  4. how to force a route to take shortest distance between two waypoints
6 Posts 5 Posters 483 Views 1 Watching
  • David Ghoshundefined Offline
    David Ghosh
    when entering a new waypoint on a route how do i force myroute to use the shortest distance between the previous way point and the current waypoint i am trying to set?
    sometimes i experience myroute retracing the route backwards and doing a large loop between the previous waypoint and the current waypoint i am trying to set.
    Marinus van Deudekomundefined Nick Carthewundefined Kenny Thierensundefined 3 Replies Last reply
    • David Ghoshundefined David Ghosh
      @David-Ghosh You'll find that in the roolkit under RouteOptimalisation, then choose fastest
      Samsung S20FE mounted on a Quadlock and using Android Auto in my car
        @David-Ghosh Add a route point on the roads that you want to use is the best option.
        • LE DIZES Freddyundefined Offline
          LE DIZES Freddy
          faire attention aux fermetures saisonnières par exemple les col
          avec la carte HERE , vous avez la possibilité de les déactiver
          Bonne journée
          • LE DIZES Freddyundefined LE DIZES Freddy
            Bonne journée
            @LE-DIZES-Freddy yes in the tolbox you can deactivate seasonal close
              Kenny Thierensundefined Offline
              Kenny Thierens
              @David-Ghosh when something like that happens, 90% chance it's due to that particular street situation (one-way street, off-road, seasonal closure, limited traffic etc). So make sure settings are all good.
              If nothing of this helps, the way to force a straight line is to press the waypoint and then select "skip"Screenshot_20250304_000151.jpg .
              '07 BMW R1200RT
              DMD² T865x tablet
              Silverfox C1 controller
              Samsung S24+
              Cardo Spirit HD headset
              LE DIZES Freddy
              Kenny Thierens
              David Ghosh
              • GPX-Datei (Route) mit Wepunkten und deren Bezeichnung in MR-App importieren
              • New beta! 4.4.1 (406)
              • Spoken waypoints prevent spoken route directions
              • Functie Rondrit: Bij selectie van de rit graag linksom of rechtsom kunnen selecteren.
              • Google maps
              • MyRouteApp (WebPlanner) development Roadmap
                stuart marrittundefined
                stuart marritt
                1.1k
              • Stan Länder
              • Afstand bij het plannen van een toeristische route
                Lex.Kloet.RXundefined
                Lex.Kloet.RX
