  4. Problems with the "Avoid Toll Roads" option
24 Posts 7 Posters 9.7k Views 3 Watching
  • RetiredWingMan Offline
    Share a link to the route and make the route public. We can review the route to try and solve the issue.
    • Giancarlo e Giancarlo e
      Since the last update (Version 4.4), when you select the "Avoid Toll Roads" option, the app assumes you shouldn't use highways. It's as if the app can't identify which highways are toll roads and which aren't. Examples:
      In this example, a route has been created where the "Avoid toll roads" option has not been chosen, and the app goes through the M-45 motorway (Madrid), which is not a toll road.
      In the same example, the option "Avoid toll motorways" has now been chosen, and as can be seen, the app avoids using the M-45 motorway (Madrid), identifying it as a toll motorway when it is not.
      Brian McG Offline
      Brian McG Offline
      Hi @Giancarlo-e I can replicate what you see in MRA with the OSM routing
      Inspecting the OpenStreetMap data on the OSM site, it has no tags for tolls on this section of motorway
      Replicating the same route in Osmand with the Avoid Tolls option enabled it routes correctly along the motorway
      The only conclusion I can come to is that the MRA version of the OSM data must have an incorrect Toll tag on this section
      • Donovan Smith Offline
        Donovan Smith
        View 'To Levigniac' in MyRoute-app! https://www.myrouteapp.com/route/open/11805038 There were sections of this router prior to starting point but I deleted them after use and only have this section left
        • Donovan Smith Donovan Smith
          I am a beginner user and think I had a similar issue. Or possibly a similar issue. I planned a route from north to south of France. I had waypoints in the route. I set options to use motorways, avoid tolls and fastest. When I opened route it did give me route violation warning. But did not say where or offer an alternative. On 3 separate occasions the guidance took me on a toll road. Which is I guess the only way to get me to my next waypoint. (This is usually avoided when using Garmin devices.)I think possibly the weighting and priority of the route planning should firstly avoid tools, then compute fastest time. Or not allow route creation. It’s hard to avoid a toll when you’re on the approach road!
          @Donovan-Smith said in Problems with the "Avoid Toll Roads" option:
          Planning a route in OSM will start the "Navigate Route as a Track" feature, because Navigation uses the HERE map. Navigating a track does not give room for alternative routing. So if you plan your route in OSM (which obviously has a problem in that area concerning toll roads) and start navigating in the MRA app (using HERE as the only option) things like this happen.
            Donovan Smith
            I planned it on the web through the web app. So can I assume the web app is osm ? I know the the Next App is here maps.
            Brian McG 1 Reply Last reply
              Brian McG Offline
              Brian McG Offline
              @Donovan-Smith the navigation app on your mobile uses the Here routing algorithm
              the Here algorithm is the one used for navigation by MRA
              on the Web planner when you are planning you can choose which routing algorithm you wish to use either OSM, TomTom or Here
              You should choose the algorithm that matches your navigation device
              So if your using MRA or a Garmin to navigate it is best to use the Here routing algorithm
              If your using a TomTom obviously best to use the TomTom algorithm
              If your using Osmand then best to use the OSM algorithm
              The TomTom & Here routing algorithms are not available with a basic web account, you need either a Gold or Navigation subscription to access them
              The map layers are just graphic overlays they just show you where the roads are, they are not responsible for calculating the routing
                Donovan Smith
                @Brian-McG ok. I just looked on the mra route planner. I don’t have access to choose here maps as I am not a gold subscriber. I am only paying for the next nav app. So by default following your post I am guessing I am on osm maps then when I go to my nav app it’s here maps, so that’ll be the issue! If I plan a route using destination input, is that also using osm maps to plan? Vis a vis is there a way around (simple and easy ) or is this a way they force a revenue stream?
                Nick Carthew Brian McG 2 Replies Last reply
                  Nick Carthew Offline
                  An MRA Navigation Next subscription gives you access to the HERE planning map in the website route planner.
                    Brian McG Offline
                    Brian McG Offline
                    @Donovan-Smith if you look at the first image in my previous post you can see it says "Here (MyRouteapp/Garmin) Gold / Nav"
                    the "Nav" at then end is to indicate, as @Nick-Carthew says that the Here routing is available with the navigation subscription
                    You need to be logged in to the web planner with the same account that you use for the Navigation app
                      Donovan Smith
                      Ok. Found the here maps setting. Thank you. Next question, if I create a a to b route on the web in the here maps. Does it always open in here maps afterwards when I choose to edit it?
                        All routes will remember the last planning map that was used for that route.
                        If you click Always use this map for new routes, the HERE planning map will always be chosen for new routes.
                          Donovan Smith
                          Thank you @Nick-Carthew. So I guess then I can open and edit it in the mra app and it will do as expected. I have created a simple route here just a to be to avoid tolls. Can someone confirm it’s good please?
                            @Donovan-Smith You'll need to share the route before anyone can check it.
                            To share:
                            Firstly, the privacy of the route must be set to Public.
                            Open the route and then open the Route-information tab in the left menu column, here you'll see a Privacy drop down box where you can change the privacy to Public.
                            Now click the Share button in the top right of the map screen, if you do not see a Share button, click Page menu first, then you’ll see Share button.
                            After clicking Share, you have different options for sharing, choose the Link option and then copy and paste the URL web address into your reply please.
                              Donovan Smith
                              https://www.myrouteapp.com/en/social/route/11950009?mode=share
                                Brian McG Offline
                                Brian McG Offline
                                @Donovan-Smith that is a long A-B route, just shy of 600 miles
                                it seems to be doing the right thing in avoiding the tolls
                                I put similar start - end points in google maps & selected avoid tolls & the 2 systems seem to track pretty well
                                a few small differences, the main one being how to route round the tool on the A63 at the Aire Port des Landes, only about 35 miles into the trip
                                If you select the TomTom & Openstreetmap route algorithms you will see they also take slightly different paths but in general they are all doing similar things
                                Remember to return the route algorithm setting to Here before you navigate
                                Giancarlo e
                                Giancarlo e
                                Donovan Smith
                                Donovan Smith
                                Manzo91
                                Manzo91
                                  Thomas Schäfer
                                  Thomas Schäfer
                                • opslaan naar plantomtom
                                  chris 18
                                  chris 18
                                • Welke instelling
                                  chris 18
                                  chris 18
                                • Seizoen sluitingen wegen
                                  PAT62
                                  PAT62
                                  Kobutex Motorreizen
                                  Kobutex Motorreizen
                                • App loopt vast
                                • I can't see Road Closures
