
              Jörgen Offline
              I don´t have an option for tunnels, it just works without anything from my site.
              • Peter Schiefer Offline
                Peter Schiefer
                Jörgen, last weekend I was crossing Switzerland from Basel to Geneve and I got the same problem with my iPhone but consider in combination with CarPlay in my Cabrio. Not switching back to daylight mode. Long time to find back to the road at the end. As I remember, at one or two case I need a restart. But as mentioned in a car, the Display of the Audiosystem switched also in night modus when your running lights gets on. So at that time I was not clear by myself why it doesn‘ t switch back. No reading your issue I must confirm this.
                Peter
                • Jörgen Offline
                  Jörgen Offline
                  Do you think this problem IS only in Switzerland?
                  • M. Schrijver Offline
                    I've seen this sometimes.
                    • The Location stays stuck in the tunnel. But this is visible on your screen.
                    • I'm not sure if it a map error. I'm not familiar enough with Here map. But on Google and TomTom maps the road get a slighty darker color where the tunnel is. On this part the GPS will switch to Night mode. Maybe this is wrong on the Here map at some tunnels.
                    • MRA gets stuck in Night mode while re-gaining the GPS fix when leaving the tunnel.
                    • Robineke Offline
                      Robineke Offline
                      Robineke
                      Uptill one month ago switching worked fine. All of a sudden now the switch back to light screen takes about 700meters.
                      Can I change this in settings?
                      Robineke
                      Robineke
                      Peter Schiefer
                      Peter Schiefer
                      • "The selected profile only works in the HERE / TomTom map"
                        siebo vd berg
                        siebo vd berg
                      • Transport modes?
                        Mike wiruth
                        Mike wiruth
                      • instelling voor exact track rijden
                        rudi 2h 0
                        rudi 2h 0
                      • Little issues, night mode in tunnel, recalculation
                        Robineke
                        Robineke
                      • No navigation instructions
                        Hans-Udo Erdmenger
                        Hans-Udo Erdmenger
                      • Google maps and Streetview
