  4. Trying to navigate from a GPX file in offline mode.
20 Posts 7 Posters 3.3k Views 4 Watching
  • Brian Martinundefined Brian Martin
    @Brian-Martin https://drive.google.com/file/d/1KYoFYJJOnKJHa7B8392jj4q_68A3HwkK/view?usp=drivesdk
    @Brian-Martin, You are sharing a textfile in Google drive, not the route in MRA 😉
    Brian Martinundefined 1 Reply Last reply
      Brian Martinundefined Offline
      Brian Martin
      @Con-Hennekens sorry, not with it today as I have a stinking cold. Will try again later.
        Brian Martin
        @Brian-Martin https://www.myrouteapp.com/en/social/route/10547614?mode=share
        Marinus van Deudekomundefined Guzzistundefined 2 Replies Last reply
          @Brian-Martin Hi Brian
          I'vew looked at your route
          Most of the waypoints are not ON the route
          Have you tried putting them ON the road
          If you have downloaded the maps of that country you should be able to use that route and navigate is
            Guzzistundefined Offline
            @Brian-Martin I also checked your route: same finding with WP not exactly on the road. Please use map engine HEERE to place the WP exactly.
            I tried also to navigate with. By online navigation, it works fine. Just by offline navigation, I have got error message: "could not calculate a route" - but this is because I did not download a map for offline usage before.
            So, everything works as designed for me 🙄
            • Guzzistundefined Guzzist
              Brian Martin
              @Guzzist Thanks for looking. How do you download for offline usage? I thought you just downloaded the GPX file to use for
              off and online.
                off and online.
                @Brian-Martin - oh, may I need to explain a little more 😌
                If you have planned a route in MRA Route Planner - or would like to use a track - than both would be available in myRoute-App as well for navigation. But it's needed to activate "synchronisation for all" in front of. (If you open a route in MyRoute-App, tap on 3 dots in top right corner and select "sync for all").
                By this, you can navigate with a route or with a track as long as you are online. If you intent to be offline later on, go online in front of your trip, goto your Account in MyRoute-App (tap 3 lines icon at top left corner, then Account icon at top right corner, then scroll down an select "offline maps" - and download maps for all regions/countries the route or track Passes trough you want to use. And keep them up to date further on!
                Just then, you can navigate with a route or track also offline 😁
                Not sure what you intend with the downloaded gpx file. From where did you download to where to store? You can use a gpx file from elsewhere, but at first upload it from your computer to MRA Route Planner. Then - as I wrote above, if you have switched on "synch" - the route or track you have created or uploaded to MRA Route Planner will be available automatically at your p.e. Smartphone in MyRoute-App. There is no need to load the gpx file to your Smartphone.
                  Brian Martin
                  @Guzzist I did what you suggested and it seems to have worked, not able to get out onto the road yet but after opening route in MRA in offline mode it did calculate and started instructions. I usually download GPX files into Google Drive on my PC, phone, and Tablet I use for navigation. It's pretty seemless, as soon as I and file is added to the folder it's there straight away on all devices.
                  Thanks for you help.
                    @Brian-Martin, the sync option @Guzzist explained takes the hassle out of "transferring routes to your device". That really is a thing of the past if you use MRA planner as well as MRA Navigation. 😉
                      Brian Martin
                      @Con-Hennekens I save the GPX files in Drive as I use different navigation programmes depending on what I'm doing so I have access to all. 👍
                      Brian Martin
                      • Am I using it wrong?
                        Kerry Lebelundefined
                        Kerry Lebel
                      • Spoken streetnames
                        GT JWRundefined
                        Gos Kuusundefined
                        Gos Kuus
                      • RX routes
                        1.6k
                        Papasmurf2undefined
                        Papasmurf2
                        1.4k
