  4. Routeplanner options - twisty and height - where have they gone?
8 Posts 4 Posters 447 Views 2 Watching
  • iain.gardengmail.comundefined Offline
    When planning a route, there used to be options to select quick/winding/twisty roads and low/medium/large height variations. These seem to have disappeared. Why?
    Thanks
    • iain.gardengmail.comundefined iain.gardengmail.com
      Thanks
      Guzzistundefined Offline
      wrote last edited by Guzzist
      @iain.gardengmail.com if you have selected in options map algorithm:
      • "Standard (OpenStreetMap)" - then you can select in options / toolkit / curvy: low or mid or high
      • "TomTom" - then you can select in options / route optimation: quickest or shortest, and in "hight": low or mid or high, and in
        "curvy": low or mid or high
      • "HERE" - then you can not select such options
      All only, if you are "gold" member
      iain.gardengmail.comundefined 1 Reply Last reply
      • Guzzistundefined Guzzist
        @Guzzist Thanks.
        I am a gold Member and have selected Standard OpenStreetMap. The twisty / height options do not appear any longer. Out of interest, where do you select the OpenStreetMap option?
          You select the OpenStreetMap at A
          B shows the curvy route options, height options are only part of TomTom map.
          Don't use C to select a calculation map, The maps there are just overlays.
            Thanks, Con.
            But what happened to the height and curve options when creating a route in the route lab? I used to select them all the time when planning a multi-day holiday, but those options appear no longer to be offered to you.
            Also, I used to plan with the Here/MRA option, as I navigate with MRA on my trips. Should i plan in Tom Tom and then, when finished, convert to Here/MRA?
              Thanks, Con.
              @iain.gardengmail.com, This is in routelab 😉 .
              You are probably referring to the roundtrip generator? Yes indeed, those options have been removed and automated. It still gives great (and even better than before!) routes, doesn't it?
              • Rainer Treichelundefined Offline
                Rainer Treichel
                When planning with Here, you have the option of choosing the fastest route or the shortest route.
                However, this is only available in car mode!
                This option is not available in motorcycle mode.
                The shortest route is often an interesting choice, but it needs to be adjusted considerably. Then it becomes a beautiful route.
                RT
                Stammtisch Themen Anmeldung
                  Thanks, Con. I've not really used the new approach enough to judge whether it's better. But I'm about to!
                  Rainer Treichel
                  • MRA User map
                    RetiredWingManundefined
                  • Routepunten overslaan zonder reden
                    1.7k
                  • Indicator arrow drifts all over the map.
                  • App very laggy
                    Thomas Neumeyerundefined
                    Thomas Neumeyer
                  • When adding pauze in a route, it doesn't get calculated in the app
                  • Change Subscription Country
                  • Routes van vrienden bekijken
                  • Harde punten omzetten naar POI zodat ze in XT bij opgeslagen staan
