  4. Compass Rose
Compass Rose
15 Posts 9 Posters 4.5k Views 3 Watching
  • LennyO Offline
    LennyO Offline
    Hello, all!
    Can we PLAEASE, put a compass rose on the navigation screen, better yet have it as an option?
    This would help tremendously with all the confusion with North up, turning maps, etc,....
    THANK YOU!!!
    Herman Veldhuizen Marinus van Deudekom Nick Carthew 3 Replies Last reply
    • LennyO LennyO
      Hello, all!
      THANK YOU!!!
      Herman Veldhuizen Offline
      @Lenny-O As far as I know there is! And you can click on it to change the viewing mode.
      But there is a minor bug, which is that in North up mode the compass does not turn when I turn the map on the screen with two fingers. It does turn in the other modes. But when you select NorthUp why would you turn the map...
      Edit: reading this post again, I assume you meant a compass which turns with the phone. Yes that would be useful, then there is no need to use another app for that.
      • LennyO LennyO
        Hello, all!
        THANK YOU!!!
        Marinus van Deudekom Offline
        @Lenny-O When you click on the rose the camera view will change and you get a pop up witch camera view is then active.
        It's not a compass itself. I guess that's why you are a bitt confused
        • LennyO LennyO
          Hello, all!
          THANK YOU!!!
          Nick Carthew Offline
          @Lenny-O
          David Emmett 1 Reply Last reply
            @Lenny-O
            David Emmett Offline
            David Emmett
            I second this from @Nick-Carthew - making the north pointing half of that dial dark/red to make it clear which way north is.
            • Brian McG Offline
              Brian McG Offline
              If memory serves me at all, TomTom used to have compass/north pointing indicator built into the location triangle icon which I thought worked brilliantly
              (think it could be toggled to alternatively point to the destination)
              As you are constantly looking at your position location it was an very easy way to quickly know which direction you were headed
              • David Emmett David Emmett
                @David-Emmett said in Compass Rose:
                I hadn’t realised that I’d made a suggestion!
                I was merely pointing out the compass icon.
                David Emmett Con Hennekens 2 Replies Last reply
                • LennyO Offline
                  LennyO Offline
                  Actually @Nick-Carthew, I think that @David-Emmett suggestion is FANTASTIC!
                  Can we get it done?
                  Peter Zehentreiter Nick Carthew 2 Replies Last reply
                  • LennyO LennyO
                    Can we get it done?
                    Peter Zehentreiter Offline
                    @Lenny-O When I'm traveling in north-facing mode, north is always at the top of the map anyway, please correct me if I'm wrong.
                    That's why it's called north pointing!
                    Why then also the additional information in red on the compass?
                    BMW R 1250 GS
                    DMD-NOR7E 7"
                    SPC Universal mount
                    Motorola Edge 40 "offline"
                    Sena SLR 3
                    Sena 50 R
                    • LennyO LennyO
                      Can we get it done?
                      @Lenny-O The compass icon changes after you tap it to indicate which camera view is being used, so I’m not sure that suggestion would work now.
                      Personally, I know which general direction I am travelling in by knowing the direction of my route and by looking at the natural clues that surround me. The sun 🌞 being the biggest clue. So I’m not bothered about having a moving compass needle.
                      • David Emmett Offline
                        David Emmett
                        95% of the time, I know which direction I am heading in too. But there are times when I am riding a relatively convoluted route (because, why not?) and I have gone left-left-right-left-left-left-right so many times that I am briefly confused. And yes, I could (and do) use the sun to orientate myself (except when it's dark, of course), but a simple differentiation of the compass rose would make it much faster and less taxing. Which means I can focus more of my attention on the road, and on riding.
                        It is a very minor change with a big impact, in my opinion.
                          David Emmett
                          @Nick-Carthew Apologies. Perhaps I should have rephrased it. But that icon is exactly the one I would like to have a clearer distinction of north on.
                          • LennyO Offline
                            LennyO Offline
                            Ok, look here.
                            In this mode you can not tell looking at the compass which way is North.
                            I guess the point of the Navigation is to make my life easier and not resort to the starts, the sun and other ways to understand my position and direction 🙂
                            • JP d Offline
                              JP d Offline
                              JP d
                              I would like a way to turn the North view off, as I only use Dynamic and Top view. 🍻
                                @Nick-Carthew said in Compass Rose:
                                THAT are the most brilliant ones! 😉
                                JP d
                                JP d
                                David Emmett
                                David Emmett
                                  Philip Verbeek
                                  Philip Verbeek
                                • Questions and suggestions
                                  Mike wiruth
                                  Mike wiruth
                                • Rondrit maken lukt niet
                                  Rob Vonk
                                  Rob Vonk
