  3. Shuberth C4 pro
Shuberth C4 pro
6 Posts 2 Posters 2.3k Views
  • Drabslab
    Does anyone have this helmet?
    I just bought one 😖 👹 and the first ride I experienced a terrible noise. Like a steam kettle from 90 km/h onwards.
    Anybody with the same experience?
    • Drabslab Drabslab
      @Drabslab i can’t help with the C4, but I have a C3 Pro and I find it very quiet.
      Drabslab 1 Reply Last reply
        @Nick-Carthew problem solved (sort of).
        The C4 pro has a big opening on top for ventilation and this is creatign a heap of turbulence leadign to a steam cettle noise. A piece of tape covering that opening is enough to make it stop. Now I need to find a more eye pleasing solution 🙂
        • Drabslab Drabslab
          @Drabslab Could you take the lining out and seal the vent from the inside?
            @Nick-Carthew that is an option but with consequence of loosing the ventilation ... which can be very useful in the south of France 🙂
            I am experimenting with small pieces of foam that let some air through, but prevent the wind from making turbulence
            • Drabslab Drabslab
              Just to come back to this issue.
              This whole helmet purchase (two helmets, two SC1 advanced) is becoming a real frustration.
              Just as a warning to fellow motorcyclists:
              Don't let the reputation of the brand fool you:
              The helmet is noisy, the ventilation on top catches turbulent air and whistles as a steam cettle
              The SENA communication system is a letdown:
              • complicated to use, for setting it up you must use combinations of pushes on tiny buttons (try to remember them all)
              • virtually impossible to use with gloves
              • user manual should get a reward for explaining the most simple things a complex as possible
              If onlythis stuff would not be so expensive, I could throw it away
              • Kaart niet zichtbaar
                Bé Jeuring
                Bé Jeuring
              • Xpert overlay not clear
                Corrado Miniati 0
                Corrado Miniati 0
              • Google maps
                Ed Bos 0
                Ed Bos 0
              • Trains like Ferries?
                Corrado Miniati 0
                Corrado Miniati 0
