  3. SilverFox Controller C 1
83 Posts 9 Posters 77.2k Views 6 Watching
    @Jay-Salvo Hi Jay, I don't know if this is relevant for you, I had to install the Button App to get Apps of the F1 Mode running "Google Maps" Riku from SilverFox told me, I have to make sure that the cable connection has to be disabled.
    You are writing, that you are using the cable connection maybe that is causing some problems on your side ?
    Jay Salvo
    Jay Salvo
    Jay Salvo
    @Peter-Zehentreiter Hi Peter, as Im using the DMD2 tablet it already has the button app when shipped, I've updated it and the C1 works in Googlemaps with cable connection as do Waze, Kurviger and DMD2 but MRA won't. I can't easily disconnect it to try the C1 with bluetooth on MRA so I will have to wait and see how Corjan gets on when he receives his C1.
    Kenny Thierens Guzzist 2 Replies Last reply
    • Jay Salvo Jay Salvo
      Kenny Thierens
      Kenny Thierens
      Kenny Thierens
      @Corjan-Meijerink Sorry to bother you. Have you had a chance to test your new C1 controller? Once I am sure all functions work in MRA Navigation, I will order this controller.
      Thank you in advance.
      '07 BMW R1200RT
      DMD² T865x tablet
      Silverfox C1 controller
      Samsung S24+
      Cardo Spirit HD headset
        @Jay-Salvo said in SilverFox Controller C 1:
        ...Im using the DMD2 tablet it already has the button app when shipped, I've updated it...
        Please, how could you update the Button App? Which version do you have on your device now?
        Jay Salvo Peter Zehentreiter 3 Replies Last reply
        • Guzzist Guzzist
          Jay Salvo
          Jay Salvo
          Jay Salvo
          @Guzzist Hi they sent me an email, this it it pasted(im just trying to work out how I can pass you the zip file they sent:
          We have done integration work with DMD2 app and Firmware update for C1 controller is needed.
          After this update, F-mode toggle is implemented by "pinching" the joysticks: The Control (left) joystick to right and The Panning (right) joystick to left.
          After this update in F1 mode, you can define all Controller joystick moves (4 of them) into action in DMD2 app. As well the cable connection is now fully supported in DMD2 and Buttons app.
          Please follow the link https://www.silverfoxcontrollers.com/c1update for installation instructions.
          The update file is attached on this email
          Sama suomeksi:
          Olemme tehneet integrointityötä DMD2 ohjelman kanssa ja Firmware päivitys C1 ohjaimeen on tarpeen.
          Tämän päivityksen jälkeen F-moodit vaihtuu "puristamalla" joystickeja toisiaan kohden: Vasenta oikealle ja Oikeaa vasemmalle.
          Päivityksen jälkeen F1 tilassa voit määritellä kaikki 4 suuntaa DMD2 toiminnoiksi. Myös kaapeliyhteys (serial connection) on täysin tuettu DMD2 ja Buttons -ohjelmissa.
          Seuraa linkkiä https://www.silverfoxcontrollers.com/c1update
          Päivitys tiedosto on liitetiedostona tässä sähköpostissa.
          Best Regards
          Riku Pasanen
          tel+358 40570 2779
          www.facebook.com/SilverFoxcontrollers
          • Guzzist Guzzist
            Jay Salvo
            Jay Salvo
            Jay Salvo
            wrote on last edited by Jay Salvo
            #23
            @Guzzist You can download it from their site here:
            Guzzist 1 Reply Last reply
              @Jay-Salvo thank you very much for detailed information. But I just wondered how to update the Button App. I don't intend to use SilverFox controller.
              • Guzzist Guzzist
                @Guzzist Do not know whether it is helpful for you.
                I have the Button App installed as a single app on my Android.
                To update the app I have just top open the app and if there ist an update available, the app ist asking me if I want to update.
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Motorola Edge 40 "offline"
                Sena SLR 3
                Sena 50 R
                  @Peter-Zehentreiter ah - ok, understood. But it sounds, the Button app was used on DMD device - therefore I have asked, because on DMD you should not use Playstore for updates.
                  • Guzzist Guzzist
                    @Guzzist My button app isn't from the Play Store either. You can find the app as an "APK file" either in the DMD forum or on the SilverFox website.
                    BMW R 1250 GS
                    DMD-NOR7E 7"
                    SPC Universal mount
                    Sena SLR 3
                    Sena 50 R
                    • Kenny Thierens Kenny Thierens
                      @Kenny-Thierens @Peter-Zehentreiter confirmed it worked as expected! So I trust that is the case 🙂
                      I did receive the new SilverFox controller but have not yet connected it to power. Hopefully I get around doing that next week.
                      Jay Salvo Peter Zehentreiter José Fernando 3 Replies Last reply
                        Jay Salvo
                        Jay Salvo
                        Jay Salvo
                        @Corjan-Meijerink Hi, ive update everything but I cant zoom in and out with the joystick on the C1, The left joystick does nothing in MRA but works in other apps. I have a wired connection. Look forward to seeing if you have the same problem and cant resolve it. Thanks.
                        Kenny Thierens 1 Reply Last reply
                          Kenny Thierens
                          Kenny Thierens
                          Kenny Thierens
                          @Jay-Salvo did you already tried bluetooth connection instead of wired?
                          '07 BMW R1200RT
                          DMD² T865x tablet
                          Samsung S24+
                          Peter Zehentreiter Jay Salvo 2 Replies Last reply
                            @Kenny-Thierens I also mentioned that issue 15 days ago to him......I also think, that could be an issue.
                            BMW R 1250 GS
                            DMD-NOR7E 7"
                            SPC Universal mount
                            Sena SLR 3
                            Sena 50 R
                              Jay Salvo
                              Jay Salvo
                              Jay Salvo
                              @Kenny-Thierens no it’s wired, I can’t easily disconnect the wiring to try Bluetooth as it’s buried in the bike. All other navigation platforms work with a wired connection
                                @Jay-SalvoI In our Button app we can disable cable connection, do you have the same possibility in your Button app?
                                BMW R 1250 GS
                                DMD-NOR7E 7"
                                SPC Universal mount
                                Sena SLR 3
                                Sena 50 R
                                Jay Salvo Arjan de Vries 2 Replies Last reply
                                  @Corjan-Meijerink The only thing I´d like to know... is there a possibilty to skip waypoints with the controller, if yes please be so kind and explain how to do.
                                  Thanks in advance
                                  Peter
                                  BMW R 1250 GS
                                  DMD-NOR7E 7"
                                  SPC Universal mount
                                  Sena SLR 3
                                  Sena 50 R
                                    Jay Salvo
                                    Jay Salvo
                                    Jay Salvo
                                    @Peter-Zehentreiter Thank you Peter, just gone and tried it and it works via the Bluetooth although as soon as power is lost I have to reconnect bluetooth again and deselect cable in the buttons app.
                                      @Jay-Salvo I am glad to read that you can celebrate at least a partial success
                                      BMW R 1250 GS
                                      DMD-NOR7E 7"
                                      SPC Universal mount
                                      Sena SLR 3
                                      Sena 50 R
                                      Jay Salvo 1 Reply Last reply
                                        Jay Salvo
                                        Jay Salvo
                                        Jay Salvo
                                        @Peter-Zehentreiter If you sort skipping waypoints easily Id be interested in that too😀
                                        Peter Zehentreiter 2 Replies Last reply
                                          @Jay-Salvo I'll keep you informed 😉
                                          BMW R 1250 GS
                                          DMD-NOR7E 7"
                                          SPC Universal mount
                                          Sena SLR 3
                                          Sena 50 R
                                          • 4
                                          • 5
                                          Arjan de Vries
                                          Arjan de Vries
                                          Kenny Thierens
                                          Kenny Thierens
                                          José Fernando
                                          José Fernando
                                          Jay Salvo
                                          Jay Salvo
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                          • Download club route folders
                                            Mosimann
                                            Mosimann
