  4. Spoken waypoints prevent spoken route directions
10 Posts 5 Posters 2.1k Views 4 Watching
  • Makroundefined Offline
    Makro
    With waypoints close to intersections, I have noticed some situations where waypoints are spoken, preventing route directions from being spoken.
    With an intersection close by, I would prefer if route directions take priority.
    Best regards, Makro
    Rob Verhoeffundefined Guzzistundefined 2 Replies Last reply
    • Makroundefined Makro
      Rob Verhoeffundefined Offline
      @Makro The alternative is simply to place the shaping points a bit further down the road. There’s no need to put the shaping points so close to a junction. A via point is different, because it could very well be that your favorite rest stop is located there. But in that case, you obviously don’t need to hear route guidance, since you’ve reached your next stopover or final destination.
        Guzzistundefined Offline
        @Makro it's good practice, to set route points (no matter if shaping- or via point) after a junction, not before.
          Makro
          Even though it's not optimal, sometimes route points have to be set rather close to intersections, in order to make sure the route won't get calculated via the wrong streets.
          Besides, people should have the freedom to set route points as they like, and not have to force themselves to use the software in a way the algorithms can handle.
          You could also tell me not to use long text in waypoints, or not to have waypoint details spoken. But come on, the features are there to be used, right?
          So, spoken route directions should always take priority. This is not the case, and I still believe this should be changed.
          Best regards, Makro
          Con Hennekensundefined Guzzistundefined 2 Replies Last reply
          • Jörgenundefined Offline
            There are some rules to place WP correctly.
            If you need a WP close to a junction, do it with shaping point and switch the notice off.
            In case you have an explanation to the WP, then is the question of what is more important, your explanation or route direction?
              @Makro said in Spoken waypoints prevent spoken route directions:
              I disagree. If I deliberately set a waypoint close to a crossing, and I deliberately give it a text to be spoken, I think that it should have priority over route directions.
              What I do agree on, is that a waypoint that has no text to be spoken, should not interfere with the route-directions being spoken.
              It is what it is. No single app will be completely targeted at what what each individual thinks should have priority. You can adapt easily, by not placing WPs close to crossings, or not and keep being frustrated about it 😉 I think there are bigger fish to fry...
              Makroundefined 1 Reply Last reply
                ...Besides, people should have the freedom to set route points as they like, and not have to force themselves to use the software in a way the algorithms can handle...
                Sorry to say this: If you buy a Garmin, you need to lern how it will work. If you buy additionally a TomTom, you need to get familiar also with its algorithm. And they are different!
                Why the behaviour with MyRoute-App could be different?
                • Guzzistundefined Guzzist
                  Makro
                  @Guzzist said in Spoken waypoints prevent spoken route directions:
                  All software should be made initiatively, so people don't have to adapt to technology.
                  I too have used Garmin. And I know all too well, that these competitors have their issues too, you have to adapt to.
                  But simply because the big dogs make software you have to adapt to, is no reason for others to do the same.
                  Best regards, Makro
                    Makro
                    @Con-Hennekens said in Spoken waypoints prevent spoken route directions:
                    I agree. And I respect people can have different preferences.
                    But I still believe I do the right thing by providing feedback to the developers.
                    And this is not a yes or not issue. As seen before, an option can be implemented, so users can pick the spoken priority they want: waypoint details over route directions or vice versa.
                    Best regards, Makro
                      No one disputed that, but it is up to the devs what they do with it.
                      Makroundefined
                      Makro
                      • Geen kaart
                        Rob Veermanundefined
                      • back to old situation with 2 apps
                        Bouke Entundefined
                      • Basecamp-Kurviger Overlay!
                        Kudeeundefined
                        Kudee
                      • Waypoint met foto
                        Robinekeundefined
                        Robineke
                      • Default POIs
                      • de route omdraaien.
