  3. SilverFox Controller C 1
83 Posts 9 Posters 71.9k Views 6 Watching
  • Kenny Thierens Kenny Thierens
    @Jay-Salvo did you already tried bluetooth connection instead of wired?
    @Kenny-Thierens I also mentioned that issue 15 days ago to him......I also think, that could be an issue.
      Jay Salvo
      Jay Salvo
      Jay Salvo
      @Kenny-Thierens no it’s wired, I can’t easily disconnect the wiring to try Bluetooth as it’s buried in the bike. All other navigation platforms work with a wired connection
      • Jay Salvo Jay Salvo
        @Jay-SalvoI In our Button app we can disable cable connection, do you have the same possibility in your Button app?
        Jay Salvo Arjan de Vries 2 Replies Last reply
          @Kenny-Thierens @Peter-Zehentreiter confirmed it worked as expected! So I trust that is the case 🙂
          I did receive the new SilverFox controller but have not yet connected it to power. Hopefully I get around doing that next week.
          @Corjan-Meijerink The only thing I´d like to know... is there a possibilty to skip waypoints with the controller, if yes please be so kind and explain how to do.
          Thanks in advance
          Peter
            Jay Salvo
            Jay Salvo
            Jay Salvo
            @Peter-Zehentreiter Thank you Peter, just gone and tried it and it works via the Bluetooth although as soon as power is lost I have to reconnect bluetooth again and deselect cable in the buttons app.
              @Jay-Salvo I am glad to read that you can celebrate at least a partial success
              Jay Salvo 1 Reply Last reply
                Jay Salvo
                Jay Salvo
                Jay Salvo
                @Peter-Zehentreiter If you sort skipping waypoints easily Id be interested in that too😀
                Peter Zehentreiter 2 Replies Last reply
                  @Jay-Salvo I'll keep you informed 😉
                    @Jay-Salvo Hi Jay, I got it 🙂
                    This link leads to the SilverFox Bluetooth controller commands:
                    According to the commands listed in the table, the code "D" is the relevant command for skipping waypoints.
                    On the SilverFox website: https://www.silverfoxcontrollers.com/motorcycle-navigation-installation, you can find further information about which commands the two joysticks can execute.
                    According to this description, you need to push the control joystick up and hold it briefly.
                    I've tested it; it works for both via and shaping points.
                      Jay Salvo
                      Jay Salvo
                      Jay Salvo
                      @Peter-Zehentreiter That's Brilliant, a huge thank you, I will have a play this weekend to see it working.👍
                      Kenny Thierens 1 Reply Last reply
                        Kenny Thierens
                        Kenny Thierens
                        Kenny Thierens
                        @Jay-Salvo so, the combination T865x with C1 controller is working well for you now that it's BT connected? All major functions are working? If so, I'll order one too. Just need to adjust it a bit to fit on my R1200RT handlebar.
                        '07 BMW R1200RT
                        DMD² T865x tablet
                        Silverfox C1 controller
                        Samsung S24+
                        Cardo Spirit HD headset
                        Arjan de Vries Jay Salvo 2 Replies Last reply
                          Arjan de Vries
                          Arjan de Vries
                          Arjan de Vries
                          Would you prefer c1 above h1? Why or why not?
                            @Arjan-de-Vries It depends what bike do you have and how much space do you have on your handlebar.
                            I checked the specs on the SilverFox Website and came to the solution that all controller can do almost the same.
                            For my GS 1250 the C1 was the best solution (in my opinion)
                              Jay Salvo
                              Jay Salvo
                              Jay Salvo
                              @Kenny-Thierens Hi Kenny, I can get it to work with bluetooth connection but still not working with cable connection. After every update the tablet receives (which seems like 1 every other day) I have to go back in and reset the button configuration. It's a great system when working but very buggy. I can get it to work brilliantly with Kurviger though which isn't listed as a supported app so I will be using that until MRA sort the cable issue. I've messaged Joao on the DMD2 forum about it and he replied its on his Todo list but I can't see him rushing to sort as it doesn't effect their app. I think it will require a collaboration of MRA, Silverfox and users to nag him to move it along.
                                Can confirm the C1 controller will have full support starting the 4.3.9 update. In F1 mode you can use MRA.
                                Manuals will be updated accordingly.
                                Compared to B8J / H1 controller you have one extra feature, the "fit route".
                                Kenny Thierens Guzzist Peter Zehentreiter 4 Replies Last reply
                                  Kenny Thierens
                                  Kenny Thierens
                                  Kenny Thierens
                                  wrote on last edited by Kenny Thierens
                                  #46
                                  @Corjan-Meijerink heel leuk om te horen. En toevallig net vandaag heb ik de C1 controller op m'n RT gemonteerd en gekoppeld met de tablet. Dikke merci voor je moeite en doe zo verder🙌
                                  '07 BMW R1200RT
                                  DMD² T865x tablet
                                  Samsung S24+
                                    @Corjan-Meijerink said in SilverFox Controller C 1:
                                    Can confirm the C1 controller will have full support starting the 4.3.9 update...
                                    Great step forward! Thank you very much @Corjan-Meijerink. At least, DMD Remotecontroller-2 is still missing to be integrated 😉
                                      #48
                                        Does that mean that MRA is running in the future under F1 mode?
                                        Currently MRA is running under F2 mode!
                                          F2 indeed - my bad 🙂
                                          • 4
                                          • 5
                                          Arjan de Vries
                                          Arjan de Vries
                                          Kenny Thierens
                                          Kenny Thierens
                                          José Fernando
                                          José Fernando
                                          Jay Salvo
                                          Jay Salvo
                                            Glenn.B
                                            Glenn.B
                                            3.6k
                                            Robineke
                                            Robineke
                                            Reinhard Grossmann h 0
                                          • Overlay Routes like the App does and waypoints without routes
                                            Rob Kelley
                                            Rob Kelley
                                          • Route Breakdown
                                            Scarecrow
                                            Scarecrow
                                          • Brittany routes
                                            Tony 13
                                            Tony 13
                                          • Vergrendel scherm zet alles op z'n kop
