  3. Show us your set up!
17 Posts 11 Posters 4.6k Views 9 Watching
  • stuart marrittundefined Offline
    stuart marritt
    Just thought I would start a new topic to give people inspiration of what set ups people have and what works well etc
    So show us the set up you are using for MRA with as much detail as possible
    I use a Samsung galaxy S20 fe with a quadlock case and mount on to a WunderLINQ box which allows me to control some aspects of MRA with the bmw wonder wheel
    The WunderLINQ clips directly in to the bmw nav prep and also allows charging from it too
    This is how it's mounted on my bmw r1200rt
    The phone I use is OK and plenty fast enough and bright enough to see in most conditions if anything I think I would prefer a slightly larger screen
    So come on don't be shy show us your set up and your pros and cons
    • stuart marrittundefined stuart marritt
      @stuart-marritt met me be the first to respond
      I use a Thork Racing DMD2 rugged device. The T865X aan 8 inch tablet with its own simcard in it. The device is 1300+ nits so gives me aan excellent view of the route. It is mounted with a DMD made mount that I've adjusted a bit to fit in the cockpit of my Goldwing.
      For backup I have a Samsung S20FE mounted on a Quadock wireless charged head. Never had to use it though.
      link text
        link text
        • Jörgenundefined Offline
          Oukitel RT3 Oudoor Tablet. Selfmade mont on Suzuki V-Strom 1000
          • martin-phogel.deundefined Offline
            martin-phogel.de
            DMD2 T665
            https://www.thorkracing.com/produto/dmd-t665-nav-phone/
            mounted on a Triumph Tiger 900 GT with
            https://www.evotechparts.com/de/Triumph-Tiger-900-Rally-Pro-Garmin-Navi-Halter.html
            mounted on an African Single with
            https://www.hermann-mechatronik.com/de/hm.php?tlc=products&lpd=A2001&vids=2-15
            (switched to DMD App in this pic)
              Travellexxieundefined Offline
              20250607_091403_web.jpg MRA Navigation-App in my Fiat 124 Spider Cabrio on a Samsung Tab Active4 Pro.
              • RainerTundefined Offline
                RainerT
                Danke für den Hermann-mechatronik Link oben. Das hat mir noch gefehlt.
                RT
                martin-phogel.deundefined 1 Reply Last reply
                • RainerTundefined RainerT
                  RT
                  martin-phogel.de
                  @Rainer-Treichel
                  Gibt es auch mit Kugelkopf. Qualitativ und funktional oberste Liga. Kein Vergleich zu RamMount.
                  • Hns_Brwrundefined Offline
                    Hns_Brwr
                    image.png Activetab 3 op mijne 1200x dmv een rammount
                    • Makroundefined Offline
                      Makro
                      wrote on last edited by Makro
                      Samsung Galaxy tab active 3 on my Kawasaki. It's in a Brodit active holder.
                      I first mounted it on the upper bar, which is an accessory. The device was shaking there while riding, because of the RAM mounts used. A better fitting solution would likely solve the problem, but I simply fitted it at the second best place, between the handlebars.
                      This solution is a lot cheaper than a DMD2 or Carpe Iter.
                      The fitted is fine tuned to my height, so I can see all the instruments and warning lights while riding.
                      Best regards, Makro
                      • Frank Schefflerundefined Offline
                        Frank Scheffler
                        wrote on last edited by Frank Scheffler
                        Ich nutze ein Carpuride W702 in Verbindung mit einem Honor 90 Smartphone an einer Kawasaki Versys 650. Klappt super. Als Navigation nutze ich MRA oder TomTom Go.
                          stuart marritt
                          Some good looking setups here! Keep them coming 👍
                            RainerT
                            Samsung Active 5 5G statt Carpuride. Danke an @Luc Wijdeveld
                            Der Halter fürs Smartphone bleibt als Backup.
                            stuart marrittundefined 1 Reply Last reply
                              stuart marritt
                              @Rainer-Treichel said in Show us your set up!:
                              What case is that for the tablet?
                              RainerTundefined 1 Reply Last reply
                              • Frank Schefflerundefined Frank Scheffler
                                R1250GS
                                • iPhone Xr
                                • BMW-Cradel (Induktiv laden)
                                • App = MRA Navigation (iOS)
                                • App = Kurviger (iOS)
                                • App = GuRuMaps (iOS) Offroad
                                Remotek One
                                • Zoomen und Wegepunkte überspringen
                                R1250GS Halteblech, Spiegel links
                                • es lässt sich so das WW und ROne gut bedienen
                                  RainerT
                                  @stuart-marritt
                                  https://www.amazon.de/dp/B08NT17LCD?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
                                  Super Qualität.
                                  Und ein Schutzglas habe ich auch noch angebracht.
                                  https://www.amazon.de/dp/B0CTBV37KR?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
                                  • Ewout Dundefined Offline
                                    Ewout D
                                    In de MGB een 7" draadloos Ali scherm (±€65) icm iPhone. Werkt uitstekend, goed overzicht en geluid via de telefoon. Mbv RAM Mount ook makkelijk op de R1200RT te monteren, geluid dan via de helm.
                                    stuart marritt
                                    Hns_Brwrundefined
                                    Hns_Brwr
                                    RainerTundefined
                                    RainerT
                                    Makroundefined
                                    Makro
                                    Frank Scheffler
                                    Ewout Dundefined
                                    Ewout D
                                    martin-phogel.de
                                      3.4k
                                      Massimo Cardoneundefined
                                      Massimo Cardone
                                    • Hi, new UK based user.
                                      richard 3vundefined
                                      richard 3v
                                      stuart marritt
