  3. SilverFox Controller C 1
83 Posts 9 Posters 68.5k Views 6 Watching
  • Jay Salvo Jay Salvo
    @Peter-Zehentreiter If you sort skipping waypoints easily Id be interested in that too😀
    Peter Zehentreiter Offline
    @Jay-Salvo Hi Jay, I got it 🙂
    This link leads to the SilverFox Bluetooth controller commands:
    According to the commands listed in the table, the code "D" is the relevant command for skipping waypoints.
    On the SilverFox website: https://www.silverfoxcontrollers.com/motorcycle-navigation-installation, you can find further information about which commands the two joysticks can execute.
    According to this description, you need to push the control joystick up and hold it briefly.
    I've tested it; it works for both via and shaping points.
    Jay Salvo 1 Reply Last reply
      Jay Salvo Offline
      Jay Salvo Offline
      Jay Salvo
      @Peter-Zehentreiter That's Brilliant, a huge thank you, I will have a play this weekend to see it working.👍
      Kenny Thierens 1 Reply Last reply
        Kenny Thierens Offline
        Kenny Thierens
        @Jay-Salvo so, the combination T865x with C1 controller is working well for you now that it's BT connected? All major functions are working? If so, I'll order one too. Just need to adjust it a bit to fit on my R1200RT handlebar.
        '07 BMW R1200RT
        DMD² T865x tablet
        Silverfox C1 controller
        Samsung S24+
        Cardo Spirit HD headset
        Arjan de Vries Jay Salvo 2 Replies Last reply
        • Kenny Thierens Kenny Thierens
          Arjan de Vries Offline
          Arjan de Vries
          Would you prefer c1 above h1? Why or why not?
            @Arjan-de-Vries It depends what bike do you have and how much space do you have on your handlebar.
            I checked the specs on the SilverFox Website and came to the solution that all controller can do almost the same.
            For my GS 1250 the C1 was the best solution (in my opinion)
              Jay Salvo Offline
              Jay Salvo Offline
              Jay Salvo
              @Kenny-Thierens Hi Kenny, I can get it to work with bluetooth connection but still not working with cable connection. After every update the tablet receives (which seems like 1 every other day) I have to go back in and reset the button configuration. It's a great system when working but very buggy. I can get it to work brilliantly with Kurviger though which isn't listed as a supported app so I will be using that until MRA sort the cable issue. I've messaged Joao on the DMD2 forum about it and he replied its on his Todo list but I can't see him rushing to sort as it doesn't effect their app. I think it will require a collaboration of MRA, Silverfox and users to nag him to move it along.
              • Corjan Meijerink Offline
                Can confirm the C1 controller will have full support starting the 4.3.9 update. In F1 mode you can use MRA.
                Manuals will be updated accordingly.
                Compared to B8J / H1 controller you have one extra feature, the "fit route".
                Kenny Thierens Guzzist Peter Zehentreiter 4 Replies Last reply
                  Kenny Thierens
                  wrote on last edited by Kenny Thierens
                  #46
                  @Corjan-Meijerink heel leuk om te horen. En toevallig net vandaag heb ik de C1 controller op m'n RT gemonteerd en gekoppeld met de tablet. Dikke merci voor je moeite en doe zo verder🙌
                  '07 BMW R1200RT
                  DMD² T865x tablet
                  Samsung S24+
                    Guzzist Offline
                    Guzzist Offline
                    @Corjan-Meijerink said in SilverFox Controller C 1:
                    Can confirm the C1 controller will have full support starting the 4.3.9 update...
                    Great step forward! Thank you very much @Corjan-Meijerink. At least, DMD Remotecontroller-2 is still missing to be integrated 😉
                      #48
                        Does that mean that MRA is running in the future under F1 mode?
                        Currently MRA is running under F2 mode!
                          F2 indeed - my bad 🙂
                          • Kenny Thierens Offline
                            Kenny Thierens
                            @Arjan-de-Vries
                            '07 BMW R1200RT
                            DMD² T865x tablet
                            Samsung S24+
                              @Jay-SalvoI In our Button app we can disable cable connection, do you have the same possibility in your Button app?
                              Arjan de Vries
                              @Peter-Zehentreiter Hi,
                              Was there a reason to choose the C1 instead of the H1?
                              I am still in doubt.
                              Arjan
                              Peter Zehentreiter Corjan Meijerink 2 Replies Last reply
                                Arjan
                                @Arjan-de-Vries The answer was already given in post #43
                                Corjan already confirmed that C1 is having a extra feature compared to the BJ8 / H1 controller.
                                • Arjan de Vries Offline
                                  Arjan de Vries
                                  Thx. Missed that one
                                    Arjan
                                    @Arjan-de-Vries personally the main choice would be deciding if you’d prefer another joystick or 3 buttons 😉
                                    That said, the C1 is a more compact design and fits better on my bike (not that the B8J or H1 did not fit nice, this one is just slightly more slick)
                                    Arjan de Vries 1 Reply Last reply
                                      Arjan de Vries
                                      wrote on last edited by Arjan de Vries
                                      #56
                                      @Corjan-Meijerink are the joysticks more easy than the buttons?
                                      When it will be available in the mra shop?
                                        Arjan de Vries
                                        @Corjan-Meijerink So you have the c1 on your triumph tiger? (I have a 800 xcx tiger)
                                          It's a preference, got used to them by now. Instinctively the button version makes more sense but the C1 is more compact, you get used to the extra joystick and get an extra feature.
                                          I indeed have the C1 controller mounted. Absolutely love SilverFox quality products.
                                          We've ordered C1 units for reselling - expecting them in our webshop in 2/3 weeks.
                                          • 4
                                          • 5
                                          Arjan de Vries
                                          Arjan de Vries
                                          Kenny Thierens
                                          Kenny Thierens
                                          José Fernando
                                          José Fernando
                                          Jay Salvo
                                          Jay Salvo
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • scherm bevrirzing
                                          • Update 5.2.2 - Quick fix
                                            1.3k
                                          • Position Arrow
                                            Huibertus
                                            Huibertus
                                          • Carpuride W702 icm Carplay
                                            17.5k
