  4. Waypoint /shaping point placement
11 Posts 6 Posters 1.6k Views 4 Watching
  • Jan Smerkeundefined Offline
    Jan Smerke
    wrote on last edited by Jan Smerke
    Something of an old topic I know.
    Just been out on a 40 mile test run on local roads and decided to use MRA linked to my Chigee - primarily to test the revised battery usage on my android phone. I designed the route and put my points bang on the road to avoid those 25m diversions up someone's garden path.
    Surprisingly I still got a couple of those mini diversions? So, when I got in I checked on my PC. Yes, I did write it on Here maps. Yes, the points were bang on the road. So why the issue.
    When you zoom in one can often see the black route is not actually coincident on the road itself. So where should the point be placed? Road or black line. I had placed all my points bang on the road. To help me understand I expanded the points on the route by another 25 (using the toolkit) and then took another look. Ah, all these additional points are on the black route line and not necessarily on the road.
    I then figured a possible easier way of designing a faithful route.
    1. Place a limited number of shaping points to get the outline of your route then change their colour from blue to whatever, say yellow.
    2. Use the expand function in the toolkit to add another 25 or more shaping points depending on how long your route is. All of these are effortlessly placed exactly on the black line. Now look back at your route. There are now a small number of original yellow points of variable placement accuracy plus 25 blue expansion points bang on the black line.
    3. Delete all your yellow yellow points instead of the faff of moving them about.
    Obviously you need to be accurate with your start and finish waypoints. I guess it would not hurt to also change a few of those shaping points to waypoints.
    I wonder if anyone else has adopted this semi automated point placement and how it has worked out for them on a longer trip with many waypoints/shaping points.
    • Jan Smerkeundefined Jan Smerke
      Guzzistundefined Offline
      @Jan-Smerke I do have your issue too. But I don't run in problems if I do place my routepoints always exactly onto the black route line; ignoring if the route line is in the middle of the street, or not.
      There is a reason, why a route line is not exactly on the drawn road on map. Sometimes at gorges, high mountain passes etc. position from gps signal will be distracted slightly. Therefore, drawn road on map is not hit exactly.
        M. Schrijverundefined Offline
        If your waypoints are placed on the road. Then they are placed correct.
        Be aware don't place them on crossings, on places where roads crosses a highway (bridges). If possible not on roads or parts of the roads where the lane directions are split (like highways). This can cause diversions.
          Please share your route here and make shure its set to public so we can help you understand whats going wrong
            Jan Smerke
            Hi Marinus,
            Thank you for your interest. Here is the route. I have been tinkering with the route before my post on here so not sure how revealing it will be but here it is. Most issue were between points 4 and 9
            Jan
            https://www.myrouteapp.com/route/open/11757927
            Brian McGundefined Marinus van Deudekomundefined 2 Replies Last reply
              Why all those Viapoints?
              If you miss a viapoint without noticing it. You will send back endless.
                Hi Marinus,
                Jan
                Brian McGundefined Offline
                Hi @Jan-Smerke have had a look at the shared route & can see no issues, no mini diversions
                As you correctly state this revised route is probably not going to reveal the cause of the issue.
                I did notice the shared route seems to be set to route using OSM & not Here which is not ideal if planning to navigate with MRA
                I know you said the original map was saved as routing with Here so this routing change is probably one of the revisions you made
                As @M.-Schrijver says placing points near junctions or side roads is a common issue that can lead to mini diversions. It is far more important to avoid this misplacement on side or adjacent roads than it is to place the point directly on the correct path / road.Navigation systems will generally cope okay with reasonable placement errors, they will automatically try to route via the nearest road.
                Examples below show how mini diversions can easily occur ( I have just played with point 4 in your route)
                Different navigation systems have different tolerances to what they consider a reasonable placement error.
                I have found MRA navigation is very tolerant to misplacement of points off the intended road, a Garmin XT however a lot less tolerant
                All navigations systems will have a problem if points are placed near side roads, they have no idea if you wish to take the side road or not
                  Hi Marinus,
                  Jan
                  @Jan-Smerke hi Jan
                  I've looked at your route.
                  It seems strange to me that your route die not follow the road.
                  Opening the page menu I saw that this route is made in OSM and that explains why there is a difference.
                  Expanding the route to lets say 25 resulted in 12 extra shapingpoints being added to the route. Indeed bang om the Black Line of the route and since it is still using OSM not on the road
                  Then I changer the map to Here and not very surprised saw that more waypoints were OFF the route. The route itself was on the road
                  Dading the extra 12 points like before redulted in the extra points being placed on the route and this on the road.
                  So want went wrong was starting with the OSM witch was marked as standard map.
                  Set that to Here and you:re good to go.
                  Like @M.-Schrijver said don’t use viapoints if that’s not neccesary
                  Have fun
                  • RainerTundefined Offline
                    RainerT
                    This URL leads you a checklist.
                    It should make it easier to understand the parameters you used for route planning and navigation.
                    Here, too, a mix of different maps, overlays and route engines is responsible for the problems.
                    myrouteapp is close to being the perfect all-rounder. But that also means that the parameters you set play a role that is not taken into account in the error description.
                    Perhaps this will make it a little easier.
                    RT
                      The url leads to a German post with no checklist in it
                        RainerT
                        Deep.com translation:
                        Troubleshooting checklist V2.0
                        To rule out possible operating errors and better identify the fault or problem, it would be helpful to answer these questions. This will give other participants a better overview for developing further steps or a possible solution.
                        Copy the checklist, there is a button top right
                        MRA Web Planning (planning on a PC, tablet, etc. via a browser)
                        [ ] Which subscription do you have? (Basic, Silver, Gold)
                        [ ] Which routing engine was used? (OSM, TomTom, Here, preferred), not overlay map
                        [ ] What is checked in Toolkit Avoid, preferred none
                        [ ] Which vehicle was planned for? (Car, motorcycle, other)
                        [ ] Which options were set (winding/fastest/shortest), preferred none
                        MRA Navigation App (everything on a smartphone, tablet, etc. via the app)
                        [ ] Do you have a Navigation Next subscription?
                        [ ] What hardware, what smartphone is used? (Brand, model)
                        [ ] What operating system does the smartphone run on? (iOS, Android)
                        [ ] What software version is on it? (If not current)
                        [ ] Do you use Android Auto and/or Apple CarPlay?
                        [ ] Which display unit is used for this? (Carpuride/vehicle/other)
                        [ ] Which connection is used? (USB cable or wireless)
                        [ ] What are the navigation settings? (*See post by Hubert Thoring)
                             [ ] Route calculation
                             [ ] Traffic settings
                             [ ] Navigation function
                             [ ] Route validation, opt.
                             [ ] Track navigation
                             [ ] Offline maps
                             [ ] Which avoidance options were used? (Highway, toll road, etc.)
                        [ ] MRA Navigation app route planning
                              [ ] Was a route or track used?
                              [ ] Was the route/track taken from web planning (route directory)?
                              [ ] Navigate as a route or as a track
                              [ ] Was A to B destination planning used?
                              [ ] Which options were used (including curve options)?
                              [ ] Was a round trip planned, including options?
                        [ ] Settings on the smartphone
                        [ ] How are the permissions for the app set?
                              [ ] Location permanently allowed?
                              [ ] Messages/notifications allowed?
                              [ ] Online or offline mode, maps downloaded?
                        [ ] Describe the problem or your question in more detail.
                        _____________________________
                        [ ] Add screenshots if possible.
                        [ ] The link to the route file may also be helpful.
                        *Contribution by Hubert Thoring
                        https://forum.myrouteapp.com/topic/9564/mra-basis-einstellungen-empfehlenswert
                        RainerTundefined
                        RainerT
                        Jan Smerkeundefined
                        Jan Smerke
                        • Update 5.0.3 - Device management
                          Cleoundefined
                          Cleo
                          1.6k
                        • I am starting to hate this app right about now ...
                          Cleoundefined
                          Cleo
                          CD130undefined
                          1.6k
                        • Siri gebruiken met CarPlay
                          CD130undefined
                        • Web symbol on my Android phone
                          Terence Rawcliffe 0undefined
                          Terence Rawcliffe 0
