  4. MRA useless after I missed a route turn
13 Posts 9 Posters 3.0k Views 3 Watching
  • Jim O'Dowd
    Jim O'Dowd
    Jim O'Dowd
    Hello!
    I am still new to MRA and liking it very much. However, I had this experience that I wanted to share:
    I set up a new route in MRA desktop. It was a 360-mile route from my home (point A) to a destination in Arkansas (point B). There were no other intervening waypoints. I exported the route to my Garmin XT2 GPS and of course, it was on my Android Smartphone.
    Both the GPS and the Android Auto were tracking nicely until...at around 150 miles into the route, I decided to make a slight deviation, a bit of a known short cut...at this point, both the GPS and MRA on the smartphone decided to take me back to the point where I had deviated from the route.
    It was easy enough to correct this behavior on the GPS; I simply stopped navigating the route, then re-started navigation and selected the destination point and it recalculated and got me back on track from that point...all was good.
    However, I was unable to ever get the MRA app back on track. Part of this may be limitations on the Android Auto interface.
    This concerns me because I occasionally do take shortcuts, or miss waypoints, but I would like to keep on going on the route toward my destination.
    Is there any way I can set the navigation to stay on a route toward a destination, even if I miss a waypoint or alter the route? I don't want it to persist in navigating back to the waypoint or point at which I may have strayed from the route.
    I hope this makes sense and that there may be a solution. Of course, this may be an immutable feature of all GPS custom routes that cannot be changed...I hope not.
    Many thanks in advance,
    Jim O'Dowd
    Franklin, TN, USA
    Nick Carthew Travellexxie Con Hennekens 3 Replies Last reply
    • Jim O'Dowd Jim O'Dowd
      Hello!
      Jim O'Dowd
      Franklin, TN, USA
      @Jim-O-Dowd
      Do you not think that the opening sentence of your post could explain the rather unfair title of this topic?
      • stuart marritt
        stuart marritt
        stuart marritt
        I have to admit this is a bugbear of mine!
        I want to be able to set a destination and the navigation just re route you should you miss a turn without it going back! this is how most sat navs work.
        There should be an option of A to B and just take me there without trying to get you back on a route.
        I wouldn't call it useless though
        Jim O'Dowd 1 Reply Last reply
        • stuart marritt stuart marritt
          Jim O'Dowd
          Jim O'Dowd
          Jim O'Dowd
          @stuart-marritt yes, "useless" was a poor choice of words on my part...clearly, the problem was self-inflicted. I'm still very much in a learning mode here. But like you, I'm looking for a way around this issue...if there is one.
          • RetiredWingMan
            Where to start? You created a 360 mile route with no waypoints other than start and finish! Did you enable recalculations? Were you navigating the route as a track? This sounds like a recipe for disaster. The likelihood that the GPS device and MRA are going to deviate is virtually guaranteed.
            • Mzokk
              If you just want point to point navigation Google maps or Waze would do your job. I use Google maps for point to point navigation. MRA or your Zumo XT2 for that matter are designed for routes with multiple waypoints to take you on specific roads. I use mostly MRA for that type of navigation and a Zumo XT which is increasingly used as a backup or to handle my custom POI's
                Hello!
                Jim O'Dowd
                Franklin, TN, USA
                wrote on last edited by Travellexxie
                @Jim-O-Dowd
                @Jim-O-Dowd said in MRA useless after I missed a route turn:
                Yes, you can and the solution is quit simple. For A to B travels (with only start and finish), do NOT make a route. Just enter the address in your XT, hit start and have a lot of fun.
                  Hello!
                  Jim O'Dowd
                  Franklin, TN, USA
                  @Jim-O-Dowd, Just be be sure I understand you correctly: you "create" a route that in essence is a single destination on how to get there quickest, you export it to your Zumo to have it fuck it up for you, and then MRA gets the blame? Simply put there are two tribes here. The ones that say: "Why does it keep sending me back to my route", and the ones that say: "Why does it not send me back to my route"...
                  • paul69
                    no waypoints on 360 mile route, you have to take what you get, whether GPS, MRA, northern star or following a pigeon.
                    K1600 GTL
                    Oukitel RT3
                    iPhone 13 Pro, carpuride 702b
                    • paul69 paul69
                      @paul69 said in MRA useless after I missed a route turn:
                      following a pigeon.
                      Hahahahahahaha this would always be the safest bet! Nature knows best! Pigeons fly all over the world without consulting any satellite, now that(!) is impressive! 😀
                      paul69 1 Reply Last reply
                        following a pigeon.
                        @Stefan-Hummelink
                        indeed, i always have one in my pannier in case of satnav failure, 🤣
                        although it becomes a nuisance when he crosses a large expanse of water, it takes some time to locate him on the other side when i have detoured. 🦅 (not strictly a pigeon)
                        K1600 GTL
                        Oukitel RT3
                        • Con Hennekens
                          @paul69, sounds like you need to enable offroad mode...
                          • Nick Carthew
                            This topic seems to have been answered and has run it’s course so I will lock it.
                            • Nick Carthew Nick Carthew locked this topic on
                            stuart marritt
                            stuart marritt
                            Jim O'Dowd
                            Jim O'Dowd
                            • Statement on map spinning
                              hawebo
                              hawebo
                              1.7k
                            • Electric Car Travel Mode
                            • MRA 6.0.0 (515) Night mode
