  4. Myroute-app reports "Wait or quit app"
6 Posts 3 Posters 355 Views 1 Watching
  • Motobummlerundefined Offline
    Motobummler
    Hello everyone
    I have a question about the behavior of the app on Android 13 with an Oukitel RT3. I often get the message that I should quit the app or wait for it. If I choose that I want to wait, the GUI or routing is still active. It looks like everything is running normally. Except that there is regularly the dialogue about the demand to end or wait the app. Only by ending the app can I break the cycle.
    I understand that the app is not a singleton program, but rather through the use of the various SDKs and frameworks it certainly comes to the use of tasks. My question would be why the dialogue comes up and what the cause can be.
    I am aware that the Oukitel is not exactly the resource monster and only has 4 GB of memory. However, I have turned off everything so far and optimized it so that only 30% memory is occupied.In addition, I have integrated a 64 GB SD memory card as expansion memory. This memory card is a very fast card and was built exactly for that. Thus, the Oukitel sees 64GB of main memory.
    My question would be what kind of experiences do you have with it or do you have such a problem at all. What setup do you have or which Android settings have you made?
    I don't think this behavior can be seen directly in connection with the app. Only almost always comes into the message while calculating the route after loading and starting the navigation.
    Best regards
    Michi
    iPhone XR (iOS 18.01)
    iPhone 11 (iOS 18.01)
    Oukitel RT3 (Android 13) + 64GB SD without SIM / connecting with tethering
    Wired CarPlay (KIA Sportage PHEV - 2022)
    • Motobummlerundefined Motobummler
      Hello everyone
      Best regards
      Michi
      @Motobummler, my guess is that your Android is trying to save battery on apps that seem to be not in use (because there is no interaction). In your Android settings you can grant the app permission to be always on, and do no battery savings for it.
      Motobummlerundefined 1 Reply Last reply
        Motobummler
        @Con-Hennekens, thanks for the tip. However, this has already been checked and allowed the app to be used without restrictions. It's a strange behavior. Since other users don't seem to know the problem, it won't be a direct app problem. But it's still annoying. I would be interested to know if there are other users with the same hardware/software in use.
        Merry Christmas
        Michi
        Jan 50undefined 1 Reply Last reply
          Merry Christmas
          Michi
          Jan 50undefined Offline
          Jan 50
          @Motobummler said in Myroute-app reports "Wait or quit app":
          Merry Christmas
          Michi
          Yes, sometimes this happens on various systems with various versions. Als hanging screens, and various other problems with android auto.
          • Jan 50undefined Jan 50
            Merry Christmas
            Michi
            Motobummler
            @Jan-50 do i understand that you sometimes had this problem in different phases of the app? If so, may I ask what hardware you have? If it is a hardware problem, I am thinking of changing my hardware.
              Jan 50
              @Motobummler Yes, that's correct. I drive a Renault Espace with Android a Ford with a pioneer system with android, on my motor i use a Maxca C5 and an Samsung S21, and S23. All systems show the same problems. So i don't think it's hardware related since other apps work on all systems just as expected.
              Jan 50undefined
              Jan 50
              Motobummler
              • New beta! 4.4.0 (400)
                CD130undefined
              • Looking for a Route from Roermond to Ijmuiden, Netherlands?
                Rob Veermanundefined
              • NAV 6 Craziness
              • 12 Tage in den Seealpen mit MRA und es war eher NICHT gut..
                UwBundefined
                UwB
              • Route en avance sur la position
                LE DIZES Freddyundefined
                LE DIZES Freddy
              • De geplande route even verlaten, kan dit?
              • Scherm indeling MRA routeplanner
                Robinekeundefined
                Robineke
              • Scenic routing & RouteXpert library improvements
                Edwin_Mundefined
                Edwin_M
                2.0k
