  4. Another day MyRoute-app screwed up My Route
52 Posts 6 Posters 35.0k Views 2 Watching
    @Ton-Machielsen you need to copy paste the url of the route here. 🙂
    Ton Machielsen
    Ton Machielsen
    Ton Machielsen
    @Marinus-van-Deudekom https://www.myrouteapp.com/en/social/route/10719669?mode=share
    • richtea999
      @Ton-Machielsen I guess you mean this one:
      https://www.myrouteapp.com/route/open/10719669
      OK, a few thoughts/suggestions:
      • point 1 is not on a road, so there's quite a high chance that you didn't pass through it as you set off. An easy fix is to just shift it a little way ahead of where you start from, and put it directly on that road
        Like so:
      • most of your waypoints aren't on a road - they're just kind of close. Use the magnifying glass to zoom in and get them on the road. (The magnifying glass is in the pop-up that is shown when you click on a waypoint.) Waypoint 7, for example, is right between two roads:
      I'm guessing the road to the left is the 'correct' road, but you will have got taken along the right one, and then back again, I think. Quite frustrating!
      The same for waypoints 6, 11, 12, 16.
      Lastly, the end waypoint isn't on a road either. I'd put it say 100 metres before your destination, just so you're guaranteed to pass through it.
      I've made a corrected route for comparison:
      https://www.myrouteapp.com/en/social/route/10725113?mode=share
      Lastly, another reason to be very accurate with waypoint placement is on dual carriageways - I'm sure you can imagine the pain caused by selecting the wrong side of the carriageway!
      I'm sure there are other improvements, but those came to mind immediately.
      I hope that helps you a little.
      Ton Machielsen 1 Reply Last reply
      • Ton Machielsen Ton Machielsen
        @Ton-Machielsen Looking at your route itself raises a lot of issues. Only waypoint 14 and 17 are ON the route. The rest is of or even way of. That's a chance to get your route to get messed up.
        Are You navigation with the Next app of are you using a dedicated device.
        If you're navigating with the next app witch settings are you using. Did you select start navigating from the nearest waypoint. If you are in fact linvibng near waypoint 18 and you have that setting active it's by design that youy are routed home, since that's the nearest waypoint.
        Add some screeshots of your settings
        Ton Machielsen M. Schrijver 2 Replies Last reply
        • richtea999 richtea999
            Like so:
          Ton Machielsen
          Ton Machielsen
          Ton Machielsen
          wrote on last edited by Ton Machielsen
          @richtea999 Yes, that helps. I never realised that you need to be that precise. I always assumed (ass u me makes an ass out of you and me) that if the route was correct, all would be hokeydokey. Thanks for the tip. I think we need a “touch circle” for the waypoints so if they are not precisely on a road they do get hit.
          Any idea whether I am supposed to get the “Skip Waypoint” icon on the screen and when not?
            @Ton-Machielsen witch version of the app are you running
              Ton Machielsen
              Ton Machielsen
              Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                @Marinus-van-Deudekom 4.3.7 - 385
                  @Ton-Machielsen you seem to have all the settings OK
                  How dit you start to route. Did you select start from the nearest waypoint. That would be the main problem since you started near your home and that's the end of the route so would be the nearest waypoint
                    Ton Machielsen
                    Ton Machielsen
                    Ton Machielsen
                    @Marinus-van-Deudekom I select the route and then click Navigate.
                      @Ton-Machielsen and if you selecte navigate Do You see the hand sign (viapoint) nr 1 on your screen's right top
                      Marinus van Deudekom Ton Machielsen 2 Replies Last reply
                        @Marinus-van-Deudekom If I click on navigate your route I'm beeing directed to wapoint nr 4, witch is the clossest waypoint from the Netherlands. Therefore trying to let you see that navigating automatic chioses the nearest waypoint on the route
                          Ton Machielsen
                          Ton Machielsen
                          Ton Machielsen
                          I get 18…
                          On the CarPlay I get none.
                          Marinus van Deudekom M. Schrijver 2 Replies Last reply
                            Something to add to your comment.
                            When waypoints are way off route/road and you're riding a route (not a track). How can MRA Navigation (or other navigation) hit those waypoints when they are not on the road or very close to the road.
                            Those waypoints causes recalculations just because the waypoints are too far off-road.
                              I get 18…
                              @Ton-Machielsen there you have it. The app is trying to get you to the nearest waypoint, that would be nr 18. Since you know where waypoint 1 is, you've driving towards that waypoint nr 1 and meanwhile the app tries to get you to go to waypoint 18.
                              The fact that your waypoints are not ON the route is not good but the aopp will disregard those of route waypoints and try to navigate as close as possible to thoes waypoints. Your problems lies in the fact that you didn't not selct waypoint 1
                                Ton Machielsen
                                Ton Machielsen
                                Ton Machielsen
                                @M-Schrijver Understand. That’s why I am suggesting a radius for the waypoint hits. If you pass the waypoint within that distance the waypoint is considered as hit.
                                Marinus van Deudekom M. Schrijver richtea999 3 Replies Last reply
                                  I get 18…
                                  @Ton-Machielsen
                                  Ahh cause found.
                                  You've select "start at nearest waypoint" that is Waypoint 18 in your case. Unselect this option and try again.
                                    @Ton-Machielsen when navigating with the nex app is will go OK. If you would use such a route in lets say an Garmin XT, you would be in great trouble.
                                    That's why we have and use MRA next
                                      @Ton-Machielsen
                                      There is already a radius. But this radius is limited for a reason. Point 7, 11, 12 and 16 on route shows why. It is normal practice that you do your best to place the waypoints on the road.
                                        @Ton-Machielsen
                                        Ahh cause found.
                                        Ton Machielsen
                                        Ton Machielsen
                                        Ton Machielsen
                                          @Ton-Machielsen
                                          Ahh cause found.
                                          Ton Machielsen
                                          Ton Machielsen
                                          Ton Machielsen
                                          @M-Schrijver Where can I find this setting?
                                          Carl Lee
                                          Carl Lee
                                          Ton Machielsen
                                          Ton Machielsen
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
