  3. [App] Announcements
  4. New update! (4.3.7) - Track navigation improvements and CP / AA zooming
42 Posts 14 Posters 27.9k Views 6 Watching
    Hi everyone! 👋
    A new update is coming your way! 🎉
    This one includes many much desired changes and improvements.
    It's not the biggest update of all but definitely one that will make you happy 🙂
    A lot could go wrong when navigating a track. Either from your own library or a generated scenic route / roundtrip. No real images to add for this but rest assured that the stability of track navigation has been improved a lot! 😃 No more unexpected detours, no more recalculations straight to the finish and no more frustration. Initial results are very positive but more of my time will be dedicated in finetuning the track navigation.
    CarPlay changes
    Zoom buttons are available on screen!
    While navigating, they are hidden under a submenu to preserve space for future buttons 🙂 When entering the zoom interface, the topdown mode is enabled and you can change the zoom level. After closing that menu, the last used camera modus before entering the zoom interface is used again 🎉
    Android Auto
    Same as for CarPlay! 🎉
    Besides that however another nice feature is added! You can now pan the map 😏
    When you have a touchscreen, simply drag the screen.
    If you do not have a touchscreen, a button will appear to enable the pan interface.
    Note: dragging the map is not supported on CarPlay
    Other changes
    • Fullscreen mode is now a preference (Navigation settings > screen layout)
    • Improved zoom limits in CarPlay / Android Auto (sometimes you were zoomed in way too much)
    • Updated HERE and Flutter SDK
    • Minor other tweaks
    What's next?
    We will process all user feedback and keep improving the app. Besides that, we are working on a major overhaul of the start page of the app and the general UI / UX. We expect a first beta in this month but public release is unsure due to licensing negotiations.
    Cheers,
    Corjan
    JP d
    JP d
    JP d
    @Corjan-Meijerink said in New update! (4.3.7) - Track navigation improvements and CP / AA zooming:
    So glad this option had been added. As an Android user I user navigation buttons. It's great to have them back.
    Thank you! Keep on improving! 🍻
    Thomas Neumeyer 1 Reply Last reply
    • JP d JP d
      Thomas Neumeyer
      Thomas Neumeyer
      Thomas Neumeyer
      wrote on last edited by Thomas Neumeyer
      @JP-d Might be but with Samsung Galaxy Tab Active 3 the App is currently not working. Navigation is working but did not tested it further. What is definitly not working is the start screen. There is no map. Reinstalled it but same result. Hope it will be fixed soon. Regards ThomasScreenshot_20250314_210455.jpg
      It ist bananas.
      • Léon Hassing
        Léon Hassing
        Léon Hassing
        wrote on last edited by Léon Hassing
        What is the difference between enabling and disabling this setting? The i-text says "Fullscreen mode: Hides notifications and the bottom app bar" 😕
        JP d 1 Reply Last reply
          A friend has problem on his Android Phone.
          Black screen and this.
          • Léon Hassing Léon Hassing
            JP d
            JP d
            JP d
            @Léon-Hassing if this setting is on I can't see the top (Status bar) on my phone this is where you see how much charge you left, 4g, the time and any notification icons.
            On my Android you can use gestures to navigate swiping or you can use buttons (back, home and recent apps).
            If full screen is on I can't see the top status bar nor the navigation buttons.
            Léon Hassing 1 Reply Last reply
            • JP d JP d
              Léon Hassing
              Léon Hassing
              Léon Hassing
              @JP-d Thank you for your response. That may be the reason why I didn't see any differences. I always use Android Auto and not my phone.
                More Information to my post from yesterday.
                App Version: 4.3.7 385
                Phone Samsung A51 4G
                Android Version: 13 One U.I 5.1
                No maps seen and tracking does not work.
                • Henk Oskam
                  Henk Oskam
                  Henk Oskam
                  Hi, I have testend it on a different tablet.
                  Samsung Tap A running on Android 14, UI 6 and then it is working.
                  So the problem is I think Android 13 or UI 5.
                  Hope it wil be fixed because the Tablet active 3 is integrated in my bike!
                  Henk Oskam
                  Www.hposkam.nl
                  • CHRISTOPHER TOOP
                    CHRISTOPHER TOOP
                    CHRISTOPHER TOOP
                    Can I add to this, since updating to this version on my Android Samsung phone yesterday, I no longer have a map display at all. All menus are there, as far as I can see, but no maps and hence no live tracking.
                    What has gone wrong, all was fine until I did the update.
                    My Samsung is an older S9 'Edge' running Android version 10.
                      Today a ride with the 4.3.7 version.
                      This version looks more and stable and smooth when riding.
                      But i don't see much diference in the autozoom functioniality. It stays more or less on the same zoom level regardless the driving speed.
                      Is this correct?
                      • Gaetano 9
                        Gaetano 9
                        Gaetano 9
                        I confirm... The zoom only works manually, not in relation to speed or intersections. Yet it is active in the options. It should be fixed to avoid zooming manually on a motorcycle. I would add that there is not always a warning of major slowdowns on the highways. It even recommends detours, for major slowdowns, where there are none. Still needs to be fixed a bit.
                        Google traslate.. 😊
                        • Nick Carthew
                          @M-Schrijver @Gaetano-9 What camera view are you using? Automatic zoom does not work with top down view. Adjust the camera view by tapping the compass.
                          Gaetano 9 1 Reply Last reply
                            What camera should i use?
                            I do not think i use top down
                              @M-Schrijver North up and dynamic both have automatic zoom.
                                Than it does not work in Android Auto.
                                In the settings are 4 options:
                                • Off
                                • Speed related
                                • Direction related
                                • Both
                                I use "Both" with dynamic zoom.
                                  • Off
                                  • Speed related
                                  • Direction related
                                  • Both
                                  @M-Schrijver Camera view has 3 options. Top down, north up and dynamic. You adjust the camera view by tapping the compass, it is not in the settings. Your camera view choice is stored and will be used next time until you change it.
                                  You see a notification each time you tap the compass that tell you which camera view is active and what zoom is available. My example shows top down is chosen and it is fixed zoom level.
                                    #26
                                    Yes, i know.
                                    The "compass" is set so dynamic.
                                    But in the settings are some settings which tells how the autozoom should behave. That one i've set to "Both"
                                      Yes, i know.
                                      @M-Schrijver Have you tried adjusting your default zoom correction? I have mine set to +0.0 which works for me.
                                        #28
                                        I did but i see very little changes. The global zoomlevel changes. But the range of zoom level does not change. The range of zoom level is very limited.
                                        I don't have real figures about the zoom level. So i will use examples.
                                        What it looks like to me at the moment
                                        Maximum zoomed out (at 100 km/u) is 1 cm on screen is 200 meters in real. Maximium zoomed in (at slow driving or stop) is 1 cm on screen is 150 meter in real.
                                        What I expect?
                                        At 100 km/u. 1 cm on screen is 200 meters in real.
                                        At 30 km/u/stop. 1 cm on screen is 30 meters in real.
                                          Gaetano 9
                                          Gaetano 9
                                          Gaetano 9
                                          @Nick-Carthew ....
                                          Today I checked and used all the possible settings. The automatic zoom does not work on AA but on the cell phone yes. Even with Google maps. On a motorcycle the automatics are important, if it is not possible I will switch to a Tablet or a dedicated cell phone.
                                          JP d
                                          JP d
                                          MartinW
                                          MartinW
                                          Léon Hassing
                                          Léon Hassing
                                          OGRIII
                                          OGRIII
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Gaetano 9
                                          Gaetano 9
                                          Henk Oskam
                                          Henk Oskam
                                          LR
                                          LR
                                          CHRISTOPHER TOOP
                                          CHRISTOPHER TOOP
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
