  3. Using a mixture of via and shapping points
5 Posts 4 Posters 1.6k Views 1 Watching
  • Graham Hassell
    Graham Hassell
    Graham Hassell
    I can build the route using both via and shapping points but when I upload to my Garmin XT the route only shows the via points (flags) and not the shapping points.
    Is it the way they are uploading to my Garmin? I use my laptop to build my route then plug in the Garmin to upload the route.
    Carl Lee 1 Reply Last reply
    • Graham Hassell Graham Hassell
      Carl Lee
      Carl Lee
      Carl Lee
      @Graham-Hassell which gpx format are you using to transfer the route? 1.1 will transfer shaping points and via points but 1.2 will strip the shaping points. If you search the forum, you’ll find loads of info on this.
      • Carl Lee Carl Lee
        @Carl-Lee Check but the 1.2 will also send the track with the route. The track can be projected under the route in the XT.
        This it is not necessary to show all the waypoints. I've find this very usefull
          Carl Lee
          Carl Lee
          Carl Lee
          @Marinus-van-Deudekom 1.1 also sends the track which I always make visible. I have reverted to using 1.1 again due to the fact that you can allow recalculate and it will bring you back to the route if you have sufficient shaping points.
          Greenham 1 Reply Last reply
          • Carl Lee Carl Lee
            Greenham
            Greenham
            Greenham
            @Carl-Lee
            Completely agree. I've found after much consultation from our route experts that for the Zumo XT 1.1 just seems to work better.
            Carl Lee
            Carl Lee
            Greenham
            Greenham
            Graham Hassell
            Graham Hassell
            • screen
            • Live tracking
            • Rondrit generator ervaring
              Sam Kramer
              Sam Kramer
