  4. Route Makes Unexpected Detour
21 Posts 7 Posters 8.8k Views 3 Watching
    Can roadworks or accident in one direction be a cause?
    Just tried to make a route over the US 101 at that place.
    TomTom and Here made the same route. No detour as in your picture.
    @M-Schrijver I’m not sure what you’re looking at. The MRA detour is still there on the 101. I just also just tried the MRA Routeplanner in the app. The same detour appears.
    What’s interesting is that the native HERE app doesn’t show the detour. Maybe MRA has some avoidance on that I’m not aware of. I tried to set up zero avoidances, but who knows.
    MRA Web desktop is my favorite planner. But in cases like this, I switch to another app that I sometimes use. Again, I don’t want to set up odd waypoints in an attempt to trick the route into being useful.
      As you can see in my screenshot. The route is made in the direction as you screenshot and is made on the HERE map.
      No devation/reroute
      Found the cause.
      Change the transport mode from Motor to Car and your problem is solved.
      You can find a lot of topics were people are told to use Car instead of Motor.
      Transport Mode Motor does more damage than it has benefits.
      John S Parry Leike Lodiers 2 Replies Last reply
        No devation/reroute
        Found the cause.
        @M-Schrijver Thank you! Yes, I can see where this can cause a lot of confusion. I never would have figured this out. I appreciate your help.
          No devation/reroute
          Found the cause.
          @M-Schrijver @Corjan-Meijerink why don't you change the transport button to car/motor for the time being. That would take care of a lot of problem and explaining.
          • Leike Lodiers Leike Lodiers
            @Leike-Lodiers When in "Car" mode, routes do show a picture of a car and a motorcycle on top of each other for mode. BTW, is there a way to change the mode for routes already created? I can't figure out how to change it for other older routes.
            In any case, when in motorcycle mode, the route calculated in my example is just plain wrong at any level. Different for an explainable reason is OK, but that's not the situation here. What happened in my case is clearly a bug.
            @Corjan-Meijerink, is this on a list of upcoming fixes?
            Corjan Meijerink Rob Kelley 2 Replies Last reply
            • John S Parry John S Parry
              @John-S-Parry what exactly would be?
                @Corjan-Meijerink The fix?? I guess to calculate the route correctly. Which in this case is a direct line between two points.
                I'm not sure I understand the why there is confusion. The route I showed was a trip south on a major interstate (US-101) in California. There isn't a scenario I see where it makes logical sense to detour off the interstate to a side road, and then get back on. It doesn't make sense regardless of transportation mode.
                If in fact there is a reasonable explanation, please share. Otherwise, I don't know how else I'd frame it other than being a route calculation bug.
                  Rob Kelley
                  Rob Kelley
                  Rob Kelley
                  @John-S-Parry said in Route Makes Unexpected Detour:
                  Open the route in MRA on your PC and from the left bar menu select 'Route Information' and change it under 'Transport Mode'
                  GSA1250
                  HD Street Glide
                  XT500 x 2
                    @John-S-Parry Exactly! Please report it here: https://mapfeedback.here.com/#/report
                    We are not responsible for the HERE route calculation itself.
                    I'll report it too! Makes stuff gets notices quicker 😉
                    I know that for customers it doesn't matter who fixes it, as long it works in MRA but nothing much I can do about this specific case 😞
                      @Corjan-Meijerink Thanks for your response. I'll report when time permits.
                      What's interesting is the native HERE app (HERE WeGo), using the motorcycle profile setting, calculates correctly. I'll also try importing into the XT (also HERE) to see what's actually calculated. I don't know why MRA's HERE implementation would be different, but I guess there are complexities in play I don't understand. At least there is a solution I can implement now.
                      • Rob Kelley Rob Kelley
                        @Rob-Kelley Thanks for pointing me to the right place. 👍
                          Correction to my previous comment that motorcycle mode routes correctly on the HERE WeGo app. It doesn’t. 😳
                          Car mode routes correctly, while motorcycle has the same issue found in MRA. It’s definitely a HERE bug.
                            @John-S-Parry perfect, thanks for confirming!
                            • John S Parry John S Parry referenced this topic on
                            Rob Kelley
                            Rob Kelley
                            Gary Coates
                            Gary Coates
                            • Online map settings
                              MartinW
                              MartinW
                            • Real-time traffic
                              Òscar
                              Òscar
                              Andy Nicholson
                              Andy Nicholson
                            • HERE map not calibrated
                              MartinW
                              MartinW
                            • Myrouteappstay
                              Bé Jeuring
                              Bé Jeuring
                            • Navigatie met DMD tablet
                            • Show on the maps's button
