  4. function EXPAND
function EXPAND
35 Posts 8 Posters 16.2k Views 3 Watching
  • Karel76 Offline
    Karel76 Offline
    Karel76
    I did not create it directly in OSM, but in MRA through the OSM layer, see picture. Yes in the settings it was zigzag, out of town, off highway. I liked the route and that's why I wanted to add more waypoints, so that the navigation (MRA) would navigate me exactly along this route, because I know that MRA follows HERE and it has a different algorithm for creating routes and would guide me differently. Unfortunately after adding 50 points it created a completely different route. I kindly assumed that it would add the points to my original route. Now I hastily made a second route and the same result.
    • Karel76 Offline
      Karel76 Offline
      Karel76
      there is link on second route
      https://www.myrouteapp.com/en/social/route/11665201?mode=share
      • Karel76 Offline
        Karel76 Offline
        Karel76
        there is video for example how created route
        https://k00.fr/kvxz2d3t
          Marinus van Deudekom Offline
          2 possibilitys
          When you’re done like in the first video, try to export that as a gpx track
          Then upload that gpx to MRA and open it while Here is your standard map
          2 put a lot shapingpoints, I mean a lot, by hand in that first route and then change the map to Here
          Jörgen 1 Reply Last reply
          • Jörgen Offline
            Jörgen Offline
            I am a bit confused? I usually use the same process with open street maps. I have no idea why you get a totally different route when you expand with more waypoints.
              2 possibilitys
              Jörgen Offline
              Jörgen Offline
              @Marinus-van-Deudekom said in function EXPAND:
              2 possibilitys
              I tried this as well and was surprised that the gpx file (the track) is different when you export (save) it from the original.
              Whats wrong here?
              I made routes with open street maps by using sections and curvy roads and filled it as well with waypoints to use it for navigation with Here map. I can't remember having this problem.
              • Karel76 Offline
                Karel76 Offline
                Karel76
                So probably a bug, because I used this feature once and it worked as it should. Now it's unusable. Thank you for your efforts. Is there any way to send this bug to the developers?
                • Jörgen Offline
                  Jörgen Offline
                  Yes, contact the support.
                    @Jörgen said in function EXPAND:
                    I am not so sure. This is not my method of creating routes, but isn't it so that Curvy options have some kind of randomness in it, exactly to prevent always getting the same roads? I am not surprised that this happens, I would be surprised about how it worked before when it did not change the route 😉
                      @Con-Hennekens I've created a route using that tool in the TomTom map and couldn't get rid of the algorithms when I extended the route with a piece of highway. The way out was then to export the curvy part as a gpx track with I then uploaded in MRA. Yep a bit complicated
                      • Karel76 Offline
                        Karel76 Offline
                        Karel76
                        So I found a bug. when I perform the same action on the base of TOM TOM maps, the "EXPAND" function works as I want. On the OSM base it generates a different route. I attach a video of the creation on TOM TOM
                        video TOM TOM (there is OK):
                        https://k00.fr/n1vrs605
                        video OSM (wrong route):
                        Erdna 1 Reply Last reply
                        • Jörgen Offline
                          Jörgen Offline
                          @Con-Hennekens that is also not my usually method.
                          But when I create a curvy route (with what ever map) it should be possible to use them in MRA navigation as created.
                          So, why is the exported gpx file already total different to what was seen on the screen?
                          And why do I get a totally different route, when I expand what I see on the screen?
                          • Karel76 Karel76
                            Erdna Offline
                            Erdna Offline
                            Erdna
                            @Karel76 said in function EXPAND:
                            That is not a bug. TomTom and OSM use different card material and different algorythms for calculation of the route. Compared with different setting like cury route, restrictions like don´t use highways, etc. that behaviour is absolutely normal.
                            • Jörgen Offline
                              Jörgen Offline
                              @erdna, you may be right. But this is not the point. Why is MRA making a totally different route when waypoints are added (with openstreet map)?
                              WP should be added to the route that was created with OPM as well as it is done with TT map.
                                Seemingly that is due to a randomize function in the automatic creation of scenic routes. A curvy route between 2 points can be different from a curvy route between three points, even when the middle point is on the original 2-point route. That does not sound completely illogical to me.
                                Remember that routes are calculated by the map-providers, not by MRA. Each map provider does things differently. That is nothing new.
                                Jörgen Travellexxie 2 Replies Last reply
                                • RainerT Offline
                                  RainerT Offline
                                  RainerT
                                  OK,
                                  I'll leave MRA and a software problem aside for now.
                                  Adding loads of shaping points seems impractical to me.
                                  There is <Compare route calculation with>.
                                  Then you set shaping points to make the routes congruent. Incidentally, that was one of the parts involved in the creation of MRA 🙂
                                  Or you can display the route as an overlay (on the left side of the menu). This would also work with a track log. Or simply the desired route. And on this basis, you then create a new route with the route engine of your choice.
                                  I find the first alternative nicer and faster.
                                  Interesting topic, maybe I'll add it to my to-do list for the next video conference.
                                  RT
                                    Jörgen Offline
                                    Jörgen Offline
                                    @Con-Hennekens said in function EXPAND:
                                    Ok, I understand that different maps generate different routes. The curvy function in OSM and TT are fine. And with TT generated routes, I can take them nearly 1:1 when I add WP to use with HERE (and navigation).
                                    But why does it not work with OSM (nearly like in TT)?
                                    If I can not use the generated route, what sens does this function make?
                                    Or, how to solve this issue easily? (ok, you could add WP manually
                                      Travellexxie Offline
                                      Sorry Con, but it is totally illogical. With this tool, one expects MRA maintains the route. The route is already calculated, why not put the new added points on the route "as is", that would be logical. There is no use of a "new calculation" because the parameters for calculating the route didn't change.
                                      • Travellexxie Offline
                                        By the way, I was there in that area, it is very nice!
                                        https://routes.lexwill.cyou/cabriotour-tsjechie-2025/
                                        • Travellexxie Travellexxie
                                          #27
                                          @Lex.Kloet.RX said in function EXPAND:
                                          Sorry Lex, but MRA maintains nothing except a web planner tool. Calculations are done by mapproviders. Each adding of a waypoint triggers recalculations. Rest assured: I really don't know whether OSM has randomize functions in it's curvy routes calculations or not. But what happens here makes me think so. And it would have a purpose. No one wants the exact same route each time they create a roundtour from home.
                                          But I agree completely that the difference shown by in the first post are pretty dramatic.
                                          RainerT
                                          RainerT
                                          martin-phogel.de
                                          martin-phogel.de
                                          Erdna
                                          Erdna
                                          Karel76
                                          Karel76
                                          • Welke instelling
                                            1.0k
                                            Thomas Schäfer
                                            Thomas Schäfer
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • Seizoen sluitingen wegen
                                            PAT62
                                            PAT62
                                          • App loopt vast
                                          • Rejoining routes
                                            Sytze van der Laan
                                            Sytze van der Laan
