  4. Another day MyRoute-app screwed up My Route
52 Posts 6 Posters 34.4k Views 2 Watching
    @Ton-Machielsen Looking at your route itself raises a lot of issues. Only waypoint 14 and 17 are ON the route. The rest is of or even way of. That's a chance to get your route to get messed up.
    Are You navigation with the Next app of are you using a dedicated device.
    If you're navigating with the next app witch settings are you using. Did you select start navigating from the nearest waypoint. If you are in fact linvibng near waypoint 18 and you have that setting active it's by design that youy are routed home, since that's the nearest waypoint.
    Add some screeshots of your settings
    Ton Machielsen
    Ton Machielsen
    Ton Machielsen
      @Ton-Machielsen witch version of the app are you running
      Ton Machielsen
      Ton Machielsen
      Ton Machielsen
      @Marinus-van-Deudekom 4.3.7 - 385
      • Ton Machielsen Ton Machielsen
        @Ton-Machielsen you seem to have all the settings OK
        How dit you start to route. Did you select start from the nearest waypoint. That would be the main problem since you started near your home and that's the end of the route so would be the nearest waypoint
        Ton Machielsen 1 Reply Last reply
          Ton Machielsen
          Ton Machielsen
          Ton Machielsen
          @Marinus-van-Deudekom I select the route and then click Navigate.
            @Ton-Machielsen and if you selecte navigate Do You see the hand sign (viapoint) nr 1 on your screen's right top
            Marinus van Deudekom Ton Machielsen 2 Replies Last reply
              @Marinus-van-Deudekom If I click on navigate your route I'm beeing directed to wapoint nr 4, witch is the clossest waypoint from the Netherlands. Therefore trying to let you see that navigating automatic chioses the nearest waypoint on the route
                Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                I get 18…
                On the CarPlay I get none.
                Marinus van Deudekom M. Schrijver 2 Replies Last reply
                  Something to add to your comment.
                  When waypoints are way off route/road and you're riding a route (not a track). How can MRA Navigation (or other navigation) hit those waypoints when they are not on the road or very close to the road.
                  Those waypoints causes recalculations just because the waypoints are too far off-road.
                    I get 18…
                    @Ton-Machielsen there you have it. The app is trying to get you to the nearest waypoint, that would be nr 18. Since you know where waypoint 1 is, you've driving towards that waypoint nr 1 and meanwhile the app tries to get you to go to waypoint 18.
                    The fact that your waypoints are not ON the route is not good but the aopp will disregard those of route waypoints and try to navigate as close as possible to thoes waypoints. Your problems lies in the fact that you didn't not selct waypoint 1
                      Ton Machielsen
                      Ton Machielsen
                      Ton Machielsen
                      @M-Schrijver Understand. That’s why I am suggesting a radius for the waypoint hits. If you pass the waypoint within that distance the waypoint is considered as hit.
                      Marinus van Deudekom M. Schrijver richtea999 3 Replies Last reply
                        I get 18…
                        @Ton-Machielsen
                        Ahh cause found.
                        You've select "start at nearest waypoint" that is Waypoint 18 in your case. Unselect this option and try again.
                          @Ton-Machielsen when navigating with the nex app is will go OK. If you would use such a route in lets say an Garmin XT, you would be in great trouble.
                          That's why we have and use MRA next
                            @Ton-Machielsen
                            There is already a radius. But this radius is limited for a reason. Point 7, 11, 12 and 16 on route shows why. It is normal practice that you do your best to place the waypoints on the road.
                              @Ton-Machielsen
                              Ahh cause found.
                              Ton Machielsen
                              Ton Machielsen
                              Ton Machielsen
                                @Ton-Machielsen
                                Ahh cause found.
                                Ton Machielsen
                                Ton Machielsen
                                Ton Machielsen
                                @M-Schrijver Where can I find this setting?
                                  It is the first option below de "start" button
                                  • Ton Machielsen
                                    Ton Machielsen
                                    Ton Machielsen
                                    Ha! Never seen that menu before!! Thanks!
                                    • Ton Machielsen
                                      Ton Machielsen
                                      Ton Machielsen
                                      Any idea why I don’t get the waypoint hand and Skip Waypoint icon on the CarPlay? (see https://forum.myrouteapp.com/post/61333)
                                      Remember I am on a bike. I have the phone in my pocket and am navigating through the CarPlay device.
                                        @Ton-Machielsen Due to restrictions by Apple and Google the viapoint sign is NOT on Androis Auto and Carplay
                                          Ton Machielsen
                                          Ton Machielsen
                                          Ton Machielsen
                                          @M-Schrijver Is the “Navigate routes as tracks” option my solution?
                                          Carl Lee
                                          Carl Lee
                                          Ton Machielsen
                                          Ton Machielsen
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
                                          • Download club route folders
