  4. Trip Planning - Overlay Mark Up
12 Posts 6 Posters 584 Views 3 Watching
  • Steve Jamesundefined Offline
    Steve James
    When I'm trip planning for multi-way trips I will generally create an overall route and then later break up into individual days.
    In that initial stage, it would be really useful if I could annotate the map with lines, text and area fills. I realise I can do this on Google Maps, but it would be really helpful to be able to do this in the route planner. The annotations would be an overlay only and not part of the routing or the export of the route.
    Do you have any plans to implement such an option or have I missed the feature?
    Thanks
    Steve
    • Leike Lodiersundefined Offline
      wrote last edited by Leike Lodiers
      When you open one of the route you made klick on the hamburger menu on the left side and klick on routes en you can add the other routes to you're open route!
      Van Zumo 550 naar Navigator V naar Carpe iter V4b met MRA
      • Steve Jamesundefined Steve James
        Thanks
        Steve
        Brian McGundefined Offline
        Hi @Steve-James I don't believe you have missed anything & as far as I know such a feature is not on the radar for the near future, maybe on some distant plan / wish list
        My suggestion to achieve sort of what you are after, all be it not within MRA, would be to use the windows Snip tool to clip a picture of your route.
        Open this picture in MS Paint & then use the Layers function to add each individual set of lines, areas or text.
        Use Layers so you can update the base route map when it changes & remove stuff thats out of date or errors
          Steve James
          Hi, Leike and Brian,
          Thanks for your suggestions.
          I'm typically looking at routes that take about a week, so circa 2,000 miles.
          I do use the overlay routes function, but that has a different purpose, although to some extent it could be used by creating 'non routes' that are in reality annotation.
          The MS Paint option isn't directly open to me as I use a Mac, but It's possible to do similar things with Google Earth etc. and you are on the right lines. I'll have to mark up a Google Earth image with something similar. I was just thinking that it would be much better within the app as the information is there whilst you are planning.
          Thanks again,
          Steve
          • Jörgenundefined Offline
            As explained above, it is possible.
            iPhone 12 pro (iOS 180.2)
            Oukitel RT3 (Andr. 12)
            Samsung XCover 4 (Andr. 9 Pie)
            For more information, (Workshops) click here
            Steve Jamesundefined 1 Reply Last reply
              Each color is a day tour.
              • Jörgenundefined Jörgen
                @Jörgen Hallo Jörgen,
                Ich hab dazu eine Frage...
                Ich kenne die Funktion Routen hinzufügen...
                Allerdings habe ich immer das Problem dass ich bei der ersten Route welche ich als Ausgangspunkt nehme immer die gesetzen Wegpunkte noch sehe, bei den hinzugefügten Routen erscheint dann der Track(ohne Wegpunkte)
                Wie schaffst Du es immer nur den Track zu sehen?
                Danke vorab.
                Gruß
                Peter
                BMW R 1250 GS
                BMW Connected Ride Cradle
                SPC Universal mount
                Motorola Edge 40
                Sena SLR 3
                Sena 50 R
                Lex.Kloet.RXundefined Jörgenundefined 2 Replies Last reply
                  Danke vorab.
                  Gruß
                  Peter
                  Lex.Kloet.RXundefined Offline
                  Lex.Kloet.RX
                  @Peter-Zehentreiter starte eine neue Route, mit nur 1 Waypoint, meinetwegen in Australien. Dann kannst du danach die Routen hinzufügen und siehst weiterhin keine detaillierte Route 😉
                  Geluk/verliefdheid is net als in je broek plassen. Iedereen ziet het alleen jij voelt het.
                    Danke vorab.
                    Gruß
                    Peter
                    @Peter-Zehentreiter said in Trip Planning - Overlay Mark Up:
                    Danke vorab.
                    Gruß
                    Peter
                    Eine Neue leere Route erstellen, z.B. "Alle Tage der Tour XYZ".
                    Dann in dieser nur die einzelnen Tage (Routen) über "Routen hinzufügen" hinzufügen.
                    Wenn man möchte, kann man in der Routen Information und Beschreibung noch was zu den Farben usw. sagen.
                    • Lex.Kloet.RXundefined Lex.Kloet.RX
                      @Lex.Kloet.RX @Jörgen
                      Hallo Ihr zwei,
                      herzlichen Dank für den Tip, so einfach… und doch wäre ich da nicht drauf gekommen.
                      BMW R 1250 GS
                      SPC Universal mount
                      Motorola Edge 40
                      Sena SLR 3
                      Sena 50 R
                        Steve James
                        @Jörgen
                        Thanks for responding. I already do what you have suggested. It is more the broader scale, a bit like Brian McG suggests but think for marking up thoughts for a planned route say from UK to Spain, tour around and then back. Putting some areas to include, marking towns to visit and adding notes. That sort of thing.
                        Steve
                          Steve James
                          Just incase anyone is interested, my latest work around is to use Google's mymaps, to overlay annotation on a google maps background with goolemaps functionality. You can share the overlay with others.
                          I've added a screenshot of the overall, plus a couple of 'zoom ins'. Note you can add information to the points, if you look at the ferry port icon that I added, I have been able to link to the ferry sailings schedule. All useful stuff in the early stages of planning, especially if sharing.
                          It's a shame that I can't select the overlay to be visible when planning on myrouteapp.
                          To do it this way would make implementation easier.
                          Steve
                          Lex.Kloet.RX
                          Steve James
                          • Routepunten overslaan zonder reden
                            2.6k
                          • GPS's that work well with Route Planner
                            richard 3vundefined
                            richard 3v
                          • MyRouteApp (WebPlanner) development Roadmap
                            Rainer Treichelundefined
                            Rainer Treichel
                          • Off Line Maps
                            Rainer Treichel
                          • Carpuride
                            paul69undefined
                          • Starting point?
                          • MRA Absturz - ohne Grund zweimal !
                            Peter Schieferundefined
                            Peter Schiefer
