  4. App very laggy
App very laggy
19 Posts 6 Posters 5.3k Views 3 Watching
  • Thomas Neumeyer Offline
    Thomas Neumeyer
    I tried it at my Samsung Galaxy Tab Active 3. Here the same app version works well, no laggs just ok. But the other device really has a issue. It looks like the CPU/GPU is overloaded for whatever reason. I hope that dev's could look into it. Maybe its related to Android 15? Personally I really like the app and get used to it. But there are quite often draw backs with the (my) user experience which really convince me to use it as a "daily driver". Thomas
      Adrian Avram Offline
      @Thomas-Neumeyer I tried on Samsung S24 Ultra with Android 15, on Samsung S22 with Android 14, and on a Motorola Thinkphone with Android 14, and on my iPhone 13 but all the Android phones have the same issue after 4.4.0 update.
      I have downgraded the S24 Ultra to 4.3.9 which works perfectly (with other issues) but no lag and no crashing.
      Adrian
      🚙Renaul Duster with onboard AA/CarPlay Unit
      • RainerT Offline
        RainerT Offline
        RainerT
        OK, Samsung seems not to be the problem, since ich use a galaxy tab active 5 without any problems.
        Do you think it would be helpful to tell the community your setup?
        This list is a first step to do that.
        And this appendix:
        [ ] Have you stopped and restarted the MRA app?
             [ ] It's best to close it completely, long press on the app icon, info, exit, follow up with yes.
        [ ] Have you uninstalled and reinstalled the app?
        [ ] Have you restarted your smartphone?
          Thomas Neumeyer
          I downgraded to 4.3.9. All good now, at least the app performs like it has been performing before.
            Thomas Neumeyer
            Have you stopped and restarted the MRA app? yes
            It's best to close it completely, long press on the app icon, info, exit, follow up with yes. closed completly
            Have you uninstalled and reinstalled the app? yes
            Have you restarted your smartphone? yes
            Downgrade to 4.3.9 done. No lagg's. But this is not the solution I assume.
            • RainerT Offline
              RainerT Offline
              RainerT
              Did you follow the questions / instructions in the first and longer part of the list, mentioned first?
              RT
                Thomas Neumeyer
                I am not sure if this will help. It is just fact that 4.4.0 is not working proper on the device but 4.3.9 does. At least no lagg's.
                • Bouke Ent Offline
                  Bouke Ent Offline
                  tomorrow i will use MRA Next on my ulefone x10 and i will see if i have same problem. as backup i have alternative app and take my garmin xt.
                    Thomas Neumeyer
                    Let us know your experience. Thanks for testing.
                    • Corjan Meijerink Offline
                      We indeed are clueless why some Android phones have an issue with the specific app version. The issue is caused by the Flutter engine that needs to render stuff.
                      The issue is definitely not consistent for the device / Android version (confirmed by us and other users).
                      We do hope another update with a new Flutter version will solve it.
                        Thomas Neumeyer
                        Hello Corjan, thanks for your feedback. Appreciated. Hopefully you find a solution. So far I work with the previous version. I can not resist to ask what are the next big things wich might come this year 🙂 ? Some improvement with "not" routing/tracking screen?
                        Kind regards Thomas
                          We are expecting to release a major UI / UX overhaul in October.
                          The app will be a complete new experience.
                          Hopefully beta testing for that will start in September.
                          With the changes made then, the "not" routing/tracking screen will be tackled.
                            Thomas Neumeyer
                            Thanks Corjan!
                            RainerT
                            RainerT
                            Thomas Neumeyer
                            Thomas Neumeyer
                            • Steeds maar weer centreren
                            • Suggestion about making routes visible in a folder
                              3.1k
                            • Export to BMW CRN
                            • Update 5.2.2 - Quick fix
                            • Welke instelling
