  3. Carpuride
Carpuride
25 Posts 10 Posters 13.8k Views 2 Watching
  • silberfuchs67
    silberfuchs67
    silberfuchs67
    Yes, the app supports Android Auto and Carplay.
    • paul69
      hi @Mark-Hawkins
      i use a carpuride w702B, most of the time except when i am touring when I use my oukitel RT3 rugged tablet.
      the reason is, when using Cp you cannot use some the features e.g cannot skip waypoints manually etc as the icon is not on view, I am informed this an Apple issue and not the fault of MRA
      It's for this reason I use my RT3 when touring, because it can become a PITA when you have to get your phone out of your pocket to carry out certain tasks.
      K1600 GTL
      Oukitel RT3
      iPhone 13 Pro, carpuride 702b
      Nick Carthew silberfuchs67 2 Replies Last reply
      • paul69 paul69
        hi @Mark-Hawkins
        @paul69 said in Carpuride:
        hi @Mark-Hawkins
        Are you sure about this?
        I don’t have a CarPlay device to check, but I was under the impression that going into the settings gives you the option to skip.
        Hopefully someone with CP device can answer.
        Number 6.
        paul69 1 Reply Last reply
        • HighPeakRider
          HighPeakRider
          HighPeakRider
          Also using CarPlay you can't start a recording and no speedo or speed limit on a free ride, you would think an easy fix but the developers are not focused on these developments.
          Shame as so many people are switching to CarPlay based systems.
          • Achim Kaluza
            Achim Kaluza
            Achim Kaluza
            I'm using an iPhone 13 Pro Max with CarPlay on Carpuride W702BS. To get around the problem of not being able to start track recording via CarPlay, I start the recording at the beginning of the motorcycle tour directly on my phone before putting it into my pocket. Unfortunately, up to now I haven't had a usable track recording at the end of my tours because the NavigationNext app has crashed after a while every time so far. If I restart the app via CarPlay, I can usually continue navigation, but the track recording was either stopped when the crash occurred and doesn't continue when I reopen the app, or it is completely discarded, and in the end there is just a straight line from the starting point to the place where the app crashed. This is very annoying and makes the app virtually unusable for me. When you're riding in a group, you can't stop every time the app crashes and take your iPhone out of your pocket to continue track recording there.
            • paul69 paul69
              hi @Mark-Hawkins
              silberfuchs67
              silberfuchs67
              silberfuchs67
              I use a CP 702BS with CP and I can confirm that it is possible to skip waypoints with MRA Next.
                hi @Mark-Hawkins
                Number 6.
                hi,
                @Nick-Carthew
                apologies, I stand corrected, I was not aware of this icon, (I ask why myself why am I not aware DOH)
                the icon that appears in the top right corner when using the next app directly is not viewable in CP on my particular device.
                I am not sure how to add that icon, #6, can someone enlighten me please.
                unable to skip waypoints on screen below,
                K1600 GTL
                Oukitel RT3
                paul69 Ronny Schenkels 0 2 Replies Last reply
                • paul69 paul69
                  hi,
                  @Nick-Carthew
                  for clarity, below is a view of the screen when using NEXT directly on the phone,
                  notice the waypoint icon top right, recording icon bottom right, settings icon and compass icon, non of which can be seen on CP screen
                  K1600 GTL
                  Oukitel RT3
                  Marinus van Deudekom Nick Carthew 2 Replies Last reply
                  • paul69 paul69
                    @paul69 in the CP and AA devices the skin waypoint button is not available. To ski a waypoint on those devices you must hit the menu button on the lower right and then you can buy the skip waypoint button
                    • paul69 paul69
                      @paul69 For various reasons, the upcoming waypoint icon that you refer to is not available for AA or CP.
                        hi @Marinus-van-Deudekom said in Carpuride:
                        to which icon do you refer, the one on the lower right is the pan icon, not menu.
                        i am clearly doing something wrong if others can skip waypoints. I will have to have a play around.
                        K1600 GTL
                        Oukitel RT3
                        • paul69 paul69
                          @paul69 The menu button down right
                            please excuse my ignorance once again, but may I again enquire to which one you refer.
                            the CP bottom right is the pan icon/button (4 arrows)
                            the iphone bottom right is the menu button (3 dots), however this is of no use when the phone is in a pocket.
                            K1600 GTL
                            Oukitel RT3
                            • paul69 paul69
                              hi,
                              @Nick-Carthew
                              Ronny Schenkels 0
                              Ronny Schenkels 0
                              Ronny Schenkels 0
                              @paul69
                              icon #6 is not available in CarPlay when you are in 'manual zoom', because in 'Manual Zoom' the + and - icons are displayed instead.
                              Once you go back to automatic zoom, then icon #6 is available on your Carplay screen
                              Ronny
                              BMW 1250 RS '23
                              Garmin Zumo XT2 (sold)
                              Chigee AIO-5 Lite (sold)
                              Innovv N1 Pro (sold)
                              Chigee AIO-6 MAX
                              • HighPeakRider HighPeakRider
                                @HighPeakRider said in Carpuride:
                                There are limits imposed by Google and Apple concerning the AA/CP GUI. There is simply no possibility to throw all app features into the AA/CP GUI. Personally I think it is a shame that so many people buy AA/CP devices not knowing about the limitations it brings.
                                  @Con-Hennekens I couldn't agree more Con. There are a lot of issues with people using CP and AA. I think most of them because they expect to much from CP and AA and were a bit misguided in buying devices that are not that expensive.
                                  On the otherhand there are users that know the limitations of CP and AA devices and can live with it.
                                    Personally, I know the limitations of CP hence why I use a rugged tablet for touring.
                                    I’m not too worried about features like skipping waypoints or recording a tracklog from the screen, as they’re not part of my usual setup. I was merely replying to the OP.
                                    My carpuride is my media centre, i would use the TFT but the maps and navigation and phone connections have a lot of problems.
                                    @Marinus-van-Deudekom may I ask could you answer my query regarding the menu button, please could confirm which one you think is the menu button, in my screen shots above. just to ease my confusion.
                                    thanks
                                    K1600 GTL
                                    Oukitel RT3
                                    • paul69 paul69
                                      thanks
                                      @paul69 I'll try to make some screenshots and report back
                                      • Marinus van Deudekom
                                        @paul69
                                        I gave you not the wright info.
                                        Here it is
                                        If you push the button on th down Right Side of the screen, indicated by the arrow. Another screen opens and on the down left under there’s a pop up where you can skip the waypointIMG_0239.jpeg IMG_0240.jpeg
                                          @paul69
                                          Here it is
                                          hi again, @Marinus-van-Deudekom
                                          thanks for taking the time to reply, however, as shown in my screen shot, shown again below, i do not see the icon you point out
                                          as i stated earlier i will do some digging, perhaps i will uninstall and reinstall the app, and reset the CP device.
                                          thanks
                                          K1600 GTL
                                          Oukitel RT3
                                          silberfuchs67
                                          silberfuchs67
                                          Ronny Schenkels 0
                                          Ronny Schenkels 0
                                          HighPeakRider
                                          HighPeakRider
                                          Marco Bakker
                                          Marco Bakker
                                          Achim Kaluza
                                          Achim Kaluza
                                          Mark Hawkins
                                          Mark Hawkins
                                          • Routenplaner on iPad
                                          • Rondrit generator ervaring
                                            Sam Kramer
                                            Sam Kramer
